Emblempros
Old 05-08-2010, 11:04 AM   #1
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
2001 SS, Black/Black, M6, T-Top, H/C, 6,100 Original Miles.
I have this listed over at LS1tech, but I figured I post it up on camaro5 since I spend more time here these days, anyway...
I'm the original owner. I bought the car new in 2001 and daily drove it for 3 months. Then, I began modding it and it's been a garage queen, sunny day toy ever since. It only comes out on nice days and has been in the rain only once since 2001 (not my fault, it was at Rapid when it happened). The car is loaded with leather, t-tops, and single-disc Monsoon audio.
All the internal engine work was done by Mikey at Rapid Motorsports. He spec'd and installed the cam, installed the heads, ported/port-matched the FAST intake, and tuned the car. Everything else on the car has been installed by me or my father. Nobody else has ever touched it. According to Mikey, the cam is about as radical as you can go on the street, however, the driveability isn't too bad. The car is also set up with an off-road Y, so no cats. It will not pass an emissions test. I have kept the annual mileage well below the cut-off for a PA emissions exemption. The car is fully documented with window sticker, SLP window sticker, SLP owner's portfolio, and receipts for every part/mod on the car. Here's the mod list:
SLP BUILD DATE: 03/05/2001 PURCHASE DATE: 07/06/2001
SLP ENGINEERING OPTIONS:
· CAMARO SS FRONT GRILLE
· BILSTEIN ULTRA SUSPENSION PACKAGE
· CAMARO SS EMBROIDERED FLOOR MATS
· CAMARO SS EMBROIDERED REAR DECK MAT
· CAMARO SS DASH PLAQUE AND KEY FOBS
· COMMEMORATIVE OWNER’S PORTFOLIO
AFTERMARKET PERFORMANCE MODIFICATIONS:
· MTI STAGE IIR LS6 HEADS (milled .030, Manley double springs, titanium retainers, hand ported/polished, 3-angle valve job)
· RAPID MOTORSPORTS DOMINATOR C1 CUSTOM GROUND CAMSHAFT (237/242 .612/.612 112 LSA)
· CRANE CAMS HYDRAULIC ROLLER LIFTERS
· TRICK FLOW HARDENED CHROME MOLY 7.200 PUSHRODS
· CRANE CAMS GOLD RACE ROLLER ROCKER ARMS, 1.8 RATIO
· SLP PERFORMANCE PARTS HEAVY DUTY OIL PUMP
· SLP PERFORMANCE PARTS DOUBLE ROLLER TIMING CHAIN
· ARP HEAD STUDS, CAM BOLTS, CAM RETAINER PLATE BOLT
· LS6 PCV CONVERSION
· ACCURATE MACHINE WORKS PCV CATCH CAN
· MTI/ASP UNDERDRIVE CRANKSHAFT PULLEY
· RAPID MOTORSPORTS SETUP/CUSTOM TUNING
· KOOKS LONG TUBE HEADERS, 1 3/4” PRIMARIES, STAINLESS STEEL, CERAMIC COATED BY JET HOT
· KOOKS 3" OFF-ROAD Y-PIPE
· BORLA XR-1 RACE MUFFLER (INTERMEDIATE PIPE)
· GMMG, INC. CHAMBERED EXHAUST SYSTEM
· SLP/OEM CENTER MOUNT EXHAUST CONVERSION
· SLP PERFORMANCE PARTS SUPPLEMENTAL COLD AIR INDUCTION KIT
· TEXAS SPEED & PERFORMANCE HIGH-FLOW AIR BOX LID
· SLP PERFORMANCE PARTS 85MM MASS AIR FLOW SENSOR
· SLP PERFORMANCE PARTS AIR INTAKE BELLOWS
· HOLLEY POWERSHOT HIGH-FLOW AIR FILTER
· F.A.S.T. LSX 90MM INTAKE MANIFOLD, PORTED/PORT-MATCHED BY RAPID MOTORSPORTS
· NICK WILLIAMS C.N.C. BILLET 90MM THROTTLE BODY
· NASTY PERFORMANCE BILLET FUEL RAILS
· RACETRONIX HIGH-PERFORMANCE IN-TANK FUEL PUMP SYSTEM
-RACETRONIX/DELPHI 36LB FUEL INJECTORS
· THUNDER/KATECH BILLET BELT TENSIONER
· TAYLOR THUNDERVOLT 10.4MM IGNITION WIRES
· THUNDER RACING COIL PACK RELOCATION KIT
· A.I.R. SYSTEM DELETE
SUSPENSION/DRIVETRAIN/OTHER MODIFICATIONS:
· SLP PERFORMANCE PARTS SUBFRAME CONNECTORS
· PPO RACING STRUT TOWER BRACE
· BMR CHROME MOLY ADJUSTABLE PANHARD BAR
· G2 ADJUSTABLE LOWER CONTROL ARMS (Polyurethane bushing/rod end)
· LINGENFELTER ENGINEERING 3.5” HEAVY DUTY ALUMINUM DRIVESHAFT
· SLP PERFORMANCE PARTS SKIP-SHIFT ELIMININATOR
· PRO-5.0 POWER TOWER SHORT-THROW SHIFTER W/ UMI PERFORMANCE SHORT STICK
· HARLAN SHIFT LIGHT
· SULLIVAN RACING PRODUCTS ALUMINUM PEDALS
· GRANATELLI MOTORSPORTS 200MPH SPEEDOMETER CONVERSION, WHITE GAUGE FACES
· CUSTOM "SS" EMBROIDERED HEADRESTS
· POLISHED BILLET BELT TENSIONER PULLEY
· SPEED, INC. CUSTOM FIBERGLASS PCM COVER
· GENIII PERFORMANCE BILLET ALUMINUM VALVE COVERS, CHROMED
