Old 05-13-2010, 01:43 PM   #1
Mike@RMCR
Mike@RMCR's Avatar
Drives: Supercharged
Edelbrock E-Force Dyno
So here is a pic of the last Edelbrock E-Force on a 2010 SS LS3. The kit install was fairly simple except for the fact that Edelbrock miss machined the valley cover and we had a massive oil leak.
After pulling the supercharger off and re machining the cover on my mill here are the #'s we got. This is with a pulley one size smaller and a custom tune. All in all this is a great kit and actually like the fit better than some of the other positive displacement supercharger kits.
This was with about 9lbs of boost, ARH Headers & Exhaust.
Mike@RMCR is offline   Reply With Quote
Old 05-13-2010, 01:53 PM   #2
2010SSRSM6
2010SSRSM6's Avatar
Wow! Nice torque spike!
Old 05-13-2010, 01:55 PM   #3
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
ncie numbers. I'm going to have the same mods soon, but I think I'm going to stick with 7 psi. hoping for 570/500 ish.
Old 05-13-2010, 02:04 PM   #4
bilydean
bilydean's Avatar
Drives: One of the rare ABM camaros
How did you catch the mis-machined valley cover? before or after the install?
I hopefully have one of these coming and wouldn't know what to look for on the cover, so looking to your experience to see what to look for.
thanks
Dean
2000 5/23
3000 5/27
3400 6/20 TPW of 6/29
3800 7/3
4D00 7/8 interned at QC
4B00 7/16 Released from QC
4200 7/20
8/5 We picked up the car
bilydean is offline   Reply With Quote
Old 05-13-2010, 02:13 PM   #5
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
Mike, this is a very handsome numbers. If that same car would have dynoed at sea level, say Florida, would those numbers be higher or lower?
Z_Rocks is offline   Reply With Quote
Old 05-13-2010, 02:52 PM   #6
toehead93
Drives: 2014 2SS/1LE
If it is SAE corrected it won't matter where it is dyno'd.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 05-13-2010, 02:58 PM   #7
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Maybe a stupid question...is that corrected for flywheel hp, or are we looking at rwhp on that graph?
Old 05-13-2010, 03:09 PM   #8
ron10
Drives: 2010 2SS IOM L99
that should work just fine.
Old 05-13-2010, 03:21 PM   #9
NHSS
NHSS's Avatar
Drives: 2010 2SS/RS M6
No problems with fuel? Or did you install a BAP? Nice #'s!
NHSS is offline   Reply With Quote
Old 05-13-2010, 03:29 PM   #10
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
now that is what I call some down low torque
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 05-13-2010, 04:38 PM   #11
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
RWHP
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 05-13-2010, 07:15 PM   #12
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Very Lucky that this is my build...............Car runs fantastic, RMCR guys did a great job with it....
The mis-machined valley cover issue was found just before car was put on final dyno( good thing)
Fuel was good throughout up to 6600rpm with no tale off.
More pics and base dyno graph will be up shorlty here and on my journal page.
http://www.camaro5.com/forums/showthread.php?t=33889
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 05-13-2010, 08:14 PM   #13
bilydean
bilydean's Avatar
Teddy,
How did they determine the valley cover was mis-machined? Is it something you can visually determine? The reason I ask, is in theory, I have one getting ready to ship and I want to know if I can visually see the problem before I install.
thanks
Dean
2000 5/23
3000 5/27
3800 7/3
4200 7/20
Old 05-13-2010, 08:27 PM   #14
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Notice a leak on the ground before pulling up to dyno, put on lift and followed from there. Determined that it needed to be tapped further for a tight secure fit.
Roto-fab CAI dyno results Roto-fab 1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 102 07-30-2016 08:21 PM
Edelbrock E Force Supercharger Issue PJ droopy pants Forced Induction - V8 27 01-10-2011 09:21 AM
Edelbrock E Force Supercharger Installed GPC1 Forced Induction - V8 15 05-03-2010 10:21 AM
Edelbrock E-Force Blower on Dyno & Road (video) Hennessey Performance Forced Induction - V8 31 04-20-2010 03:56 PM
E force dyno results Caliman93230 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 04-15-2010 11:16 PM
