Mechanical Maintenance: Break-in / Oil & Fluids / Servicing Discussions on mechanical maintenance and servicing of your Camaro
Old 05-10-2010, 01:48 PM   #1
andyscozz
Drives: CGM 2SS
Oil Temp gauge - low oil temp!
New to V8's, new to Chevy's.
Guess I never really had an oil temp gauge before either.
Anyway, every time I start up the car after sitting for 4+ hours, the oil temp is at the minimum (photo attached)
Is this normal? The car feels "rough" until the temp raises as well. I try to never jump on the gas until it's warmed up. I figured it might have had something to do with the weather as I got the car in Feb and it was still cold out. But now we've had patches of 70+ weather, and it's doing the same thing.
Thoughts??
andyscozz is offline   Reply With Quote
Old 05-10-2010, 02:11 PM   #2
Jay2SS109
Redemption
Drives: .
Jay2SS109 is offline   Reply With Quote
Old 05-10-2010, 02:13 PM   #3
Russell James
Russell James's Avatar
Drives: '12 SS/RS LS3 IBM
normal.
with so much aluminum, it's going to cool off to ambient fairly quick. Some of the older engines that were almost all cast iron use to hold heat for a long time.
As long as it comes up to temp, above 200ish after some miles - 15 minutes or so, then it should be fine. If it never comes up, I'd think something in that guage circuit is bad.
Old 05-10-2010, 04:05 PM   #4
andyscozz
Drives: CGM 2SS
It definately comes up to normal ~200 after 10-15 minutes. Was just wondering if I was the only one!!
Want to get the oil changed also, been 3k miles.
Old 05-10-2010, 04:13 PM   #5
Mr Smith
Born again Hot Rodder
Mr Smith's Avatar
Drives: Black 1SS/RS LS3 M6
You wouldnt expect your oil to be over 100 degrees with your car setting at whatever outside or garage room temps would be do ya?
Black 1SS RS MT: Powder Coated Bow Ties, Blacked out windows, Debadged, 4 Pack gauge cluster. Pure perfection.
Mr Smith is offline   Reply With Quote
Old 05-10-2010, 04:39 PM   #6
ron10
Drives: 2010 2SS IOM L99
that is normal.mine does the same thing.
Old 05-11-2010, 06:41 AM   #7
rtcat600man
having FUN now
rtcat600man's Avatar
Drives: 2010 2LT IOM
Yes, the temp. is going to be low until you warm everything up. Mine sits around 200 degrees similar to the coolant temp and trans temp, once I have run everything for 5 to 10 minutes. I wait until all temps are up and normal before getting on the gas hard.
Old 05-11-2010, 07:02 AM   #8
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Sounds normal, so long as it moves up to the normal range after 10 minutes. If it stays below 100 deg, then you probably have a problem with the gauge.
Old 05-11-2010, 09:20 AM   #9
Jay2SS109
Redemption
Drives: .
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 12:20 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
