Cold Air Inductions
Old 05-11-2010, 07:08 PM   #1
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
People that have changed/modified exhaust.
I had my QTP exhaust cut outs intalled a few weeks ago and I love them. On another thread I read that some exhaust mod's can negatively effect your low end power (< 2000RPM) over the stock exhaust system.
I can verify that there does seem to be a difference with the cutouts completely open -vs- closed when I hit the gas hard after letting the clutch out in 1st gear. When I have the cutouts open there seems to be a slight hesitation, and just not as much power when I accelerate hard.
I don't know what the actual HP or performance reduction is but there is certainly a difference when opened -vs- closed. Is this something that is specific to exhaust cutouts or is this the same with other systems like Borla, Loud Mouth, etc?
Anyone that is considering modifying/replacing the stock exhaust may want to know how performance can be affected.
Russ
OHIOSS is offline   Reply With Quote
Old 05-11-2010, 07:12 PM   #2
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
I think it has to do with back pressure I think this would be more suited in one of the V8/V6 threads!!!!
Gotthat02fire is offline   Reply With Quote
Old 05-11-2010, 07:32 PM   #3
Maurdib
Maurdib's Avatar
Drives: 2010 Black Camaro 2LT/RS Auto
Russ
Check out he V8 Bolt on Forum
BackInBlack
Performance:Vararam cold air intake
Maurdib is offline   Reply With Quote
Old 05-11-2010, 07:33 PM   #4
OHIOSS
Russ
Thanks for your recommendation to move this post but I have not had good luck in getting any responses when I post in the other forums, but thanks for your concern.
Russ
Old 05-11-2010, 07:38 PM   #5
OHIOSS
Russ
OMG, moderator please move this post to the V8 add on forum. I think i have inadvertently upset some members for posting this in the open forum. I didn't realize we had so many forum monitors!
Old 05-11-2010, 07:42 PM   #6
gomezcorp
gomezcorp's Avatar
Drives: 2011, Summit White, Inferno Orange
Does anyone know if Borla ran a decibel reading test in the interior of the 2010 Camaro for the Touring, S-Type, & ATAK exhaust system? And if so what were the readings? Thanks
gomezcorp is offline   Reply With Quote
Old 05-11-2010, 07:48 PM   #7
tangorover
tangorover's Avatar
Drives: 2010 Chevy Camaro 2LT Summit White
The other forums take a little bit longer since they don't have a lot of traffic. But eventually you will get a lot more meaningful replies by people who actually know what they are talking about.
Dont loose faith!
tangorover is offline   Reply With Quote
Old 05-11-2010, 07:49 PM   #8
tangorover
tangorover's Avatar
Also These forums get a lot of noise like the person asking about decibel readings
Old 05-11-2010, 08:52 PM   #9
Mark Myles
Mark Myles's Avatar
Drives: 2010 2SS/RS IBM / Silver Stripes
LMFAO.......
M
Mark Myles is offline   Reply With Quote
Old 05-11-2010, 10:22 PM   #10
mulletman
Drives: 2017 Camaro SS
Search is your fiend.
mulletman is offline   Reply With Quote
Old 05-11-2010, 11:17 PM   #11
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Hooked on fonix worked for meeee...
sorry couldn't resist...
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 05-12-2010, 12:59 PM   #12
lol
Old 05-13-2010, 10:38 PM   #13
jbdj89
Drives: 2010 black ss rs
magnaflow
I had a magnaflow straight pipe mufflers installed with x-pipe and kept factory pipes....the sound is killer not too loud..and my acceleration is a lot quicker. checkout lousplymouth.com to see the system i had installed by them. They are in plymouth mass.
jbdj89 is offline   Reply With Quote
Magnaflow Stainless Steel Exhaust @ Phastek Performance Jason@Phastek Performance V8 Bolt-Ons & Tunes 2 01-28-2011 03:23 PM
Help with poor fitting ARH exhaust Johnyoder Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 04-19-2010 07:49 PM
EXHAUST Milk 1027 Wiki 2 03-07-2010 10:20 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
November Month Special on 2010 Camaro Corsa Exhaust GmPartsDirect.com V8 Bolt-Ons & Tunes 0 11-01-2009 12:46 PM
