sjm autoprod
Old 05-09-2010, 03:58 PM   #1
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
Carbon Fiber vs. Hydrocarbon
I want some of our vendors and members to come together and give us some data on the differences between hydrocarbon and carbon fiber. The best, most scientific contributions may be added to the Wiki for reference.
Here is some of the comparative information I want to post in the Wiki:
  • appearance comparison
  • texture comparison
  • weight when given the same size piece (use a scale, no estimates)
  • strength of each
  • longterm durability comparison
  • cost of construction for each
Let's not forget the most important guideline.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 05-09-2010, 04:18 PM   #2
fixxxer525
Drives: 01S10,01CBR600,05Ducati, 10 2SS/RS
Send a message via ICQ to fixxxer525
Hydro Carbon is just a sticker overlay.
fixxxer525 is offline   Reply With Quote
Old 05-09-2010, 04:24 PM   #3
Indpowr
Drives: Corvette C6
There are 3 styles.
Hydro Carbon
Carbon Fiber (lamination)
Solid Carbon fiber
Hydro Carbon - It’s a process that transfers selected ink patterns onto 3D or contoured surfaces. The film is placed on water and the high-molecular base begins to dissolve, a patented chemical activator is sprayed over it, causing the ink to remain floating in an oil like state on top of water. The part is then immersed into water and the upward pressure of the water causes the ink to wrap around and adhere to the part.
Process -
1. All parts are sanded down and smoothed out for any imperfections and are carefully inspected.
2. We then prime the products to be ready to go to the paint booth.
3. The next step is applying the PPG paint color of your choice or base color.
4. The next step is to dip the product in the imersion tank to apply the carbon fiber film pattern.
5. After the pattern is dry and baked on we then apply 3 coats of PPG clearcoat and polish to become a show stopping,deep, guaranteed long lasting finish.
From Wiki
Carbon fiber (carbon fibre), alternatively graphite fiber, carbon graphite or CF, is a material consisting of extremely thin fibers about 0.005–0.010 mm in diameter and composed mostly of carbon atoms. The carbon atoms are bonded together in microscopic crystals that are more or less aligned parallel to the long axis of the fiber. The crystal alignment makes the fiber very strong for its size. Several thousand carbon fibers are twisted together to form a yarn, which may be used by itself or woven into a fabric.[1] Carbon fiber has many different weave patterns and can be combined with a plastic resin and wound or molded to form composite materials such as carbon fiber reinforced plastic (also referenced as carbon fiber) to provide a high strength-to-weight ratio material. The density of carbon fiber is also considerably lower than the density of steel, making it ideal for applications requiring low weight.[2] The properties of carbon fiber such as high tensile strength, low weight, and low thermal expansion make it very popular in aerospace, civil engineering, military, and motorsports, along with other competition sports. However, it is relatively expensive when compared to similar materials such as fiberglass or plastic. Carbon fiber is very strong when stretched or bent, but weak when compressed or exposed to high shock (eg. a carbon fiber bar is extremely difficult to bend, but will crack easily if hit with a hammer).
Lamination meaning that a sheet of REAL carbon fiber is laid over top of a already pre-molded part (fiberglass, plastic) then resin etc is laid on top of it.
Not all Carbon Fiber (lamination) is the same. Some of it is made in China and some of those cheaper products use cheap resin which will turn colors and crack over time.
Hydrocarbon looks good and in inexpensive, but carbon fiber has a depth and 3D effect to it that just can't be achieved with anything else. Solid Carbon Fiber panels is what F1 uses along with other racing and aircraft use but are usually so expensive that the average car buyer would not pay for it but appears the same as the real carbon fiber (lamination).
As far as weight goes.
OEM Piece = x weight
Hydro Part = x plus the weight of paint
Carbon Fiber (Lamination) = x plus the carbon fiber materiel, resin, clear
Solid Carbon Fiber = a whole brand new part = less weight
Photo comparison of Carbon Fiber (lamentation) vs. Hydro Carbon
Old 06-15-2010, 12:00 PM   #4
guiLT
Tampa Gulf Coast Family
guiLT's Avatar
Drives: 2001 Maxima
Whoa. This is the first sticky in the "Other cars Disscusion".
Carry on.
Old 06-15-2010, 07:42 PM   #5
nova
nova's Avatar
Drives: 2010 Camaro 2SS/RS, VR, PW, WR
I've got a fair amount of experience designing and fabricating composite structures from my college days so maybe I can add some useful information.
I was team lead for the following unmanned aircraft competition for the 2005-2006 year (before they won).
http://www.xipiter.org/
The aircraft you see there is primarily composed of carbon fiber structures produced using a variety of techniques. The design shown on the website is pretty close to what we had when I was on the team, a configuration I did probably 80% of the structural design for.
The thing I would add here is that CF can also be had in whats known as "pre-preg" where the CF cloth comes from the factory with resin already in it. You then just lay up your CF layers on your mold and cure.
The end result is a lot more consistent than a wet lay up or vacuum assisted resin transfer molding (VARTM) technique but the materials cost is quite a bit higher. Storage is also more of an issue because you typically must store pre-preg under refrigerated conditions to keep it from curing on its own.
To give you an idea of the expense of pre-preg, our aircraft above had a wingspan of 128in and weighed in at 55 lbs. We used $5000+ in pre-preg carbon fiber to build it.
An improperly designed CF part can actually weigh more that an equivalent metal part. In order for a CF part to realize all the advantages of composite materials, you have to have very well defined load paths and you have to design the part such that its greatest load carrying capability is along those paths, with less load carrying capability in other areas. Treating CF like an isotropic material (same properties in all directions, ie black aluminum) which its not, will result in a lot of excess weight.
The Beech Starship is a prime example of this phenomenon.
Maybe I'm going too deep into things but hopefully someone will find the information interesting...
2010 2SS/RS, M6,VR,White Rally's,Polished Wheels
Mods:
skip shift eliminator (hey everybody's gotta start somewhere )
crappily painted engine cover...
nova is offline   Reply With Quote
Old 07-28-2010, 08:22 PM   #6
Mr Twisty
Mr Twisty's Avatar
Excellent info... Do you have any experience with cored layups that you would like to share? The marine industry seems to love it.
-- Benjamin Franklin
New Aluminum and Carbon Fiber Driveshafts coming soon GFORCE1320 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 12 06-10-2010 09:47 PM
Carbon Fiber Cowl Hood, Trunk, and more! PHASTEK Peformance Sean@Phastek Exterior Parts & Accessories 3 01-29-2010 03:44 PM
Real Carbon Fiber and Hydrocarbon Differences (Pictures Inside) dsvcustoms Cosmetics and Lighting Modification Discussions 14 10-15-2009 10:48 PM
Hydrocarbon and Real Carbon Fiber Installed (Pictures Inside) dsvcustoms Cosmetics and Lighting Modification Discussions 22 10-01-2009 09:42 AM
