Cold Air Inductions
Old 05-11-2010, 04:26 PM   #1
ducq
ducq's Avatar
Drives: 2010 Camaro 1SS/RS LS3 blck w/ IOM
Unhappy Delete Resonators with X-pipe?
Hello I'm new to camaro5 but have been lurking since I got my 2010 camaro 1SS LS3. I recently put on some borla S-type axle back exhaust on my babygirl and the tone is nice but I was expecting just a bit more of a meat eating sound to it. I now regret not going with the full catback cause the YouTube videos I've seen sound very nice. I was lead to believe there is no difference in sound between the catback vs axle back other than hp gain.
Okay stay with me now
Well I live in California so I can't remove my cats. Borla suggested I buy their x-pipe setup which would give me the piping for my axleback to become what it would have been had I thrown on the catback exhaust but it costs almost 700 bucks! I've read that the resonators act as mid mufflers and tone down sound and raspyness (not as much as the L99 but they do). So I'm thinking, would I be able to put on a magnaflow 2.5" x-pipe and delete resonators with just straight pipe? would that give my exhaust a bit more growl? and would there be problems with magnaflow metal going on borlas 304 stainless steel metal, or would the 2 be far from each other that they wouldn't touch? Sorry I just want my exhaust to sound throatier and not like a BMW!(YouTube 2010 camaro s type axle back)
please don't jack my thread with intake questions I see that happening a lot haha
ducq is offline   Reply With Quote
Old 05-11-2010, 08:43 PM   #2
96rss/ls6
Inferno is the only color
96rss/ls6's Avatar
Drives: 96 ls6 camaro, iom 2ss/rss /
I dont think many people are responding here because of all the variables going on here. The s type is definately quiet. As far as the x pipe sound it will change the sound, but it sounds to me like you are really just looking for more volume. The resonator delete may give you a little more sound. And cuttting off the rear set of cats would probably give you a little more. But I would suggest finding the sound you want and then try to trade with someone in the classified forums that wants there car more quiet.
96rss/ls6 is offline   Reply With Quote
Old 05-11-2010, 10:37 PM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
I would probably have to agree with this.
You're probably better off selling your axle-back for 50%-60% of what they go for. Then use that money to buy either the Magnaflow Comp 2.5" cat-back or the SOLO Mach X. Both of these are basically a resonated x-pipe with a muffler delete.
You can get the Magnaflow from MagnaflowPlus.com for about $650 shipped if you call them (don't go by their web site prices). For the SOLO you'll have to buy from them for about $750 shipped.
Do a search on the forum for both of these systems. There is plenty of info and videos out there.
Build Journal
Old 05-12-2010, 12:07 AM   #4
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
Just for your reference, I just did the X-pipe w/ resonator delete on my car this last sunday...
The thread is here: http://www.camaro5.com/forums/showthread.php?t=82032
I went with the Dynomax Axleback, hoping it would be louder, BUT I had to go a little farther. Deleting the resonators didn't make a HUGE difference, but it is noticeable, probably more in person than on the videos. Deffinitely louder under load.
There is a before the X-pipe and resonator delete, and an after X-pipe and resonator delete video, both with the axleback installed. I don't have a video of stock. Check it out, maybe it will give you an idea if doing the x-pipe & resonator delete is enough.
I pretty much did mine myself for $111 dollars. If your axle back is like mine, it doesn't go past the front of the axle, and you still have factory pipe. Look into the Edelbrock 6717 setup ( http://www.summitracing.com/parts/EDL-6716/ ), you have to cut your factory pipes, but I think it would probably work fine with your borla axleback, and not hurt your wallet. Unfortunately, I built my setup before I ever knew this Edelbrock piece existed.:-/
Jason@ is offline   Reply With Quote
Old 05-12-2010, 02:26 AM   #5
ducq
ducq's Avatar
Yea sorry for my jumbled up post, i wrote it up on my iphone while in my work truck on break. I just have so much running through my mind about my car! haha i spend all my off time looking up parts and skimming through these forums. Well i don't think ill be removing my borla axle backs to sell them, i just want to modify them a bit. I do like the tone they have, i just want to add a bit of a raspy growl to it.
i can notice the difference between the two racnjsn. It did pick up just a bit more of a chunky rasp to the exhaust. It's just about the same change in my exhaust im looking for, perhaps a better quality X-pipe might give just a bit more? i don't know if different metals and slightly different shapes to the X-pipe make a difference.
