sjm autoprod
Old 05-11-2010, 09:54 PM   #1
BlownSS
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
O2 Sensor removal confusion
i am going to be installing my new Kooks headers in the next couple of days. I have been doing alot of research and i have found that most peeps are in 100% agreement that i need to use a penetrating oil and a pattern of screwing in and out (not a pun.......but funny) while adding some penetrating oil. The confusion is whether to do it while the exhaust / bung area is warm or cold. I dont want to destroy them when i remove em......Thoughts?
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 05-12-2010, 07:14 AM   #2
Russell James
Russell James's Avatar
Drives: two 5ths and a 1st
I cracked mine loose while hot right after a drive. They popped right loose and turned out by hand. The day before I put a little penetrating oil on them.
Heat normally helps things loosen.
If they weren't cross threaded when put in, they should spin right out easy after cracked loose. A cresent wrench was all I needed.
Old 05-12-2010, 08:06 AM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Originally Posted by Chief Blackhawk View Post
Just take a wrench and loosen it. Its not magical and its not a 10yr old car. They come right out.
There are numerous people that would disagree with you. They SHOULD come right out but several have had to buy new ones.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-12-2010, 08:15 AM   #4
se7en
Drives: 10 Procharged SS
Mine were soaked for 2 days with oil....try it...nothing. Got a torch, heated it... nothing.
Finally heated the shit outta it and while someone else cranked.... out it came!!
Good Luck!!
10 Camaro: Built 376, LSA Heads, BTR valve train and Stage III Camshaft. F1A 12 Rib-3.75 pulley (17psi), Squash Dual Fuel System with Return (Dual Walbro 450LPH on a Hobbs Switch), Aeromotive regulator, Holley Fuel Rails, ID1300's. RMVB 4L80, 4K Stall, and Trans-brake. 9" IRS, 3.50 gears with a full spool
se7en is offline   Reply With Quote
Friends and Family Discount Confusion RB43TD Camaro Price | Ordering | Tracking | Dealers Discussions 7 02-15-2010 05:26 AM
shift knob/shifter confusion larietrope Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 01-05-2010 07:22 PM
VIN Confusion 5thGenCamaroChick 5th Gen Camaro SS LS LT General Discussions 13 10-03-2009 02:17 PM
Confusion on RS rims llevan22 Wheels and Tires Talk Sponsored by The Tire Rack 10 05-26-2009 08:33 PM
V6 Super/Turbochargers. Much Confusion! SemperFi Forced Induction - V6 25 04-26-2009 08:29 AM
