Old 05-13-2010, 06:14 AM   #1
FB3
FB3's Avatar
Drives: 2014 Camaro 2SS RS LS3, BRM, NPP
Solo Mach X After Further Review
I installed the Mach X cat back on my SS manual a week ago and was quite pleased with it as I said in my previous post on this subject.
However, the drone on expressways around 70 - 75 mph, 1750 - 2100 rpm, is quite bad to me. At first I thought it was because the back seat was down. I raised it which helped a little, but that drone is just oppressive to me.
It is a shame because it sounds so good in all other regimes. However, I spend a good portion of my driving during the week on the turnpike, so I just don't think that I will be able to tolerate it long term. Even trying fifth gear at that speed does not help much inside and it also hits that frequency during upshifts for the brief time that it is in that power band.
Anyway I think that I am going to take it off and try a Flowmaster American Thunder cat back. They are not supposed to be too loud nor drone but have good sound. "Supposed" being the key word.
Thankfully I saved my stock system intact, so if all else fails I can put it back on. Hope it doesn't come to that, but I am not willing to endure the discomfort of resonance in my car. This could turn out to be one expensive experiment.
Experience is the best teacher but the tuition is very high.
FB3 is offline   Reply With Quote
Old 05-13-2010, 07:04 AM   #2
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
ahh.. at least theres a good market for used exhausts out there.. hope you dont loose to much on the sales
AlSuwaidi is offline   Reply With Quote
Old 05-13-2010, 08:40 AM   #3
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
I don't seem to have much drone at all at 70-75 in 6th gear! In fact it's downright quiet! Are you sure all your clamps are tight, maybe a leak somewhere? The only time mine even approaches a drone is in 4th or 5th gear around 1800-2000 mainly when laboring the engine going up a slight incline or depressing the throttle lightly to gain a little speed, otherwise no issue with drone at all! I hope you are able to resolve the problem! Have you called Steve or Jeff at Solo?
Not a Camaro but it works for now!
ssmike is online now   Reply With Quote
Old 05-13-2010, 08:48 AM   #4
camarohead
camarohead's Avatar
Drives: 2010 ss rs ls3 red-white rallys
has anybody with the mach x added headers yet? would love to hear that sound.
camarohead is offline   Reply With Quote
Old 05-13-2010, 08:50 AM   #5
camarohead
camarohead's Avatar
ok, found the video.
Old 05-13-2010, 09:16 AM   #6
ron10
Drives: 2010 2SS IOM L99
sorry to hear.
Old 05-13-2010, 09:23 AM   #7
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
Hello,
There are a few things you should check before you remove the system. A few have experienced drone due to a few reasons:
1. Check all clamps for leaks...we recommended re-tightening all clamps after about 500 miles of driving, as they will expand upon initial heating during the break-in period.
2. Check the clearances between the exhaust and the body of the car. If the clearance is not enough, you will get more noise in the car.
3. Make sure your heat shield is on tight. The bolts have come loose on many cars, and a loose heat shield can transfer sound into the car.
4. Make sure the tips are not recessed inside the fascia, and not too close to the fascia. we have seen from other cars that this makes a huge difference.
5. If none of this works, we have QR resonators that would take care of any noise in that range. Check the abive and if they do not work, give Jeff a call at 905-703-1557 and he will work with you to correct the problem.
Steve
GOINGSOLO2 is offline   Reply With Quote
Old 05-13-2010, 09:24 AM   #8
RobertHarriSS
RobertHarriSS's Avatar
Drives: 2SS/RS M6
Mat your trunk with a product like Fatmat, Hushmat, or Dynamat. It will quite things down for you.
RobertHarriSS is offline   Reply With Quote
Old 05-13-2010, 10:50 AM   #9
FB3
FB3's Avatar
Thanks for the responses. I only have about 100 miles on it now and plan to get under it tomorrow and check all clearances and clamps.
Tips are definitely not recessed. Strange thing is the condition does seem to fluctuate, so hopefully there is something loose or too close to the structure. Will definitely check and update when I do.
Old 05-13-2010, 12:00 PM   #10
3GPa
3GPa's Avatar
Drives: SOLD/2SS/RS Painted Rally Stripes
Ditto...
I used Dynamat and it made a big difference!
3GPa is offline   Reply With Quote
Old 05-13-2010, 12:03 PM   #11
I thought the drone was because of the AFM on the L99's.
Old 05-13-2010, 12:06 PM   #12
bobby35ny
bobby35ny's Avatar
Drives: 2017 ZL1 M6, bye 2013 ZL1, 2010 SS
I ripped out the GMPP cans due to Drone.
If Drone bothers you just get a Corsa and put it to bed.
NO DRONE!!
-Bobby
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 05-13-2010, 12:15 PM   #13
FB3
FB3's Avatar
I had a Corsa cat back on my G8 GXP and really liked it, but thought I would try something a little deeper for the Camaro.
Exhausts are like colors. Some like red, some like blue, etc. I am going to try all of the suggestions here before I pull it off.
I am sorry that I didn't call Solo first, but did not think that it was their fault nor that anything could be done. Now I see there are possibly some remedies. I do not like to complain about a product before I give the manufacturer ample time to try and fix it, but this is most likely just a case of my personal preferences.
GROUP BUY- Mach XL V6 (Manual) and Mach XLT V6 (Automatic)- Ends 11/30/09 GOINGSOLO2 V6 Bolt-Ons & Tunes 252 10-20-2011 09:33 PM
My Solo Mach X to Corsa Review Read On! 55Designs Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 07-11-2010 10:35 AM
SOLO Performance Camaro Exhaust Sound Clips Compilation GOINGSOLO2 V8 Bolt-Ons & Tunes 29 04-11-2010 09:11 PM
Solo Mach X Review mikey8 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 03-10-2010 11:02 PM
Solo Mach XLT Review mikey8 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 41 01-09-2010 01:41 PM
