BeckyD@RodgersChevrolet
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 05-10-2010, 01:49 PM   #1
gearhead440
gearhead440's Avatar
Drives: Yellow 2SS, 6 speed manual
Dyno results for Granatelli plug wires
The complete thread is located here: http://www.camaro5.com/forums/showthread.php?t=82034
This is an excerpt and a copy of my dyno runs on the Total Performance dyno in Monroe, NC, just east of Charlotte, NC.
With dyno conditions of 96Fg, 13% humidity, max stock numbers were: 362hp, 365 ft-lbs. I realize that others have gotten numbers in the 370’s but this is what we received.
Swapping out a K&N air filter that mates to the stock air box, P/N 33-2434, and New Era Performance tube that mates to the stock air box: 370hp, 361 ft-lbs. 8hp increase, torque apparently slipped slightly at max. Combined cost: $145, cost per hp: $18.13 / hp.
Total increase from base pull: 19hp, max torque remained the same but the average torque and hp (area under the curve) were increased noticably (~ 15 ft-lbs) across the usable rpm band.
Total cost: $275, cost per hp: $14.47 / hp.
We can really tell a difference in the sound and performance of the car and are extremely happy with our results and that is what matters the most to us, regardless of the numbers .
gearhead440 is offline   Reply With Quote
Old 05-10-2010, 02:04 PM   #2
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Swapping stock plug wires for Granatelli plug wires, P/N 28-1811S: 381hp, 364 ft-lbs. 11hp increase, max torque still around where we started on initial run but torque increase throught the rpm band. Yes, we gained a solid 11hp by changing out the spark plug wires and I can honestly say that everyone there was surprised and pleased at the gains. Cost (from Summit Racing): $130, cost per hp: $11.82 / hp.
Total increase from stock: 19hp, max torque remained the same but the average torque and hp (area under the curve) were increased noticably (~ 15 ft-lbs) across the usable rpm band.
We increased power by 19hp and torque by approximately 15 ft-lbs across the rpm band with our bolt-ons. We can really tell a difference in the sound and performance of the car and are extremely happy with our results and that is what matters the most to us, regardless of the numbers .
I am certainly not here to rain on your Parade or Pop your balloons, but you can NOT do comparison with one pull for each change, you must do 3 to 4 pulls for each condition to verify repeatability.
Your baseline numbers are low due to the fact that you only did one pull,
LS3 cars consistently make between 372 and 378 RWHP fully warmed up, and I stress Fully Warmed up, 195 degrees water temp and 200 degrees Oil temp.
There is 10 hp in the oil temp alone.
I also See Torque dips in your curve this indicates the Knock sensor pulling timing probably due to bad fuel giving inconsistent readings.
I believe that the gains you saw were about 5 RWHP given all my experience with LS3 Camaros and that came from the New Era Tube and NOT the Wires.
Spark Plug Wires don't make HP unless the old ones are BAD, same goes for spark plugs.
Here is what I suggest you do to know for sure.
Do 5 Pulls making sure you get 2 back to back Identical runs with the stock wires then do the same with the aftermarket wires then repeat with the stock wires and tell me what you get.
Stock LS3 with the New Era tube will Make 381 RWHP with Nothing Else this is a fact.
I am sorry but the internet is full of this kind of Poor Data Collection just to sell product to unsuspecting individuals.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
JANNETTYRACING is online now   Reply With Quote
Old 05-10-2010, 02:23 PM   #3
Longhorn SS
Longhorn SS's Avatar
Drives: 2010 IOM Camaro SSRS L99
yeah, what he said. Seriously, Ted showed this to be conclusively true when doing his CAI tests. I hope you're right, but I doubt it.
2010 Camaro 2SS/RS - Roto-Fab CAI, ARH 1-3/4" LTs w/cats, LMR tune, KW V3 coilovers, Pfadt F&R sway bars, end links, rear trailing arms, tie rods, solid subframe bushings, HPS brake pads
Longhorn SS is offline   Reply With Quote
Old 05-10-2010, 06:45 PM   #4
gearhead440
After 2 hours in traffic at 95F temps just to get to the dyno, I would imagine that the car was as warmed up as it would ever get but I certainly not the expert in this field. I noticed the dips also and had 93 octane in the tank. I suppose I can use a different gas station than the one I normally use and see if that makes a difference.
We did three back to back pulls with the stock wires and then did 2 pulls with the aftermarket wires. We did do 2 pulls with the new wires installed, but I didn't mention the first run results because we forgot to connect the computer sensor wire to the spark plug wire - third pull on the graph with no torque value. We broke one stock wire so I'll have to come up with one but I am already planning to take your advise, Ted, and see what the data says. Thanks for your valuable input and I'll post what I have as soon as I get more dyno time. If I understand what you are saying correctly, do 3 dyno runs with stock wires, 3 dyno runs with after market wires, then do 3 final pulls with stock wires, all else remains the same, and compare the results.
