sjm autoprod
Old 05-13-2010, 09:31 PM   #1
c6vettepilot
c6vettepilot's Avatar
Drives: Victory Red/Black
L99 VS. LS3
I realize the LS3 is paired with the 6 speed manual and the L99 is with the automatic. What is the difference between the two engines? I have the automatic. I just installed the Borla axle back S-type exhaust. The sound is driving me crazy when I'm cruising along and it shifts between 5th and 6th gears.......It makes a sputtering, drone sound as I speed up and slow down....I was told by Borla that I would need to install at least the X pipe to get the better sound. Do I need to go with Headers, also?
I have a C6 Vette with the LS2 and 6 speed, plus Dynatech Supermaxx headers and B&B exhaust...great sound.
Again, what is the difference between the two engines? And, any advice on why the automatic sounds so strange?
c6vettepilot is offline   Reply With Quote
Old 05-13-2010, 09:43 PM   #2
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
L99 has AFM (active fuel management) which annoyingly changes the engine parameters to run on 4 cylinders to save gas at 'cruising' speeds, although it comes on much earlier than people want. It also has slightly less hp at 400 vs. the LS3's 426.
the sound you might be getting is the AFM kicking on and it's not going to be a throaty V8 sound. Otherwise, I'd go with installing the X pipe and headers.
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 05-13-2010, 09:51 PM   #3
3BVert
3BVert's Avatar
Drives: 2010 Camaro 2SS/RS
I agree. It's AFM. If you're not worried about "potential" warranty issues, get a tune and turn it off or use a handheld like the DiabloSport Predator. I turned mine off and bought the Corsa LS3 exhaust and it's awesome!
2SS/RS Red Jewel Tintcoat
6-Speed Automatic
3BVert is offline   Reply With Quote
Old 05-13-2010, 09:57 PM   #4
ron10
Drives: 2010 2SS IOM L99
probably the biggest difference in the two engines is the cam.
Old 05-13-2010, 10:03 PM   #5
topgun1
topgun1's Avatar
Old 05-13-2010, 10:11 PM   #6
5thGenOwner
5thGenOwner's Avatar
Drives: '10 SS & '15 FRS
If you got the money... I'd do that for sure! But tuning out the AFM will solve your basic problem. You'd probably need a tune after getting headers anyway.
5thGenOwner is offline   Reply With Quote
Old 05-13-2010, 10:53 PM   #7
c6vettepilot
Thanks, guys! Your info is very helpful! That's why I like these forums...
Old 05-13-2010, 10:59 PM   #8
tune out the AFM
Old 05-14-2010, 12:06 AM   #9
thesnoopster
thesnoopster's Avatar
Drives: '10 SIM SS/A6 - '12 SIM Equinox LT
As what they said... its the AFM activating .... thats why im turning it off / deleting it when I get my exhaust and headers and cam later down the road.
2010 SIM Camaro 1SS/A6
Mods: "93 Octane and a baby seat..." TunedByFrost/EFI Performance,LLC @ PAS "You gotta love me ... or leave me alone"
Old 05-14-2010, 12:12 AM   #10
2SSARMY
Drives: 2SS/RS
If you get a tune and something happens you'll lose your whole power train warranty.
"Flashing" it back to stock settings really doesn't help, as they just connect it to a main computer and see everything that has been done to it.
2SSARMY is offline   Reply With Quote
Old 05-14-2010, 10:13 AM   #11
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
That's why you go to your dealer and ask them to recommend a tuner to you. It works for me at least. I'm really cool with my dealer, but anyone that wants to get a tune just ask your dealer and maybe they'll point you in the right direction while maintaing your warranty. This works with modifications also.
StlRomAniaN is offline   Reply With Quote
Old 05-14-2010, 10:21 AM   #12
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
The four major differences are the AFM, cam, variable valve timing, and 10.4:1 compression for the L99 auto vs 10.7 for the LS3 Manual. If I'm correct.
Here are some links to the specs-
http://www.camaro5.com/forums/wiki.p...specifications
http://www.pro-touring.com/forum/showthread.php?t=65615
http://www.qualitychevy.com/2010-Cam...fications.html
http://www.camaro5.com/forums/images/camarospecs.pdf
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128
Northern Massachusetts & Southern New Hampshire Camaro Club
http://www.camaro5.com/forums/group.php?groupid=127
The mother of all supercharger questions thread
http://www.camaro5.com/forums/showthread.php?t=77958
My 2010 Camaro Review
http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442
2010 Transformer Edition Camaro L99 Auto
2010 Bumblebee is offline   Reply With Quote
Old 05-14-2010, 10:50 AM   #13
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
Racing your "STOCK" vehicle at the drag strip also voids your warranty!
2SSCAMARO is offline   Reply With Quote
Old 05-14-2010, 11:17 AM   #14
toehead93
Drives: 2014 2SS/1LE
As everyone pointed out it is AFM. I tuned mine out but another option is to get a resonated x-pipe like Magnaflow makes. It is under $100 shipped.
Actually the cam isn't that big of difference. The realdifference IMO is the AFM lifters which limit rpms and the VVT which advances and retards timing to increase torque under the curve. So although the L99 doesn't have the same peak numbers as an LS3 it does have better power under the curve.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 and L99? black2black10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 05-07-2010 01:58 AM
LS3 vs L99 mods ORANGE U NV Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 01-10-2010 10:45 AM
Solo Performance V8 Quantum Axle-Back Exhaust Kit for LS3 and L99 GOINGSOLO2 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 12-03-2009 03:01 PM
LS3 vs. L99 LS3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-21-2009 11:39 PM
