Emblempros
Old 05-03-2010, 07:50 PM   #1
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
Kook's install ?'S
I bought some used 1 7/8 Kooks with off road pipes.
1)Does the steering shaft need to be taken apart?
2)Do both headers slip in from the bottom side?
3)I have read that some people are having issues with the threads on the o2 sensors is this a hit or miss thing or should I put some heat on them before I back them out or penetrating lube?
4)Has anyone used o2 spacers with any success?
kaler is offline   Reply With Quote
Old 05-03-2010, 08:05 PM   #2
thecamaroguy
thecamaroguy's Avatar
Drives: 2010 Camaro SS/1967 Camaro SS
No on the steering shaft, if you can get the car up high enough, both will come out the bottom. The hardest part was getting the drivers side off, but it does come out the bottom.
Installation is from the bottom as well.
Thanks,
thecamaroguy
2010 Camaro 2SS - CGM
1967 Camaro SS350 - At Body Shop
Proud to say I have always owned a Camaro! A Camaro has been my Daily driver since I started driving!
thecamaroguy is online now   Reply With Quote
Old 05-03-2010, 08:14 PM   #3
ratlover
Drives: 2010 Inferno Orange SS 6 speed
Installs easy from the bottom.
Never heard mention on here about O2 sensors but I had a bitch of a time. Just pass side. Used a O2 socket and everything, acted like it was cross threaded from the factory. Broke free then tightened up. Didn't want to tighten back up or spin out. Driver side broke free then spun out by hand.
ratlover is offline   Reply With Quote
Old 05-03-2010, 08:23 PM   #4
Barton Industries
Barton Industries's Avatar
Use a Torch and heat up AROUND the O2 sensor and it will come out like butter.
The headers fit like a glove. They both will slide up from underneath and there is no need to remove anything except the old exhaust.
Barton Industries is offline   Reply With Quote
Old 05-03-2010, 10:05 PM   #5
mwt18
mwt18's Avatar
Drives: 2010 Camaro 2SS
I sprayed my O2 sensors with penetrating lube every night for a week before I installed my headers. Went to Autozone and loaned out an 02 wrench. It was cake taking them out.. 2 of them were cross threaded, but I didn't even need a breaker bar to free them. I think the key is to go through a couple of heat cycles with the penetrating lube. They should break free really easily.
mwt18 is offline   Reply With Quote
Old 05-04-2010, 12:32 AM   #6
kaler
kaler's Avatar
Cool thank you for the info guys.My Buddy is letting me barrow his exhaust/fabrication shop on Saturday so it should be a breeze.
Roto-Fab Cold Air Intake Install - PHASTEK Performance Sean@Phastek Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 03-17-2011 03:46 PM
Kooks complete system (headers/exhaust) Darth_Emma Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 56 03-28-2010 10:00 AM
My HURST Install, V6 Specific cschmidt1956 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 03-23-2010 04:22 PM
Cold Weather Blues Prevention Magnacharger Install Specials at Livernois Motorsports! Andy@Livernois Forced Induction 4 12-09-2009 07:53 AM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 05:36 PM