There is no rain on my parade - I don't have a king's ransom invested in anything I've done to the car and there are great folks here who lend advise and encouragement. Regardless if it is plug wires and pipe or delta rays from the warp reactor, we still love the power of this car and the number is not what matters the most to us, it is the fun factor !
Thanks again,
GH
Old 05-10-2010, 08:49 PM   #5
STORMTROOPER
STORMTROOPER's Avatar
Drives: White ss/rs auto
When its all said and done that's all the really matter's
TED,
Thanks just for being a part of this site and responding to all the questions and offering all the help that you continue to do. The fun factor of this car is great and I think having this site and people like you and many others adds to the fun factor ten fold.
STORMTROOPER is offline   Reply With Quote
Old 05-11-2010, 07:53 AM   #6
JANNETTYRACING
Thanks again,
GH
I am Really Glad you didn't get defensive and accepted the post as I intended to be educational.
Correct on the Testing proceedure.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 05-11-2010, 09:00 AM   #7
se7en
Drives: 87 Pinto on 32's
Dyno sheet: "STD" numbers may also be slightly different with an "SAE"
se7en is offline   Reply With Quote
Old 05-11-2010, 09:28 AM   #8
ron10
Drives: 2010 2SS IOM L99
thanks ted and jannetty for being on the forum.i always look forward to your input on these threads.i have learned a lot from you.
Old 05-11-2010, 10:03 AM   #9
SK360
Drives: 2005 Pontiac GTO
lol.... as was previously said you gained nothing from plug wires.
Also get those graphs in SAE correction not STD.
SK360 is offline   Reply With Quote
Old 05-11-2010, 12:10 PM   #10
gearhead440
Knowledge is power, truth is unerring and education is fundamental to enlightenment. Those who do not learn from their mistakes are destined to repeat them.
Old 05-11-2010, 07:28 PM   #11
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
well said!
Let me know when you get additional results and based on that new info, I may be interested in new wires, although I couldn't locate a 2010 Camaro SS application for them on the web.
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 05-11-2010, 07:31 PM   #12
topgun1
topgun1's Avatar
Isn't STD the hp and tq data in part based on the particular atmospheric conditions at that exact time the dyno was performed? If that is the case, that to me would be a more accurate representation of power but on the other hand, it's my understanding that SAE (Society of Automotive Engineers for other readers' benefit) is simply a formula for standardization of hp and tq numbers across the board, but does this standardize to certain atmospheric conditions?
that day it was 95-96 degrees and humid. those #'s should increase on a cooler, less humid day theoretically.
Old 05-12-2010, 06:29 PM   #13
Bear2SS
Bear2SS's Avatar
Drives: Black 2SS LS3
Hey guys - I went back to Total Performance early this morning (was about 70) which is 20 degrees cooler than when we were all there. I pulled 560, a pickup of 40 hp. Nothing was different other than the car was cooler and the air temps were cooler. I'd suggest in future to organize another dyno day around cooler weather. Just my 2 cents. Thanks Thomas!
Bear2SS is offline   Reply With Quote
Old 05-12-2010, 08:17 PM   #14
topgun1
topgun1's Avatar
heck yeah Barry! Nice #! I knew with cooler temps and lower humidity you'd pull more! We should all too. By the time I get back there, every day will pretty much be 90s and high humidity!
unfortunately it's hard to predict the weather in enough advance to give folks ample time to plan to go and with the summer approaching it may be a while before we get a cooler day again.
Old 05-13-2010, 08:37 AM   #15
SK360
There is an Uncorrected option, here are the differences I found between SAE/STD
SAE j1349 correction:
29.23 in/hg.
77 degree temp
0 percent humidity
Standard correction:
29.92 in/hg.
68 degree temp
0 percent humidity
That explains why STD numbers are typically a bit higher.
Since I have access to the runfiles from my latest dyno pulls I am able to open them in the dynojet viewer and adjust the correction factors and smoothing to see what the differences would have been.
Here are 3 graphs from my best NA pull.
SAE Numbers:
STD Numbers:
Uncorrected:
Old 05-13-2010, 12:17 PM   #16
topgun1
topgun1's Avatar
thanks for that info SK360, helps alot
Old 05-14-2010, 05:59 AM   #17
se7en
Thanks for showing the difference between the "STD" and "SAE". I think a lot of people need to know this as no dyno is the same.
Good Post!!
Old 05-14-2010, 07:53 AM   #18
R.I.P. jesserayjames
Drives: 2010 IOM 2SSRS
nice
Old 05-21-2010, 08:21 PM   #19
Granatelli
Drives: 2SS Victory Red
Ted.
Just saw this - how could plug wires go bad on a brand new car? - stock wires are 1000 ohm drop per 6inch and Granatelli wires are 0
that is where the power gains come from
Granatelli is offline   Reply With Quote
Old 05-31-2012, 01:10 PM   #20
IMJ
IMJ's Avatar
Drives: 2012 SS LS3 | Silver Frost Metallic
I know that this is an older thread that I'm resurrecting, but what happened here? It just died...
