JUICEDMOTORSPORTS
Old 10-16-2008, 02:02 AM   #1
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Ram-air Design Idea
I hear a lot of people commenting on how the mail-slot is not functional. So..here is a rough idea of how (even you) could make it functional with some automotive supplies. Or for any engineers out there.
http://img374.imageshack.us/my.php?i...3ramairfy9.jpg
Kyle2k is offline   Reply With Quote
Old 10-16-2008, 02:03 AM   #2
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
nevermind I see it. Not a bad idea but i don't care for functional scoop.
Old 10-16-2008, 02:04 AM   #3
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
It would be some extra pluming, but it could bring some cool air to the intake.
Old 10-16-2008, 02:09 AM   #4
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
I honestly don't think that little mail slot will do enough for the flow of air anyway. I think the main air intake would have to be behind the lower grill or upper grill... That slot...nope...too small.
Can't wait to see what SEMA has in store for us in that dept. You know that SOMEONE must have something ready to go!
Old 10-16-2008, 02:13 AM   #5
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Where it loses in height or girth or whatever you want to call it it makes up in length.
Lets assume the mail-slot is 1 inch tall and 12 inches long. So
A= L x W
12in^2 = 1in. x 12in
Whereas if it was a more traditional circular ram air, etc. with a 4in. diameter.
A= pi x r^2
12.56in^2 = 3.14 x 2^2
It only has half an inch less area to bring air in.
btw, it would be to just supplement the air filter, it could just funnel into the air box. (yet still bringing in cool air)
Old 10-16-2008, 02:26 AM   #6
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
if the car was forced induction i could see it working because it would actively be sucking air in, but naturally aspirated no way that hole will allow enough flow.
headpunter is offline   Reply With Quote
Old 10-16-2008, 02:29 AM   #7
ShnOmac
ShnOmac's Avatar
QUOTE=headpunter;160713]if the car was forced induction i could see it working because it would actively be sucking air in, but naturally aspirated no way that hole will allow enough flow.[/QUOTE]
ShnOmac is offline   Reply With Quote
Old 10-16-2008, 03:09 AM   #8
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
I don't see how it couldn't have enough flow. The internal combustion engine is a glorified air pump. Think about it, we have a 6.2 liter engine (mind you, receiving all the air through a 90mm throttle body) , so every 2 rotations of the crank of the engine, 6.2 liters of air is getting pulled in and compressed, ignited, and released. So even at a somewhat low rpm of 4000 (where you might expect to see gains from a ram air anyways) the engine will be rotating ~67 times a second. divide that by 2, because every second rotation it will bring in 6.2 liters. You will be sucking in ~208 liters of air EVERY SECOND.
I would appreciate an engineer or someone to chime in and correct any wrongs. But, it's getting late I think I will leave the rest for tomorrow lol
Old 10-16-2008, 03:19 AM   #9
headpunter
headpunter's Avatar
Drives: Man
when you impede the flow you are getting less density in the air charge.
Old 10-16-2008, 03:20 AM   #10
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
What flow are you impeding, this would supplement the air filter.
Old 10-16-2008, 03:33 AM   #11
headpunter
headpunter's Avatar
Drives: Man
if you are doing it suplimentally it should i guess, i still want to reverse mount the hood and use hood pins to hold it down to allow for alot more room to cut out in that area.
Old 10-16-2008, 03:42 AM   #12
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
I agree that more room would also probably allow more room for a better design, but, the bottleneck all along the induction line by far is still the throttle body. It has a ~3.5in diameter. If my estimates for the mail-slot are correct. that is still ~2in less surface area for flow through the throttle body than it is through the mail slot.
Old 10-16-2008, 04:52 AM   #13
swifttal
swifttal's Avatar
Drives: '91 Z-28
She won't agree with you on that one pal... :(
swifttal is offline   Reply With Quote
Old 10-16-2008, 08:27 AM   #14
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I would rather see something where you could get that slot to provide additional airflow over the radiator ..
Crowley
Crowley is offline   Reply With Quote
A FAKE SCOOP??!! ARE YOU KIDDING ME??!! MotorCityAgent 5th Gen Camaro SS LS LT General Discussions 222 03-01-2009 08:17 AM
Camaro (concept) Press Release!! Pencil.Fight 5th Gen Camaro SS LS LT General Discussions 4 07-21-2008 04:33 PM
United States Air Force PureEvil Off-topic Discussions 6 12-16-2007 12:46 AM
