BORLA
Old 05-12-2010, 03:49 PM   #15
wyocamaro
wyocamaro's Avatar
Drives: 2010 2SS/RS, 2-2007 Silverados
Originally Posted by PfadtRacing View Post
I'd have to agree. Not lowering, keeping travel, eliminating body roll, no racing, these are all characteristics of items that can be addressed by installing a good set of matched swaybars. This is a great recommendation, especially for a beginning mod, that wont break the bank. These are upgrades you would still want to pursue even if you were to install coilovers, so you may as well start there, and then address any perceived lack of performance after you get used to the new handling and balance of your Camaro.
We also offer a strut tower brace to stiffen up the chassis, as well as solid subframe mounts. We have had a TON of customers install these on street cars and love them. I am not sure how bad the roads are where you drive. I would forgo the subframe bushing recommendation for this very reason.
Give us a call if you have any questions, on our products or other wise.
SO.... Rough roads out in WY also and to achieve better handling (not track racing), maintain smooth ride, on twisting mountain roads that occasionally can be washboard, etc, a good bet is the sway bar kit and tower brace combo ONLY- no bushings, etc?????
Thanks
2SS/RS, Sunroof, IOM Inside and out, Manual.......VIN 7754. 5000: DELIVERED 5/18/09
wyocamaro is offline   Reply With Quote
Old 05-13-2010, 08:04 AM   #16
2quick
Drives: none
I would suggest a three way adjustable front and rear sway bar set to just start out with. That way if you add more you can adjust for it. Try that out then move on up from there. You don't really seem to be a full coil over type of situation. You don't want to road race. All you want to really do is improve handling a little better to help pass on the freeways and on ramps and a coil over seems like over kill for that. If possible find a local club that may have some cars with different setups that you could take a ride in them. That would help you out a lot i think.
2quick is offline   Reply With Quote
Old 05-14-2010, 02:39 PM   #17
Hotchkis
Drives: 1st through 5th gen Camaros
Originally Posted by RyanG View Post
Folks,
Looking for some advice on suspension upgrades. The issue is I live in Eastern Canada where 80% of the roads suck (New Brunswick). What I don't want to do is make the ride so stiff that on the bad roads it feels like the car going to shake the teeth out of me.
I had a 99 Trans Am and had a front tower brace and sub frames and really liked it. Then I had a 2001 firehawk with the "autocross" setup, it handled like a dream on a good highway but on the normal roads it was hard to take.
If I put sub-frames, front brace, and better sway bar would that "harden" the ride too much?
So far I like how the Camaro rides stock on the crappy roads but would like a bit beter handling on the highway.
Any suggestions?
Thanks so much for any advice.
~Ryan
We'd have to throw in our vote with the "keep it simple" suggestions, sway bars and a brace. As much as we love springs, you probably don't need them for what you plan to do with the car. If you decide to go road racing later, you can always change springs then.
Hotchkis is offline   Reply With Quote
Old 05-14-2010, 05:50 PM   #18
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Thanks
Hey! It's not that we wouldn't recommend bushings, but they are really more of a secondary concern for upgrading, based on the OPs goals. It is our opinion that this should be left up to the customers discretion as to how rough the roads are in their area, and how that will affect their ride quality. We have engineered bushings that reduced friction values, for excellent street use. But, some customers are more sensitive to installing poly at a lot of locations.
We always recommend, as Hotchkis seems to agree, to keep it simple for the time being. Going overboard right away can lead to less than desirable results, and the customer not having a good idea of which part they are not happy with (if any).
It is really going to be on a case-by-case basis, the users end goals, and their sensitivity to perceived NVH concerns. All of these factors play an integral role in recommendations.
Old 05-15-2010, 05:46 AM   #19
AWS-GTAW
Drives: 2010 Camaro 2ss M6
Is it possible to remove and install sway bars without jacking up the motor and loosening the mounts?
AWS-GTAW is offline   Reply With Quote
Old 05-17-2010, 09:26 AM   #20
2quick
Drives: none
Yes it is possible to do it without jacking up the motor.
Old 02-05-2011, 11:10 PM   #21
Tarl
Drives: Rally Yellow/black -2010 Camaro
How easy or hard is it to install a sway bar kit and tower brace? Can you do this in your garage listening to some music and sipping a drink? This is an easy bolt on right? And what do you guys recommend? Want to tighten up the handling some before doing more major mods. Baby steps...hehe
Tarl is offline   Reply With Quote
Old 02-07-2011, 09:08 AM   #22
2quick
Drives: none
yes you can do this in your garage. Little cussing with the front bar when twisting it out but not that big of a pain.
Old 02-07-2011, 09:20 PM   #23
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Just because it's possible doesn't mean it's easier. While it is possible to get the bar out without lifting the motor, it takes a specific routine which I find time consuming and very aggravating, especially when it is so much simpler to just lift the motor. What most don't realize is that this is not like older cars where you have to relieve pressure from the motor mounts, unbolt a cross-bolt, then spend an hour trying to re-align it again when you put it back together. The mounts sit on stands and are aligned via studs. You can physically lift the motor in 5 minutes - loosen two nuts, jack up the motor, and you are ready. The swaybar practically falls out this way vs. wrestling and twisting it out of the car when not lifting the motor.
BMR guy is offline   Reply With Quote
Old 02-08-2011, 09:15 AM   #24
2quick
Drives: none
For some the thought of lifting the motor is a little daunting. I do agree it is a faster way of doing it if your comfortable working on cars.
Old 02-10-2011, 12:40 PM   #25
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
There is absolutely NO reason to lift the motor to remove the front sway bar. Lift the car. Remove the front wheels. Remove the four bolts that hold the steering rack in place. Slide the OE bar out. Before reinstalling the four steering rack bolts you have the oppotunity to install Pedders EP2112 steering rack mount to compliment your new sway bars. Replace the rack bolts.
Old 02-10-2011, 02:02 PM   #26
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Obviously there are more ways than one to remove the front sway bar.
Pete thinks its easier to move the rack, I think it's easier to lift the motor. The motor mount nuts are practically in your face and located on the bottom of the K-member. There are only two of them vs. 4 bolts for the rack that are located in a cramped location between the cradle and the motor.
Yes, you can do it either way, I am only pointing out that lifting the motor is much simpler than everyone thinks it is. If it were a race to remove the front sway bar using both techniques, the guy lifting the motor would win every time.
Old 02-22-2011, 11:04 PM   #27
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Pull off the OE center brackets and bushings. This might take longer, but you don't have to disassemble any major parts (like steering rack or motor).
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 03:28 PM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 05:21 PM
G-Force Rear Suspension and Halfshaft Upgrade! Pics Mike TexaSS Suspension / Brakes / Chassis 11 02-07-2010 07:46 PM
MTI Racing Stage 1 Suspension Upgrade MTI Racing Suspension / Brakes / Chassis 0 01-27-2010 11:14 AM
