SDTW Custom Wheels & Tires
Old 05-05-2010, 10:18 PM   #1
chicagojoe16
chicagojoe16's Avatar
Drives: 2010 Camaro
Car is 'Pulsing' Power
I have an SS with the LS3. I've been experiencing something that is kinda scary at times, I'm hoping someone here can give me advice. If I'm at a stop and decide to put the hammer down, I'll be fine in first gear but once I put it in second gear the car starts to give power in pulses. My right foot is still on the pedal but the car is jerking forward about every half second. Any idea what the problem is? Would the battery reset help this? A mechanical engineering friend of mine suggested that perhaps it's due to the way the body shop at my Chevy dealer put the left front wheel on after my accident back in January. He thought it might be a traction control issue.
Thanks for your thoughts.
Imperial Blue SS
chicagojoe16 is offline   Reply With Quote
Old 05-05-2010, 11:34 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Do you have any mods?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-05-2010, 11:52 PM   #3
wbdinger
wbdinger's Avatar
Drives: NSMNJW=2010 CGM 2SS/RS LS3
kinda sounds like traction control cutting in an out ?
DYI Oil Catch Can, DYI dash ABL, DyI fender "V"emblems, ACC Plasma DRL, DYI Painted red SS on steering wheel, DYI CGM painted bowties on wheels, DYI Clearcoated Brake Calipers, Eibach pro 1" lowering springs, GM Heratige grill, GM skipshift eliminator, GMPP 92206992 Exhaust, 2-10" Kenwood subs w/350watt pioneer amp, RiderGraphics hood spears/gill outlines, 9x20 wheels-custom silver,weather tech mats, ARH 17/8 headers and cats. Tuned by Davenport Motorsports.
wbdinger is offline   Reply With Quote
Old 05-06-2010, 12:02 AM   #4
BikeRacer13
Drives: 2010 Camaro 2SS
I know exactly what you're referring to as I was experiencing the same thing. I took it back to the dealer, they did a 'reprogram of the ECM for power hop' at launch. This seemed to work for about 1 1/2 - 2 months of daily driving, but now I'm having the same problem again. Guess I'm gonna take her back in again but this time I want them to find what's causing this. No mods. Yet.
BikeRacer13 is offline   Reply With Quote
Old 05-06-2010, 06:47 AM   #5
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Maybe try the fuse pull, 5 and 20 for 3 hours.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-06-2010, 07:33 AM   #6
Dave2SSRS
Dave2SSRS's Avatar
Drives: 2010 Camaro 2SS/RS
He has the LS3, the fuse pull is for the L99.
2010 Camaro 2SS/RS
Imperial Blue | Grey two-tone Interior | Silver racing stripes | Magnaflow Comp Cat-back | CAI intake | Elite Engineering Tunnel Brace |
Richmond (Houston), TX
Dave2SSRS is offline   Reply With Quote
Old 05-06-2010, 08:01 AM   #7
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
mmm weird... tell us when you find out
AlSuwaidi is offline   Reply With Quote
Old 05-06-2010, 08:02 AM   #8
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Take to dealer. Let them fix it.
9/26/09 Took delivery!
Old 05-06-2010, 08:06 AM   #9
Edrock
Edrock's Avatar
Drives: '10 Camaro 2SS LS3
It works for the LS3 as well...at least it did for mine. Noticed an immediate difference.
DT Shorties, Solo hi-flow Cats, X-pipe, resonator delete, Flowmaster Super-44s, VMAX TB, Stronger MAF, C.A.I. Intake with race scoop, and JRE Tune!
WOT is my happy place!!
Edrock is offline   Reply With Quote
Old 05-06-2010, 08:45 AM   #10
Dave2SSRS
Dave2SSRS's Avatar
Oh ok.. then I stand corrected. I thought the battery disconnect was for the LS3.
Whatever works!!
2010 Camaro 2SS/RS
Old 05-06-2010, 09:21 AM   #11
Scott@Bjorn3D
Whatever works!!
Battery disconnect is not needed for either car. Just 3 hour fuse pull. There is a battery backup unit for ECM so the battery disconnect may have to be for days.
Old 05-06-2010, 09:48 AM   #12
chicagojoe16
Drives: 2010 Camaro
No mods, don't really know what you mean by traction control sound. I think I'll try the fuse pull, see if that does anything. I can't get to my dealer for a while as I am at college until the end of May so hopefully the the fuses take care of it.
Imperial Blue SS
Old 05-06-2010, 09:52 AM   #13
R1CH
R1CH's Avatar
Drives: 2010 CGM 2SS/RS 6M
Check the MAF (Mass Air Flow Sensor); make sure it's tightened down all the way and not loose.
R1CH is offline   Reply With Quote
Old 05-06-2010, 11:24 AM   #14
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Sounds like the traction control is kicking in when you shift into 2nd which limits power to the wheels when they try to spin.
Before you do anything, turn off the traction control and try it again. If your issue goes away, then this is what it is and pulling the fuses nor the dealer can help you as the car is running normal.
Nitrous info CamaroSpike23 Forced Induction - V8 63 06-20-2017 11:15 AM
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 03:07 AM
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 09:39 PM
"The car of the future may turn out to be no car at all." Scotsman General Automotive + Other Cars Discussion 2 11-03-2007 01:22 AM
