SDTW Custom Wheels & Tires
Old 05-04-2010, 10:56 PM   #1
DeezNuts
DeezNuts's Avatar
Drives: 2010 Cyber Grey Camaro LS
Exclamation Starter mods for the V6?
Now everyone knows the basics of upgrading (CAI, Exhaust, Plugs and Wires) But what else should/could be done on the V6? Would changing out the cams and throttle body be the next step? I have a goal for the V6. I want to make it put the same power to the wheels as the ss without forced introduction (or come close) if thats even possible.:bangdesk:
DeezNuts is offline   Reply With Quote
Old 05-04-2010, 11:50 PM   #2
spyderbuddy
spyderbuddy's Avatar
plugs and wires?
it's coil on plugs
Old 05-05-2010, 12:10 AM   #3
masterofpuppets
Pulling your strings
masterofpuppets's Avatar
Drives: My girlfriend crazy with car talk
I really doubt you're going to get those numbers without going the FI route.
masterofpuppets is offline   Reply With Quote
Old 05-05-2010, 01:05 AM   #4
SDCamaro10
SDCamaro10's Avatar
Drives: 2010 Camaro 1LT RJT
Hmm.. well, with whats on the market right now I highly doubt you'll get that kind of power. However, if you wanted to spend the money, and its not cheap.. port and polished head, P&P intake manifold, larger throttle body, bore the cylinders, larger pistons, get some valve work, not sure if theres anything out there for the fuel management system... full exhaust, long tube headers, cold air intake, nitrous, lose some of the weight in the car, smaller wheels with better tires, swap the rear end out with an SS rear end, 4.10 gears, lightened pullies, performance cams... stuff like that.
SDCamaro10 is offline   Reply With Quote
Old 05-05-2010, 07:57 AM   #5
DeezNuts
DeezNuts's Avatar
errr...guess im boosting then.
Old 05-05-2010, 09:33 AM   #6
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
Bmwdon has a similar project going and hes looking to get some nice numbers without going the FI route....but hes still not expecting SS numbers.
Can't wait to see his results though.
Old 05-05-2010, 10:34 AM   #7
Teddydog
Teddydog's Avatar
Drives: ABM 2LT M6 RS
Wow. I thought you wanted to modify your starter and was wondering what was wrong with it!
Rob
Teddydog is offline   Reply With Quote
Old 05-05-2010, 10:17 PM   #8
faninc
Drives: 2010 Camaro RS in SIM
engine is 312 hp stock and Diablo could not even tune better, so did not release a tuner for v6. use 93 octane and be happy. Add CAI for a bit more...GM built a helluva a V6.
faninc is offline   Reply With Quote
Old 05-05-2010, 10:51 PM   #9
diamondmike
diamondmike's Avatar
Drives: 2SS/RS
the best way to make this v6 s go fast. take the motor out and install a big block.
i thinking 502 efi with the a/c blowing. now thats a camaro
7.83 @ 172 and 1.15 60ft 5th gen
4.93@143
diamondmike is offline   Reply With Quote
Old 05-05-2010, 11:23 PM   #10
DeezNuts
DeezNuts's Avatar
Well Im glad this turned into a thread bashing, I was trying to ask more along the line if it was possible and if so how would one go about it. I guess I'm going to install the throttle body spacer, my full exhaust, better plugs and bigger injectors and re-map the ECU when that comes out for starters. Thanks for the little help you gave.
Old 05-06-2010, 05:27 AM   #11
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM 2SS
I don't know why the others said what they said, but..........there's plenty of threads in this section alone, discussing exhaust swaps, intake swaps, MAF relocations, cams, blah blah blah........maybe you should read through the section or search before starting a thread that has been started 150x since this forum has started.
Alot of us get tired of explaining the same thing again and again every week when someone comes and starts a thread "what are some mods for v6"
Blade is offline   Reply With Quote
Old 05-06-2010, 05:57 AM   #12
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Throttle body spacer...
ummmm... and good luck finding those bigger injectors....
scrming is offline   Reply With Quote
Old 05-06-2010, 10:22 AM   #13
KMPrenger
KMPrenger's Avatar
DeezNuts....don't waste your money on a TB spacer, or injectors and the likes. Start off with exhaust and intake. Long Tube headers and tune will be your biggest gain, if you want to spend the money, For the intake side of things, my recommendations...go with Injen (which has proven results), or wait for AirRaid's new redesigned tube (which sounds promising so far, but likely wont perform much or any better than Injen).
You just can't make power cheap on this car, but the above should net you an extra 25 or 30 horses and would definitely be a noticeable improvement.
Old 05-06-2010, 03:14 PM   #14
DeezNuts
DeezNuts's Avatar
Thanks KM. I think I'll just read posts and not start threads
V6 Camaro VS V6 & V8 Stangs xpanda305x Chevy Camaro vs... 17 05-03-2010 11:06 PM
Drove Camaro V6 vs Challenger V6 I drove Stew Chevy Camaro vs... 23 11-12-2009 03:05 PM
4th Gen. Z28 to 5th Gen. V6 tryan2422 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 27 11-11-2009 08:20 AM
Mods, Mods and More Mods Tecca Cosmetics and Lighting Modification Discussions 28 09-15-2009 01:20 PM
ok what mods do we have for the v6 acehole Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 1 08-01-2009 01:53 AM
