Jason 98 TA
Old 10-13-2008, 09:35 PM   #1
69er
Drives: 69 Z/28 , 83 Z/28 (L69), 10 2SS CGM
SKIP-SHIFT??????
Someone in another thread mentioned that the manual transmission has skip-shift. I thought they did away with this on the Corvette years ago!
Say it ain't true!! How do I disable it??
I ain't gonna have no friggin' computer tell me how and when to shift!!!!!!!! !!!
69er is offline   Reply With Quote
Old 10-13-2008, 09:40 PM   #2
RallyFever
Senior Member
RallyFever's Avatar
Drives: 2010 Camaro 2SS
My vette had a light in the dash come on when it was ACCEPTABLE to shift from 1st to fourth, but that's the extent of the system.
RallyFever is offline   Reply With Quote
Old 10-13-2008, 09:40 PM   #3
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
OH please dont let this happen....I hated that darn skip-shift!!!
ZZcamaro is offline   Reply With Quote
Old 10-13-2008, 09:43 PM   #4
bolteon593
Drives: 2011 GT500
why? doesn't seem like such a bad idea to me.
bolteon593 is offline   Reply With Quote
Old 10-13-2008, 10:10 PM   #5
bret03
bret03's Avatar
Drives: 30th anniversary Z28, Jeep XJ
On my 4th gen a $30 dummy plug from Jegs that gets plugged into the wiring near the transmission solved that problem, but I have driven newer Corvettes already without the feature.
bret03 is offline   Reply With Quote
Old 10-13-2008, 10:19 PM   #6
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
Yes it will have the skip shift from 1st to 4th.
franknbeans is offline   Reply With Quote
Old 10-13-2008, 10:24 PM   #7
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
$5.00 resistor from radioshack will take care of it.
I piss excellence
and fart awesomeness
Old 10-13-2008, 10:25 PM   #8
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
i dont get it, why is it so bad to have a skip shift thing? Learn2Shift?
headpunter is offline   Reply With Quote
Old 10-13-2008, 10:32 PM   #9
Captain Awesome
Drives: 2010 Camaro 2SS/RS
I think Radio Shack stopped selling discrete components 5 or 6 years ago. Certainly they are gone from all my local stores.
Captain Awesome is offline   Reply With Quote
Old 10-13-2008, 10:34 PM   #10
Captain Awesome
Just learn how to throttle the gas to keep the fool thing from triggering. It's not hard at all. I don't even notice mine there anymore.
Old 10-13-2008, 10:45 PM   #11
Jamestwilliams
junior member
Drives: Grand Am
The following is based on what I have heard about skip shift so I could be wrong. I thought that the skip shift function only kicked in under normal light acceleration conditions, and was deactivated when you either used additional throttle or held first gear longer.
Jamestwilliams is offline   Reply With Quote
Old 10-13-2008, 10:53 PM   #12
69er
After a few times of trying to shift into second and it doesn't go in, that would drive me insane. I could get used to it, but I don't want to!
I don't know how much throttle you have to use to stop it, but it seems that this would make me use that amount of throttle all time and increase the amount of emissions and ruin the gas mileage this function is supposed to help with.
Old 10-13-2008, 10:56 PM   #13
Captain Awesome
I drive 25 miles to work each way, and go through 2 stoplights and 2 stopsigns. I seriously doubt that you could measure the difference that skip-shift makes in my commute. 99% of my drive is in 6th gear.
Old 10-13-2008, 11:05 PM   #14
69er
True, but I'm also looking at it from the EPA view. If you tend to keep giving it a certain amount of throttle above the normal light cruising, then the emissions might be increased, along with the theoretical decrease in mileage, however minor. They try to get every drop, you know.
I'm just grasping for straws as to why it has to be!
Fall Bondurant/ Skip Barber track av8r 5th Gen Camaro SS LS LT General Discussions 0 09-30-2008 06:35 PM
No-Lift Shift AirGoya 5th Gen Camaro SS LS LT General Discussions 29 03-09-2008 12:08 PM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 06:11 AM
