Old 05-09-2010, 08:03 PM   #1
papabearcamaro
papabearcamaro's Avatar
Drives: 2012 Chevrolet Silverado 4x4 Z71
104 octane in a bottle
Just curious about this stuff.
Is there any real benefit to using this? I know the SSs are built to run 93 octane but if this is used would the extra octane hurt anything?
Just to let you know,the car goes in for headers and a dyno tune in June so if this stuff was used I could have the car tuned accordingly. Also,it sees very little use,maybe 500 miles to 1000 miles a year so I am not worried about the extra added expense of putting it in every tank full..
These are just questions I am asking out of curiosity,I do not have it in my head to run out and buy this stuff. Thanks for everyones comments.
SOLD(Traded for 2012 Silverado Z71 4x4 and 2012 Sonic Hatch.)...2010 Camaro 1SS/RS/LS3,yellow with House of Kolor Tangerine Pearl rally stripes,manual trans.Hurst short throw shifter,4 pack rally gauges,Roto-Fab air intake,Kooks long tube headers with high-flow cats,Borla S-Type catback exhaust,Comp Cam,PRC ported heads,Maggie with 3.6 pulley and 1:1 cog drive,secondary fuel system with 65lb injectors,ADM digital A/F and Boost gauge,Pfadt trailing arms and subframe bushings.614.25rwhp/566.82rwtq on 8# of boost.
2012 Chevrolet Silverado 1500 EX.Cab 4X4 Z71.
papabearcamaro is offline   Reply With Quote
Old 05-10-2010, 01:27 AM   #2
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
Mostly snake oil; will provide a minor amount of octane boost, maybe 0.4 above your gasoline octane rating.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected
obe1 is offline   Reply With Quote
Old 05-10-2010, 10:03 AM   #3
Russell James
Russell James's Avatar
Drives: Camaros
It only does anything if your getting spark knock. So if your not getting sparK knock, it's a waste of money.
I wouldn't use it prior to tuning either, because you want to tune for whatever gas you will be normally using. If you have 93 octane in the area and a near stock LS3, should have no need to use octane booster.
Most of the octane boosters work pretty good. I use to have an 11 to 1 CR 468 BBC in a street strip bracket car. On 93 it would spark knock. With a couple bottles of 104+ in there it would not knock, and I could bump the timing up.
Old 05-10-2010, 10:16 AM   #4
ron10
Drives: 2010 2SS IOM L99
this is a way to spend money for nothing.
Old 05-10-2010, 11:12 AM   #5
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via AIM to WheelmanSS
Yup. That stuff is crap. Unless you want to buy it by the pallet. At which case, you're better off going to the gas station and filling up 100 unleaded.
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ
- Vortech V3 Supercharger
- Kooks Stepped Headers, Magnaflow 16580
- Suspension by Pfadt, Hotchkis.
2007 Trailblazer SS- Sold
2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold
1994 Camaro Z28 - Sold
WheelmanSS is offline   Reply With Quote
Old 05-10-2010, 02:26 PM   #6
lol
Old 05-10-2010, 02:46 PM   #7
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
I'm not so sure the stuff is worthless. I've purchased several bottles of different brands and my butt dyno could tell the difference--even with the cheap stuff that's less than $2 a bottle. We can only get 91 octane here, but at 4,500' above sea level that's generally all we need. I'm not claiming you would see a substantial, or even measurable, timing increase on a dyno, but there's one way to find out...
Meh
My 5th is offline   Reply With Quote
Old 05-10-2010, 05:37 PM   #8
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
Waste of money if you're just putting one bottle in there. I don't know how much is in the bottle, but let's just say 16 fl. oz. That's 1/8, or .125 of a gallon.
So let's say you fill your tank up with 18 gallons of 93 octane. Then you put 16 oz of 104 octane in there.
That 16 fl oz is .00694, or 0.694% of the total volume. So 99.306% of your total fuel is 93 octane. Already it's easy to see that it's not going to make much of a difference.
93 octane x 99.306% = 92.355
104 octane x .694% = .722
92.355+.722 = 93.077 octane that you effectively end up with.
UsedTaHaveA68 is offline   Reply With Quote
Old 05-10-2010, 07:10 PM   #9
MJanowich
Door ding magnet
MJanowich's Avatar
Drives: 2010 Black 2SS/RS
A fuel's Octane rating doesn't relate to the energy content of the fuel, just the resistance to pre-detonation. Stick to 91 or higher Octane and don't worry about the additives.
MJanowich is offline   Reply With Quote
Old 05-10-2010, 07:16 PM   #10
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Just find a Sunoco around you that sells 100 octane, there's 2 around me that do
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 05-10-2010, 07:40 PM   #11
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
keep in mind that when they say "we raise your octane 5 points" 10 points equals one octane rating so that 5 points changes your fuel from 91 to 91.5
only octane booster that works is Lucas, but if you can find race fuel, that is prefered... i blend 104 octane unleaded race fuel (sunoco gt240 plus) with 91 octane in an 11:2 ratio to effectively make a 93 octane blend.
check this out:
http://volvospeed.com/Reviews/octane_boosters.html
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
Old 05-10-2010, 07:40 PM   #12
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Your car is designed around 93. The factory computer is pretty darn smart. It is extremely unlikely you would gain any NOTICEABLE change. If you were going FI or Nitrous then other fuel requirements come in to play. It basically consists of some petroleum distillates which may help with detonation, but that's about it.
Old 05-10-2010, 09:00 PM   #13
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Well, then you butt-dyno needs to be recalibrated.
If you truly understood how many "octane" points you were actually gaining, you would see it is absolutely minimal/barely worth noting.
And another thing... octane DOES NOT equal horsepower. Octane is a measure of fuel's compression before it ignites. Too low of octane level cause knock due to the fuel igniting from compression and not spark. Your computer counteracts for this by reducing timing.
93 octane is sufficient for an L99 or LS3. Even at 91 you should be fine. Unless your area is plagued with shitty quality gas, there is no reason to seek out anything of higher octane. The only people needing higher octane on this forum are for members with A.) Forced induction B.) Certain Nitrous applications or C.) Built motors with higher CR.
573 RWHP 498 RWTQ
Old 05-11-2010, 09:59 AM   #14
Soundwave
Soundwave's Avatar
Drives: Camaro SS(2)/RS
This is truth.
You guys and your "noticeable gains".
Good to know I could make millions selling bullshit in a bottle though when I'm ready to retire!
Soundwave is offline   Reply With Quote
Octane Ratings? Icefsh Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 12 03-10-2015 06:10 AM
What type of fuel to use? Matth3w 5th Gen Camaro SS LS LT General Discussions 13 03-24-2010 01:56 PM
How to get 93 octane? BlownSS 5th Gen Camaro SS LS LT General Discussions 3 03-23-2010 01:11 PM
Anyone running something other than 87? jeansonne627 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 31 10-01-2009 03:40 PM
No 93 Octane in California tribone Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 15 08-27-2009 05:18 PM