Old 05-12-2010, 07:44 AM   #6
Edrock
Edrock's Avatar
Drives: '10 Camaro 2SS LS3
Check out the clips in my sig for some samples. Not apples to apples but gives you some idea of resonator delete. I'd say go for it. I'm glad I did. You should be able to get a local muffler shop to do this for a fairly good price. Good luck.
DT Shorties, Solo hi-flow Cats, X-pipe, resonator delete, Flowmaster Super-44s, VMAX TB, Stronger MAF, C.A.I. Intake with race scoop, and JRE Tune!
WOT is my happy place!!
Edrock is offline   Reply With Quote
Old 05-12-2010, 07:50 AM   #7
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
Im lost..
AlSuwaidi is offline   Reply With Quote
Old 05-12-2010, 11:34 AM   #8
Jason@
If I could do it again, I'd get the edelbrock piece. I think it's the only one available that I've seen that replaces the H pipe with an X and deletes the resonators in one shot, and if there is more, the edelbrock one is probably the easiest on the pocket book. Unfortunately, i'd never seen it advertized, and didn't know it existed before I built mine.
Old 05-12-2010, 11:55 AM   #9
longbeachss2010
longbeachss2010's Avatar
Drives: black SS
JUST GET AN X PIPE. AND GET WHAT U NEED. I GOT STARIGHT PIPES NO RESO. ND NO X PIPE.
longbeachss2010 is offline   Reply With Quote
Old 04-04-2011, 05:48 PM   #10
miSSouri_5
miSSouri_5's Avatar
Drives: 2010 CGM Camaro 2SS RS
I just put on Flowmaster Axle-back exhaust. Good for now, but I can see replacing resonator with the Edelbrock X-pipe in the future.
2SS/RS Cyber Grey Metallic/Black Interior, Auto, Sunroof
Purchased 3/20/2010
Mods so Far: - Tinted windows - Molded Quarter Flares - cgm vinyl bow-ties - weathertech dig-fit floor liners
COMING SOON: Catback Exhaust - Painted Stripes (gloss black) - tinted brake lights/side markers
miSSouri_5 is offline   Reply With Quote
Old 07-26-2011, 04:43 PM   #11
SS>GT
SS>GT's Avatar
Drives: 2010 Camaro SS
That X-pipe is no longer available from summit racing. Do you know of anywhere else to get it?
2010 camaro 2ss LS3
Corsa catback exhaust w/muffler delete, hennessey intake, Pfadt springs, Hurst Short throw Shifter, Murdered black.
GO TEAM LS3
SS>GT is offline   Reply With Quote
Old 07-26-2011, 05:53 PM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There are several other companies that make X pipes. Depending on what you want, the prices vary. Magnaflow makes a universal 2.5in True X pipe for around $75 that works great and fits perfectly. It's a weld in piece though, unless you want to put a bunch of clamps in a small area.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-26-2011, 07:15 PM   #13
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
I ordered my x-pipe from Heartthrob. A very good fit and sound. It was $105 and my local shop welded it in for $48.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - Granatelli Brake Lines - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
Camaro_Custom_Painted is offline   Reply With Quote
Old 10-18-2011, 10:48 PM   #14
SS_Matt
permagrin
SS_Matt's Avatar
Drives: 2012 LS3 SS/RS
I have the Flowmaster Outlaw axleback. It's definitely loud enough, but I'm wondering what an X pipe like this would do for the tone.
Can someone describe the difference in tone?
Also... in that pic- how does the welder weld the top of that pipe when it's up so close to the car?
Thanks for any feedback.
2012 Black on black SS RS LS3
SS_Matt is offline   Reply With Quote
borla, delete, exhaust, magnaflow, resonator
muffler delete with xpipe and no resonators, first imprseeions caper Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 07-05-2011 05:41 PM
SLP 3 inch Mid pipe & Muffler delete Video linkwpc Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 08-02-2010 04:54 PM
Finally,... Video Of My Camaro 2SS Muffler, Resonators, H-Pipe Delete & AirAid Intake Black LS3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 02-07-2010 08:37 PM
Exhaust Theory revisited Wacker Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 11-23-2009 11:12 AM
Muffler delete and x pipe installed..... AVman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 10-29-2009 05:23 PM