· STAINLESS STEEL ENGINE BOLT KIT BY TOTALLY STAINLESS
-UNDERHOOD CHROME BOLT KIT BY HILLCO FASTENERS
· CUSTOM STAINLESS STEEL MESH GRILLE INSERTS
· S.S. INSERTS REAR CAMARO LETTER FILL-INS
· S.S. INSERTS 8" ANTENNA
· AMERICAN RACING TORQ-THRUST II WHEELS: 17x9.5 FRONT, 17x11 REAR
· BFGOODRICH g-FORCE T/A KD TIRES: 275/40 FRONT, 315/35 REAR
· YANK TORQUE ARM RELOCATION/TRANSMISSION CROSSMEMBER
· SPOHN CHROMOLY ADJUSTABLE TORQUE ARM
OPTIMA RED TOP BATTERY WITH CUSTOM CHROME COVER
CHROMED DIPSTICK TUBE WITH MBA HANDLE
CHROMED/SHORTENED THROTTLE CABLE BRACKET
Full set of MBA billet aluminum cap covers (rad cap, washer reservoir cap, coolant reservoir cap, power steering reservoir cap, master cylinder reservoir and fill cap)
SLP "Camaro SS" Car Cover with Storage Bag and Cable Lock
The car put down 451 rwhp/396 rwtq on the dyno that mikey uses. The car does very well for what I use it for. If you would plan to race this car, you would need to upgrade the rearend. It's still the stock 10-bolt, so it won't hold up to many drag strip launches.
The car is located just north of Pittsburgh, PA.
$22,000 Reasonable offers considered.
I have a few more pictures in my FQuick garage and a ton more available on my computer. If there is any specific picture you would like to see, just send me a PM.
http://www.fquick.com/garages/viewvehicle.php?id=10799
Quick video of car at idle:
More photos here:
http://img268.imageshack.us
/g/img1825l.jpg/
Kilo-9 is offline   Reply With Quote
Old 05-08-2010, 11:12 AM   #2
5thgencamaro11
The Need for Speed!
5thgencamaro11's Avatar
Drives: 2010 VR Camaro 2LT
Very Nice!! somebody should get on this quick!
Victory Red 2010 Camaro 2LT
A6 /High Wing Spoiler / Black Rally Stripes/ Side Hockey Stripes
5thgencamaro11 is offline   Reply With Quote
Old 05-09-2010, 03:38 AM   #3
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
this car is gorgeous!!! I would snap this up in 2sec if i had the extra 20k laying around.
The 2010 Sin is offline   Reply With Quote
Old 05-09-2010, 03:58 AM   #4
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Man..makes me miss my 4th Gen.
Looks GREAT.
Old 05-10-2010, 05:49 PM   #5
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Thanks, everyone!
Old 05-16-2010, 01:16 AM   #6
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Bump.
Old 05-16-2010, 11:43 PM   #7
kunkelz28
kunkelz28's Avatar
Drives: 2010 Camaro SS RS
free bump for an awesome car at a great price
kunkelz28 is offline   Reply With Quote
Old 05-22-2010, 02:44 PM   #8
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Bump.
Old 05-27-2010, 01:37 PM   #9
sportyb24
Romanian Outlaw
sportyb24's Avatar
Drives: 13 ZL1 , 14 Silverado Crew Cab
Bump bump nice car
[/SIGPIC]2013 Camaro ZL1 M6
sportyb24 is offline   Reply With Quote
Old 05-27-2010, 09:29 PM   #10
ULTIMATEORANGESS
Drives: 1999 Hugger SS 2005 QS GTO
very nice. itll make a good home wheres theresxno emission testing.
ULTIMATEORANGESS is offline   Reply With Quote
Old 05-28-2010, 01:43 AM   #11
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
True!
Old 06-11-2010, 11:46 PM   #12
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Bump...still available.
Old 07-01-2010, 12:07 AM   #13
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Car is Sold. Thanks!
Old 07-01-2010, 09:13 AM   #14
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
Wow nice ride congrats on the sale!
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Do you want the Z28? ChrisB Camaro ZL1 Forum - ZL1 Specific Topics 1616 09-05-2010 12:49 AM
Why do you think the Z28 is the higher tier? The_Blur Camaro ZL1 Forum - ZL1 Specific Topics 181 10-14-2009 09:08 PM
NCE Camaro convertible drop top first drive! black_camaro_SS 5th Gen Camaro SS LS LT General Discussions 71 08-07-2009 04:58 PM
2001 SS HELP HOTRIDES1 4th Generation Camaros 4 03-06-2009 05:23 PM
Possibly buying a 2001 SS w/ 62k miles and a few mods MajorTom 4th Generation Camaros 2 10-10-2008 03:38 PM
