JUICEDMOTORSPORTS
Old 05-08-2010, 06:45 PM   #1
Merc
In The Circle
Merc's Avatar
ARH Headers
Does anyone know for sure what size the header bolts are on the LS3 to attach the ARH's to the LS3? Looking at Stage 8 Fasteners, they have a very cool locking header bolt system. Once there locked they will not back-off.
Old 05-08-2010, 07:30 PM   #2
JB @ C and L Machine
Drives: Ordered 2011
I had ....well some what since they all didn't fit on my mustang. IMO...they are a waste of money. I going to use these http://www.mcmaster.com/#lock-washers/=707htc
JB @ C and L Machine is offline   Reply With Quote
Old 05-08-2010, 07:42 PM   #3
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
There is nothing wrong using factory gaskets and header bolts. They clamp perfect. Problem is if the header flange is warped and no matter how you clamp you will still have leakage in that area. Save your money. Get your headers coated for protection and heat control with the money you saved.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 05-08-2010, 08:30 PM   #4
Merc
In The Circle
Merc's Avatar
You coated the 304 stainless headers form ARH? We normally coat all the steel headers we build. But not the SS ones. Interesting.
Old 05-08-2010, 08:32 PM   #5
Merc
In The Circle
Merc's Avatar
$1800 headers. The locking bolts are only $40, even ARP SS are around $25.
Old 05-09-2010, 10:47 AM   #6
Sack Rat 2SS
The cost of those header bolts is not too bad so go for it. More to coat headers. I don't like the way stainless headers discolor over time. They start off looking OK but gradually change. Plus the coated contain heat better inside the tubes. Plus adding a little BLING to engine compartment. Here is a pic from underneath.
Silver 2SS/RS Man/6
GM 3.91 Rear Gears
Old 05-09-2010, 10:58 AM   #7
You miss understood ...They did not fit right on some of the "hard" bents IE...the front tubes. For me they are a total waste of time and money!!! Its your $$$$$ do want you want ...but they will not just fall on the bolts. They WILL have to be modified to fit!!
Old 05-09-2010, 01:43 PM   #8
ratlover
Drives: 2010 Inferno Orange SS 6 speed
I have ALWAYS had an issue with header bolts backing out. On the camaro though not the case? Kooks headers, factory bolts and gaskets. I assume the arh uses equaly as nice of flange as kooks since they are a high end header, kooks is very thick and finished well. I'd say they arnt needed for your car but added insurance is never bad.
ratlover is offline   Reply With Quote
Old 05-09-2010, 02:35 PM   #9
BLK2SS
BLK2SS's Avatar
Drives: Black 2SS
I'm not a big fan of the Stage 8 fasteners. I went with Percy's split lock bolts, part# 21008. The size you are looking for is M8 1.25 x 25mm.
BLK2SS is offline   Reply With Quote
Old 05-09-2010, 03:11 PM   #10
Merc
In The Circle
Merc's Avatar
So you have tried them? I did think about that and if you tried them and speaking from experience. Thanks Bud.
Old 05-09-2010, 03:14 PM   #11
Merc
In The Circle
Merc's Avatar
Thx. Taking it all in. Just thought they maybe the ticket. Maybe re-consider. That's why C5.com is so cool.
Buying ARH Headers + Corsa Exhuast Don't, Wait! jpetro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 06-17-2010 11:09 AM
Modern Muscle Exhaust and Intake Special modern-muscle V8 Bolt-Ons & Tunes 1 01-20-2010 07:46 PM
JBA releases exhausts, headers and midpipes. Bewenched Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 09-16-2009 04:04 PM
3" Magnaflow Installed with ARH Headers - BEST SOUND EVER! ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 42 09-10-2009 12:45 PM
