Old 05-14-2010, 11:56 PM   #1
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
Drives: Red Rock Metallic ZL1
Foam gun ?.........Junkman
I have the quater master foam gun, at least I think that's the name, it's the one that you recommended in one of your posts..anyways with the Adams soap, how many ounces do you put in the container, and then you fill the rest up with water right?
Chad's ZL1 is offline   Reply With Quote
Old 05-15-2010, 12:58 AM   #2
Tecca
Tecca's Avatar
Drives: ...
2-3oz is recommended I double that.
Yes fill it with water after you put the soap in.
If not you will get some foam but not nearly as much if you put water in it.
Tecca is offline   Reply With Quote
Old 05-15-2010, 01:01 AM   #3
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
I like to do about 4-5 cap fulls (i have the big 1gallon jug tho) and fill the foam gun container 1/2 full with water.... and give it a little shake before i start.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 05-15-2010, 08:15 PM   #4
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
Oops I've been going pure car shampoo in that bad boy, but it's been working fine. I assume that the worst I've done is waste soap?
ChadG is offline   Reply With Quote
Old 05-16-2010, 12:28 PM   #5
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Chad I have been doing the same thing!!!! I get a hell of a lot of foam tho!! Seem to go through my car wash soap pretty quick.
Looks like I need to water it down.
K
Moriartii is offline   Reply With Quote
Old 05-16-2010, 12:55 PM   #6
Ject
aka Patrick
Ject's Avatar
you can add a little more or little less depending on how dirty the car is.
Old 05-16-2010, 03:33 PM   #7
ChadG
ChadG's Avatar
I'm going to try watering it down with a 1 to 4 soap to water ratio next time I wash it and see if there is a noticeable difference in the suds. Is that still too much soap?
It's supposed to rain the next few days so I will hopefully get around to it late this week and post the results.
Old 05-21-2010, 06:20 AM   #8
Junkman2008
"Detailing Devil Dog"
Junkman2008's Avatar
Drives: 2001 Corvette Coupe
I use 2 ounces of Car Shampoo for the quart sized foam gun.
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline   Reply With Quote
Foam Gun Inferno2SS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 37 05-04-2010 01:20 PM
Tried out a new foam gun tradosaurus Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 14 04-21-2010 04:25 PM
question about the foam gun shad2009 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 02-24-2010 03:13 PM
Foam Gun Questions Onereign Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 2 01-14-2010 04:03 PM
Foam gun for washing cars icemancars Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 13 11-05-2009 11:18 AM
