Caryle Racing
Old 05-13-2010, 10:15 AM   #1
Bowtie Junkman
Bowtie Junkman's Avatar
Drives: 2000 Camaro SS
Chatter at start up ...
Hey guys (and gals) ...
Anyone else getting that chatter (sounds like coming from the valvetrain) for 1-2 seconds at start-up when cold?
I've had (2) other vehicles with LS2's (C6 and TBSS) and I seem to remember them doing the same thing ... but I thought it got better as time went on ... I'm at 2500 miles now and I think it's gotten better, but definitely still there ...
I thought I remembered someone stating at one time on the Corvette forum it had to do with the LS motors having floating wrist pins ... ???
Anyone else experiencing this and anyone with the explanation?
Thanks!
Bowtie Junkman is offline   Reply With Quote
Old 05-13-2010, 11:12 AM   #2
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
i hear it too, everybody keeps saying it is normal
trudawg660 is offline   Reply With Quote
Old 05-13-2010, 11:42 AM   #3
Dave2SSRS
Dave2SSRS's Avatar
Drives: 2010 Camaro 2SS/RS
I have it as well... assumed it is normal
2010 Camaro 2SS/RS
Imperial Blue | Grey two-tone Interior | Silver racing stripes | Magnaflow Comp Cat-back | CAI intake | Elite Engineering Tunnel Brace |
Richmond (Houston), TX
Dave2SSRS is offline   Reply With Quote
Old 05-13-2010, 11:52 AM   #4
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
It's the lifters that bled down.
At shut off, some valves are open = valve spring pressure against the lifter. After so much time, that lifter may bleed off it's oil. Then at start, those couple lifters that bled down go tap tap tap for a few seconds until they get oil pressure.
Plus every lifter to lifter bore fit might be a hair different. If the engine just happens to stop with a lifter up on the cam lobe that has a hair looser fit, over a day or two that one may bleed down. Whereas a real tight lifter might sit up on the cam for weeks without bleeding down.
Harley's do the exact same thing, and they use SBC roller lifters too. Every once in a while an HD will be a biotch to start because one or more of the valves isn't opening much due to the lifter bleed down. With only two cylinders its a much bigger problem when one of the valves decides not to open while cranking.
All the LS engines I've had over the year do it, so I wouldn't sweat it. Even my 5.3 truck engines have done it, and they use lighter valve spring pressure.
Old 05-13-2010, 11:55 AM   #5
ron10
Drives: 2010 2SS IOM L99
mine does it also.usually when it has set for a couple of days.if the car is still warm,it does not do it.
Old 05-13-2010, 02:49 PM   #6
Parker70
Parker70's Avatar
Drives: 2010 IOM 2SS/RS IO int, A6
My car has done it since it was a couple of weeks old. I read the threads on here and wasn't very concerned, but took it to the dealer anyway. They couldn't recreate the problem, so I eventually took some video and e-mailed it to them. The technician said nothing to worry about, but they were going to have the service manager and GM rep. listen to it and get back with me. That was about 2 weeks ago. Still waiting.
Parker70 is offline   Reply With Quote
Old 05-13-2010, 03:29 PM   #7
HaZe_X
HaZe_X's Avatar
Drives: Trailblazer SS & Camaro SS
Piston slap? My LS2 does it when cold, as does the LS3
2010 Camaro 2SS/RS/LS3 -Black on Black - Kooks 1-7/8 Headers, Dyno Tuned, ADM Race CAI, QTP Cutouts, Hurst Short Throw, SJM Line Lock, Alpine PDX 1.1000, (2) Alpine Type R's, ...Soon to be cammed!
HaZe_X is offline   Reply With Quote
hard to start, when warm? buelldude Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 52 07-26-2016 05:46 PM
Remote start heated seats. Does it work? rodimus prime 5th Gen Camaro SS LS LT General Discussions 80 01-05-2010 02:44 PM
sputtering for 5-10 sec after a cold start (LS3) rcracer78 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 10 12-13-2009 09:40 PM
Rough Engine Start After Tune? Tanner Tuning / Diagnostics -- engine and transmission 9 10-08-2009 01:25 PM
