JDP Motorsports
Old 05-09-2010, 08:01 PM   #1
RyanG
Drives: 2010 Camaro SS/RS IOM
Suspension Upgrade Advice for Rural (Crappy) Roads
Folks,
Looking for some advice on suspension upgrades. The issue is I live in Eastern Canada where 80% of the roads suck (New Brunswick). What I don't want to do is make the ride so stiff that on the bad roads it feels like the car going to shake the teeth out of me.
I had a 99 Trans Am and had a front tower brace and sub frames and really liked it. Then I had a 2001 firehawk with the "autocross" setup, it handled like a dream on a good highway but on the normal roads it was hard to take.
If I put sub-frames, front brace, and better sway bar would that "harden" the ride too much?
So far I like how the Camaro rides stock on the crappy roads but would like a bit beter handling on the highway.
Any suggestions?
Thanks so much for any advice.
~Ryan
RyanG is offline   Reply With Quote
Old 05-10-2010, 01:37 AM   #2
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
So some info would be helpful
1. What are your goals
2. What wheels and tires are you running or going to run
3. What hp do you have.
4. Do you want to lower your Camaro
5. Do you have a budget
6. What type of driving will you be doing besides bad roads
thanks
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 05-10-2010, 05:32 AM   #3
RyanG
Answers
Answers to the questions:
1. What are your goals?
A: Just to make the car handle a bit better, eliminate and body flex. Minimize body roll on the highway when passing someone a little too fast. bascially better handling than a 2011 Mustang GT or Shelby.
2. What wheels and tires are you running or going to run?
A: Stock tires and wheels that come with the SS/RS package (20” wheels and Pirellis)
3. What hp do you have?
A: Only thing I have added a SLP LMII and CAI to the car. All I plan to do for 2-3 years.
4. Do you want to lower your Camaro?
A: No. Roads too crappy.
5. Do you have a budget?
A: No, looking for best solution for my needs. Looking to spend less than more. Like a Stage I type of situation.
6. What type of driving will you be doing besides bad roads?
A: Just daily driving, no racing or drag racing. Just looking for better handling when hitting the off ramps aggressively
Thanks Mike!
~Ryan
Old 05-10-2010, 11:11 AM   #4
Info@PeddersUSA.com
Thanks Mike!
~Ryan
Here are some recommendations based on the following:
1. better handling than a 2011 Shelby
2. Maintain ride height
Camaro Street XA
Merlin P/N is CAMARO STREET XA
This is a value Package with a kick. The new state of the art Pedders eXtreme Xa coil Overs are revolutionizing the auto community. The Mono tube 30 way adjustability will give you the ultimate in desired ride; a flexible ride. Maximum comfort when you want, to killer control when you have to show the world you are on top of your game. This package will include the critical bushings of Street 1. Plus our alignment package will give you full alignment extended alignment capabilities front and rear and adds 1 to 1.25 degrees of positive front caster!
P/N Part Description
160086 Camaro eXtreme Xa Multi Adjustable Coilover Kit By Pedders with 8kg/mm Front and 10kg/mm Rear Coil Rates
EP1167 Zeta Rear Differential Bush Kit
EP1200 Zeta II Rear Extreme Sub-Frame Connector Kit
EP6578 CAMARO Front Radius Rod STIFFENING SNUBBERS (new)
PDUSACAMFULL CAMARO REAR EXTENDED CAMBER, TOE ADJUSTERS, FRONT CASTER ECCENTRICS & CAMBER ADJUSTERS
Then add Camaro Solution B sway bar kit:
CAMAROSOLUTIONB 27MM FR. & REAR BARS WITH 4 ADJUSTABLE ENDLINKS Larger HD end links require enlarging mounting holes.
Here is a better, more complete kit that will exceed your needs:
CAMARO TRACK II with Xa Coil Overs
MERLIN STORE PART NUMBER IS CAMARO TRACK II
The Track II combines all the components of the Street II and adds sway bars, all bushes and adjustable HD Endlinks. With the virtual pivot point design and the advanced rear suspension you tracked Camaro does not need to be over sprung and over damped. In complete OE trim it will out perform many respected marquees. With a Track II System we are going hunting for the big boys with big dollar stickers. We add more urethane bushes to create greater control. These are Pedders exclusively designed urethane bushes that use voids, shapes and volume of urethane to increase control while maintaining an OE like ride. There are no squeaks. It is not rough. It is AMG like control. It has long been the Pedders philosophy that sway bars are not used to correct deficiencies in your suspension. Sway Bars are the final tuning step for a properly sprung, damped and bushed vehicle. Pedders sways offer four positions of adjustment front and three positions of adjustment rear. They include Pedders urethane bushes. They are perfectly matched to provide an amazing level of control as they compliment your Pedderised ZETA II Camaro, PLUS the flexibility to fine tune the control rates to fit your needs. This kit uses our Pedders eXtreme Xa Coil Overs that give you a massive amount of flexibility, custom tuning to your individual driving habits and needs. You will have complete suspension travel no matter what height you set the Xas at. This will give you the same comfort at a 2 inch drop as you would have at a 1/2 inch drop. For the SS Camaros with Brembos, we strongly recommend adding our Complete Brake Hose Kit for added performance and security. PDUSACAM2800
EP1167HD REAR ZETA HD DIFFERENTIAL BUSHING KIT
EP1201HD CAMARO VERY HD REAR SUB-FRAMEBUSHING REPLACEMENT
EP2112 Zeta Steering Rack Bush
EP6577 CAMARO Front Radius Rod Bushing
EP7264 Zeta rear lower control arm inner
EP7322 Camaro Only Rear Control arm - Upper inner rear.
