Old 05-12-2010, 05:24 PM   #1
CaliEMT
Decepticons. . . MOBILIZE
CaliEMT's Avatar
Drives: 2010 2SS/RS Black
Yank 3200?
So I have an L99, and I was recommended a LS3 Cam Conversion kit (w/ Cam, what size please advise) with a "Yank 3200". I have no idea what all this means (especially the Yank part), and I dont know where to begin a search even.
Im intersted in a Muscle car idle with sustained drivability also @ freeway speeds. I dont want those surging issues coming with big cams I hear about. Horsepower is a goal but not my primary.
CaliEMT is offline   Reply With Quote
Old 05-12-2010, 05:28 PM   #2
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
yank is a brand of torque converters. the 3200 stands for the stall rpm that the torque converter begins to transfer power to the wheels. so when you stomp on the gas, the engine jumps to that rpm and you start hauling ass! the stock torque converter stall speed is only 17 or 1800, 3200 is probably the highest you can go without screwing with driveability on the street.
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
Old 05-12-2010, 05:51 PM   #3
silverfox
silverfox's Avatar
Drives: 2010 camaro ss
I have the Yank ss3200 in my l99 car and it's great on the street or strip. It will have to have more rpm to get moving on the street so you will burn more gas. But damn if it don't raise hell on the strip. I would recommend you get used to it before installing a cam.
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles.
Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump.
907rwhp.
silverfox is offline   Reply With Quote
Old 05-12-2010, 05:56 PM   #4
I want a stall
Old 05-12-2010, 05:58 PM   #5
SSyanide
Drives: 2010 Camaro SS/RS
Alot of times a converter is used to decrease the "surge" from an aggressive cam when driving the car( when you're at a light or stop, it'll want to lunge forward a bit with an agressive cam), it'll also provide you with the means to a much improved 60ft if you drag race it. I'd suggest with any converter that you go with a trans cooler as well...it's cheap insurance for these expensive transmissions.
I want a stall converter too...
SSyanide is offline   Reply With Quote
Old 05-12-2010, 07:21 PM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I hope you have a nice chunk of change for all this cause you're gonna need it. The LS3 swap isn't cheap. What are your goals for this car? If you just want more power, there are a few good VVT cams out there for the L99. The Stall isn't necessary unless you have some big plans for it. Gears would be a better investment at the start.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-12-2010, 08:40 PM   #7
CaliEMT
CaliEMT's Avatar
Well they want 1450$ for the LS3 Conversion Cam Kit. Comes with everything for the swap.
They didnt price the yank 3200.
I plan on Supercharging . . . . I meam like a year down the road though AT least!
Old 05-13-2010, 07:53 AM   #8
SRTM4
Drives: 2010 SS Camaro black
A converter is probably the best thing that you can do to an auto SS other than forced induction.
For ther street 3200 is probably the highest I would go. I just installed a 2800 PI converter in my car and it made a nice difference.
If you are going to install a cam you will want a higher stall converter. It will keep you in your powerband. With just about any cam you are going to lose some botton end torque. The converter will get you in your sweet spot of the cam coming on power.
Every Auto car shoould do a higher stall converter. This will close the gap with the 6 speed cars.
SRTM4 is offline   Reply With Quote
Old 05-13-2010, 07:57 AM   #9
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
i had no idea wha they were ... im glad i read this thread.. learnt somethin new!
AlSuwaidi is offline   Reply With Quote
Old 05-13-2010, 08:13 AM   #10
SSRS Steve
Drives: 2000 Z28
A yank 3200 would be a good first mod and get a tune
SSRS Steve is offline   Reply With Quote
Old 05-13-2010, 09:35 AM   #11
SC2150
A trans cooler is a must on any converter swap.....and a good converter will lower your ET by .5-.8 seconds with no other mods, so it is one of the best bangs for the buck.
The FTI/RevXtreme Performance & Engineering is probably the absolute best you will ever find and is less than $800 for the billet unit. The 3600 drives like near stock on the highway and around town until you hit it, and then you right in the powerband instantly.
The FTI feels like a 3200 or less when driving normal and we have yet to break one in the years we have been using them. PM me if you want a quote.
Old 05-13-2010, 12:59 PM   #12
toehead93
Drives: 2014 2SS/1LE
Consider reading these two threads before you do an LS3 conversion.
http://www.camaro5.com/forums/showthread.php?t=80797
http://www.camaro5.com/forums/showthread.php?t=82272
The only bad part of the L99 is the DOD/AFM lifters. The VVT is good if you get the right cam spec'd out. It will help reduce surging and keep more power under the curve than an LS3 with the same cam. The stock L99 lifters is keeping the engine from revving higher therefore replacing them is a good idea.
Someone mentioned gears...IMO good option for an M6 but for the same price as a converter I'd get the converter, until gear prices drop to normal pricing.
Your converter should match your cam. There are two types of converters too. Yank is a single disk and there are multiple disk converters too. The single disks cannot be locked at WOT like the stock multidisk but there are sometimes tuning issues with the multidisk. I persoanlly will get a multidisk converter at a later date. This is a good start for converters:
http://www.camaro5.com/forums/showthread.php?t=37093
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 05-13-2010, 02:28 PM   #13
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via AIM to WheelmanSS
You want to pick your stall speed based upon the appropriate RPM range of your power curve. A 3200 stall on a stock car is a little high for my taste. If you car makes power at higher RPM, you will want a higher stall speed than a cam that makes more low end torque.
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ
- Vortech V3 Supercharger
- Kooks Stepped Headers, Magnaflow 16580
- Suspension by Pfadt, Hotchkis.
2007 Trailblazer SS- Sold
2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold
1994 Camaro Z28 - Sold
WheelmanSS is offline   Reply With Quote
Old 05-13-2010, 02:35 PM   #14
toehead93
Exactly, just because you have a cam doesn't mean you need a really high stall. I had too big of a stall on my old LT1 for the cam I had. I never got to use all the low end torque it made.
2010 2SS A6 - sold.
my oh my.. L99 burnout with yank torque converter installed DanD V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 75 06-12-2010 06:42 PM
Tempted to yank it out of storage tommygun6644 5th Gen Camaro SS LS LT General Discussions 48 01-20-2010 07:46 PM
Yank Converters bad55nomad Tuning / Diagnostics -- engine and transmission 2 11-15-2009 04:21 PM
Now taking Orders, SLP TVS 3200 Supercharger System,Special Camaro5 Member Pricing jeff@allusa Forced Induction 6 10-19-2009 10:53 AM
Now taking Orders!!! SLP TVS 3200 Supercharger System! Same technology as the ZR1! Kris@BMCPerformance Forced Induction 10 08-13-2009 03:28 PM
