Old 10-16-2008, 09:24 AM   #15
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
the slot is to close to the radiator anyway, you only be sucking in hot air
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Old 10-16-2008, 10:32 AM   #16
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I don't think the slot would provide significant airflow personally. I'd look for a set-up similar to what the 'Vette-guys have from VaraRam. They get like 3-tenths in the 1320' with that ram air set-up and think there may be a chance of something similar for us. Time will tell
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 10-16-2008, 11:04 AM   #17
Mr Twisty
Mr Twisty's Avatar
Rotate the throttle body main inlet 90 degrees (straight up.) Add 4th gen type filter with a soft-seal on the outer edge, add plumbing from front underside of hood to the cowl, (where it would meet filter with hood down,) VOILA! Cowl induction. [edit] Or if you'd prefer ram-air, modify the hood so the mail slot is on the hood directly in front of the new filter position mentioned.
-- Benjamin Franklin
Old 10-16-2008, 11:30 AM   #18
lalometalik
killer bAnana
lalometalik's Avatar
Drives: 1985 z28
it is strictly a visual design feature. the slot is positioned directly in front of the hood latch. this is not possible as already discussed on a different thread.
click below:
http://www.camaro5.com/forums/showthread.php?t=5365
"Shut your noise tube, Taco Human!"
lalometalik is offline   Reply With Quote
Old 10-17-2008, 10:38 AM   #19
Dan
Dan's Avatar
Drives: 2004 GTO
1. There is a structural support right behind the slot so your idea would not fit.
2. There is no such thing as ram air.
Dan is offline   Reply With Quote
Old 10-17-2008, 10:58 AM   #20
Chewy
My boredom isn't safe
Chewy's Avatar
Drives: 2010 SS Camaro
Send a message via AIM to Chewy Send a message via MSN to Chewy
Ram-air intake
From Wikipedia, the free encyclopedia
Jump to: navigation, search
Contents
[hide]
A ram-air intake is any intake design which uses the dynamic air pressure created by vehicle motion to increase the static air pressure inside of the intake manifold on an engine, thus allowing a greater massflow through the engine and hence increasing engine power.
The ram air intake works by reducing the intake air velocity by increasing the cross sectional area of the intake ducting. When gas velocity goes down the dynamic pressure is reduced while the static pressure is increased. The increased static pressure in the plenum chamber has a positive effect on engine power, both because of the pressure itself and the increased air density this higher pressure gives.
Ram-air systems are used on high performance vehicles, most often on motorcycles and race cars. Ram-air has been a feature on some cars since the late sixties, but fell out of favor in the seventies, and has only recently made a comeback. Modern parachutes use a ram-air system to pressurise a series of cells to provide the aerofoil shape.
At low speeds (subsonic speeds) increases in static pressure are however limited to a few percent. Given that the air velocity is reduced to zero without losses the pressure increase can be calculated according to:
dP / P = (v2) / (2RT)
Chewy is offline   Reply With Quote
Old 10-17-2008, 11:29 AM   #21
Mr Twisty
Mr Twisty's Avatar
A carburetor venturi is ram-air, the SR71 Blackbird uses ram-air. I believe the F22 is also using ram-air to go supersonic without afterburner.
Old 10-17-2008, 11:56 AM   #22
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Hmmm .. I'm pretty sure that the fart out of a RAM can be called Ram Air !!
Crowley
Crowley is offline   Reply With Quote
Old 10-17-2008, 01:30 PM   #23
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I think that the main slot needs to be a bit taller before it could ever really be functional as a scoop. An extra 1/2 in might be all thats needed. Then there is the whole issue of not having any room behind it to put any plumbing.
But if you open it up it might do a bit to help keep the engine cool.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-17-2008, 01:53 PM   #24
Dan
Dan's Avatar
Drives: 2004 GTO
An F22 and a Blackbird can go fast enough to see a pressure change and a ram effect, a car cannot. Reading that it can on wikipedia is about as much use as asking someone on the street since it is written by whoever thinks they know what they are talking about.
Old 10-17-2008, 04:25 PM   #25
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Or asking you what you think....
My original idea is intended to bring cool air to the airbox more than charge it and cause a pressure increase
Kyle2k is offline   Reply With Quote
Old 10-17-2008, 05:02 PM   #26
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
of course im at work and cant see the picture....
i'll touch on this tomorrow
I piss excellence
and fart awesomeness
Old 10-17-2008, 05:42 PM   #27
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
For future referance...... wikipedia is not a real source
Old 10-17-2008, 06:02 PM   #28
erasedgod
CGM 2SS/RS
erasedgod's Avatar
Drives: # 9641
It's good enough for a casual discussion. He isn't doing his thesis here.
erasedgod is offline   Reply With Quote
A FAKE SCOOP??!! ARE YOU KIDDING ME??!! MotorCityAgent 5th Gen Camaro SS LS LT General Discussions 222 03-01-2009 08:17 AM
Camaro (concept) Press Release!! Pencil.Fight 5th Gen Camaro SS LS LT General Discussions 4 07-21-2008 04:33 PM
United States Air Force PureEvil Off-topic Discussions 6 12-16-2007 12:46 AM