I've been privvy to the "power of plugs and wires" debate since back when Splitfire plugs were in vogue. Why hasn't anyone with access done a real dyno study on this?
Find a dyno
Run the car with stock ignition a few times to find a mean
Run the car with the aftermarket ignition a few times to find a mean
If the numbers don't speak for themselves, then run a significance test between both the list and aggregate values.
I'm really curious for some hard dyno data regarding plug wire changes on this age old debate. The plug wire industry talks about OHMS and whatnot, but wouldn't a dyno and gas mileage test simply be better?
__________________________________________
Ironman John
IMJ is offline   Reply With Quote
Old 05-31-2012, 03:25 PM   #21
axis
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Find a dyno
Sounds like a job for IMJ.
The BIG problem is, any gains you MIGHT get can be attributed to variations from run to run or margin of error of the dyno. If you want to believe there's gains to be had, then by all means buy a set. People spend a lot more $$ on less gains. They do look nice and won't cause a problem, which you can't say about splitfires.
Halltech Yellowjacket fed
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
JRE tuned
Aint nobody got time for that
Old 05-31-2012, 05:36 PM   #22
RiceEater
Drives: 2010 Camaro V8
Still having a REALLY hard time believing that that you're gaining 19hp with plug wires...
RiceEater is offline   Reply With Quote
Old 06-01-2012, 12:14 PM   #23
IMJ
IMJ's Avatar
I hear ya. I'm definitely not a subscribing believer to significant HP gains via aftermarket ignition wires and plugs on modern coil pack cars. But, for all of the claims that the ignition parts makers have made (and modified to be more accurate) over the years, I'd really like to see something empirical here.
I'd be happy to offer my car up as a guinea pig for real dyno tests on this stuff, but truth be told, it should be sponsored by the ignition companies if they really believed in their products. An ignition showdown if you will. I'd be impressed with the first company to step up and take part (MSD, Accel? You guys are industry leaders, how about it?).
Agreed for modern and more recent applications, ya.
Ironman John
Old 06-01-2012, 12:47 PM   #24
axis
axis's Avatar
Would you really trust MSD, Accel, Taylor, etc to post up results from THEIR testing? Maybe the fact that they're not posting up results should tell you something? Independent testing is where it's at. Anything other than that will be shrouded in controversy. The Tornado claims 25% increase in fuel mileage and 10ish hp increase. Splitfire claims 10+% increase in HP and better fuel economy as well. Obviously they did their own testing. Do you believe them as well?
If this were an older vehicle where each plug wire came from the distributor and was 2+feet long, i'd understand that the lowest resistance wires would work best. Our cars have a coil per cylinder and the plug wire is 6in long. I just don't see it.
JRE tuned
Old 06-01-2012, 01:14 PM   #25
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
Power from plug wires is based as much, if not more, upon belief---not fact. Those who believe their wires make more power are going to believe that no matter what. Those that don't believe it are not going to believe--no matter what.
You could make a series of dyno runs on the same day and if you got higher numbers with the Voodoo (insert brand name here) wires the non-believers would say, well, your dyno runs were 30 minutes later and the temperature or humidity was lower/higher, or your oils was thicker/thinner, etc, etc. If the numbers were lower with the magic wires the non-believers would say "I told you so!" and athe believers would say "Yeah but our dyno runs were later/earlier in the day..." etc, etc.
No one is going to be convinced either way. I say if you like the wires spend YOUR money and get them. I got the MSD wires because I like the way they look, they were available and affordable. IN THEORY, I THINK I have a few more horsepower, but I don't care one way or the other.
My 2 cents.
Mods: Pedders Xa's, bushings, braided brake lines, Solution B sway bars, Hawk ceramic pads, Spohn trailing arms, Kooks 1 7/8 LT's, HF cats, Magnaflow 3" cat-back, MBRP rec tips, Cold Air Inductions black CAI, MGW short-throw shifter w/retro shift ball, Showstopper Engine Bling, Forgeline MD3P's 9.5 & 11", Conti DWS 275's & 315's. AAC plasma DRL's.
Proud previous owner of: 1968 327 Camaro, 1972 Camaro SS 350, 1978 Z28, 1979 Z28. 2010 SS is My 5th Camaro
My 5th is offline   Reply With Quote
Scrming's Airaid and Injen Dyno results... scrming Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 212 06-28-2010 03:28 PM
Magnuson install at RPM motors dyno results tlamb2 Forced Induction - V8 8 04-06-2010 07:32 PM
Vararam, Kooks, SLP UDP, 160 stat and FlowMaster Dyno results inside! litle88 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 36 03-28-2010 10:16 PM
Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 47 09-06-2009 03:36 PM
Dyno Results on L99? pharmd Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 05-12-2009 10:53 PM
