Solo Performance
Old 05-04-2010, 07:07 PM   #1
IConnection
Drives: 2010 Camaro SS
Did some testing on the stock air box?
We had a cold air kit on a car and tested it...
We found that it heat soaked badly 105@Cruise/120@idle and it was hurting throttle response and maf tuning..
We then added the stock air box back into the car and they went to
85@cruise/100@idle???
The car was adding more fuel with the stock air box and the maf readings were better too...........
I am really starting to think that the stock box is fine and all you really need is a good tube...
The only other kit I really like----> Halltech Kit
I believe it to be the best kit aval for the Camaro to date
I know there's the Fastlane and the Injen whic mount the filter outside the engine bay and thats an excellent design but I'm just not convinced the aluminum tubing is the way to go...
I would love to see them or someone else make it out of plastic..
By the way the kit we tested was not a Fastlane or Injen....
I wont say whose kit it was becuase I am not into bashing other companies but I can tell u it has a plastic air box and aluminum maf tubing and the filter was inside the engine bay, it also had no lid on it....
Again IMO I would go Halltech or SLP's Blackwing tube and filter with the stock air box...
Is there better stuff out there, well I guess according to some of the testing thats been done but again testing is just that (a test)...Just like our test it really proves nothing other than what data you get and IMO are data sez stay away from aluminum maf tubes and crappy cold around surrounds..
I will recommend HALLTECH OR SLP's stuff to my customers..
I do beleive the VR is going to shine too but so far there hasnt been enough response's or testing to see if it really works, I know it worked well on the GTO's and G8 so in time we will see how it pans out...
Just trying to give honest data to guys looking to spend there money wisely
JS
IConnection is offline   Reply With Quote
Old 05-04-2010, 07:25 PM   #2
3GPa
3GPa's Avatar
Drives: SOLD/2SS/RS Painted Rally Stripes
Nice Write Up!
Thanks.
3GPa is offline   Reply With Quote
Old 05-05-2010, 07:06 AM   #3
gearhead440
gearhead440's Avatar
Drives: Yellow 2SS, 6 speed manual
Thanks for the info and data.
gearhead440 is offline   Reply With Quote
Old 05-05-2010, 10:04 AM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
Thanks for the honest opinion!
I'm definately happy with my Halltech!
Build Journal
Old 05-05-2010, 10:13 AM   #5
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Jannetty basically said the same thing that the stock box is pretty darn efficient and that the stock filter produced the same power as a kn when tested.
Old 05-05-2010, 12:52 PM   #6
spyderbuddy
spyderbuddy's Avatar
that was what i was talking about. it seems that the cold air kits really does not do anything great over the stock air box. with the out side temp being 84 degrees, my air inlet temp was 101 degrees. so i can not see how they are getting a benefit from there setups
Old 05-05-2010, 01:26 PM   #7
rmnc3r
Drives: me up the wall.
Nice Writeup. Glad to OE Engineering is Top Shelf.
I've been playing with this idea and like to throw it out:
The Stock Box has an unused inlet; would there be any
benefit or detriment to open the hole and run a tube down
towards the bottom of the chassis? Superficially, this
would seem to turn the stock box into a CAI type system.
rmnc3r is offline   Reply With Quote
Old 05-05-2010, 02:29 PM   #8
Gnarlygianni
Gnarlygianni's Avatar
Drives: Black Camaro 2SS
what about all the intakes that DO receive a gain such as C.A.I. , Roto-Fab, ect
Gnarlygianni is offline   Reply With Quote
Old 05-05-2010, 05:14 PM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
It's not so much that the others give better IAT's than the OEM seup, but most of them will FLOW considerably better. IAT's aren't then end all/ be all to making a CAI. It has to flow AND give good IAT's. If you're getting the same or better IAT's AND have more air flowing, you have a winning combination. It's the degree of these two things that make one CAI better than the other. We won't go into flow turbulance and driveablity with this thread.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-05-2010, 05:26 PM   #10
IConnection
Axis,that is true but when we see a CIA adding heat and scewing MAF readings VS a STOCK OEM FILTER SYSTEM it lead us to believe that GM has done a pretty good job..
I will honestly say the there are a few systems out there that are good
We just feel the Halltech MAY be the best to date
This could change over time and I hope thats the case because there is nothing wrong with competition, I was just putting up data we were seeing with this particular kit and nothing more :o)
Old 05-05-2010, 08:54 PM   #11
spyderbuddy
Thanks i thought it had to do with flow over temp
Group Buy - ADM Performance Cold Air Intakes @ Apex Motorsports Apex Paul V8 Bolt-Ons & Tunes 34 06-08-2010 09:09 PM
ADM Performance "Street" & "Race" intakes in stock and ready to ship! FREE SHIPPING!! Apex Motorsports V8 Bolt-Ons & Tunes 23 05-22-2010 08:14 AM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 08:37 PM
Late Model Racecraft Cold Air Kits IN STOCK Late Model Racecraft V8 Bolt-Ons & Tunes 5 08-06-2009 05:42 PM