EP7323 Zeta Camaro Rear Toe, and trailing arm links in and out.
For better handling, we need some higher performance coils. But you do not want to dorp the vehicle and due to your roads, you still need to maintain suspensipon travel. Our Xa coil overs will do this. You can get to OE height, and maintain full suspension travel, and yet have the flxibility to adjust damping levels when you require a more spirited control.
Hope this helps. If you have any questions, just ask
thanks
mike
dms
Old 05-10-2010, 05:01 PM   #5
RyanG
Thanks Mike. When I get the rest of my pennies saved for this I am calling YOU.
The info has been a great help, and I bet helped some others as well.
~Ryan
Old 05-10-2010, 05:05 PM   #6
Info@PeddersUSA.com
~Ryan
It is my pleasure. You are wise to ask questions and would expect more to come as you digest it all.
I will continue to be here to assist you
thanks
mike
dms
Old 05-10-2010, 05:47 PM   #7
Circuit Motorsports
Drives: 2005 STi
If you're not looking to lower the car and you want to keep the ride with as much travel and compliance possible then a set of good swaybars would be your best bet IMO for a beginning mod.
If you DON't want to lower the car and you drive on rough roads I wouldn't recommend coilovers.
Circuit Motorsports is offline   Reply With Quote
Old 05-10-2010, 07:03 PM   #8
Info@PeddersUSA.com
With our Pedders Xa coil overs, we offer extreme diversity with the 30 way detented damping levels. At the 0-5 clicks you are at the OE damping levels. At 10-14 clicks, you are at aggressive street ride. At 20 clicks, you are at roadracing levels. So with our Pedders Xa coil overs, they will be able to handle rough roads and full suspension travel without any problems. It will be sportier than OE, but I will remind all that the thread poster expects the Camaro to outhandle a 2011 Shelby. The 2011 Mustang GT has some advantages over the current model Camaro SS.
mike
dms
Old 05-10-2010, 08:04 PM   #9
cool
Old 05-10-2010, 11:02 PM   #10
Circuit Motorsports
Drives: 2005 STi
I'm familiar with the Xa coilovers. I personally wouldn't recommend them for someone who doesn't want to lower the car, make it any sitffer or lose ride quality on rough roads though. Mind you I'm not recommending other similar coilovers either.
I think the OP would be happy with a track pack from Hotchkis. It will tightren up the chassis with the Max chasis brace and the swaybars. However it does include lowering springs, which while they will improve handling, will also lower the car which he stated he didn't want.
So in lieu of that I would recommend swaybars, and the max chassis brace and front strut tower bar for a stiffer chassis and better handling without compromise on the stock damping or travel.
Old 05-11-2010, 08:12 PM   #11
Info@PeddersUSA.com
Stiffening up the chassis will not make the Camaro outhandle a 2011 Shelby, which was one of the requirements the poster has made. Adding controls to reduce the camber change in the front by approximately .005 degrees, which is not even measurable on any current alignment machine will do little to improve the handling.
The 2011 Mustange has a much stronger set of sway bars, far better tires , a lot firmer and lower shock and damping levels and a serious weight advantage and a better front to rear bias ratio than Camaro. So sway bars only will not do it.
We have almost as much experience now with the new Mustang as we do with the Camaro. We are just not talking about it yet because we have not introduced our product yet for the Mustang, with the exception of the Xa coil overs, that are far better than the Topiko and Steada units now being offered. But I am not going to bore this community with all the Mustang stuff. But the new Mustang GT or Shelby is a very fine platform just like the ZETA II platform is on the Camaro.
Camaro has the disadvantage coming out with a system that was better than the 2009 Mustang GT. So Camaro raised the bar, then Mustang jumped. Now What might be coming down the road for Camaro will change the playing field again.
mike
dms
Old 05-12-2010, 10:34 AM   #12
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
I'd have to agree. Not lowering, keeping travel, eliminating body roll, no racing, these are all characteristics of items that can be addressed by installing a good set of matched swaybars. This is a great recommendation, especially for a beginning mod, that wont break the bank. These are upgrades you would still want to pursue even if you were to install coilovers, so you may as well start there, and then address any perceived lack of performance after you get used to the new handling and balance of your Camaro.
We also offer a strut tower brace to stiffen up the chassis, as well as solid subframe mounts. We have had a TON of customers install these on street cars and love them. I am not sure how bad the roads are where you drive. I would forgo the subframe bushing recommendation for this very reason.
Give us a call if you have any questions, on our products or other wise.
Old 05-12-2010, 11:15 AM   #13
Circuit Motorsports
Drives: 2005 STi
^ Agreed.
Pfadt and Hotchkis, both good companies for swaybars and chassis braces.
Old 05-12-2010, 11:28 AM   #14
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
MTI makes great sway bars. They made a huge difference in my SS/RS
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 02:28 PM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 04:21 PM
G-Force Rear Suspension and Halfshaft Upgrade! Pics Mike TexaSS Suspension / Brakes / Chassis 11 02-07-2010 06:46 PM
MTI Racing Stage 1 Suspension Upgrade MTI Racing Suspension / Brakes / Chassis 0 01-27-2010 10:14 AM
