JUICEDMOTORSPORTS
Old 05-15-2010, 04:41 AM   #1
AntzV
AntzV's Avatar
Drives: blacked out 2010 Camaro
whats the difference????
Im looking into getting some headers but i wanna know whats the difference between these 2;
http://www.haddadmotorsports.com/cat...ers-p-505.html
http://www.haddadmotorsports.com/cat...aro-p-368.html
and do these come with gaskets and header bolts? or do I have to purchase them seperate??
Thanks
AntzV is offline   Reply With Quote
Old 05-15-2010, 05:33 AM   #2
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
i would think one has cats and one doesn't but the description is so simple you can't tell
trudawg660 is offline   Reply With Quote
Old 05-16-2010, 03:01 AM   #3
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
Looks like they are the same part numbers (6511) but one comes with O2 extension harnesses. Headers usually comes with gaskets. You may have to reuse your orignal bolts which is what I had to do with my ARH.
Try the Kooks website for more info.
Cam 427 is offline   Reply With Quote
Old 05-16-2010, 02:37 PM   #4
AntzV
AntzV's Avatar
Should I get the one with the O2 extension harnesses? Would you recommend the locking header bolts?
Old 05-16-2010, 02:52 PM   #5
RedJewelSS
RedJewelSS's Avatar
Drives: six in a row makes it go
yes
brian
2010 camaro SS. LS3/6SPD (sold)
2003 Jeep Wrangler/Rubicon/NV3550
1989 F-150 4x4/300 I6/M5ODR2
1982 mustang. 351W/414stroker C4 9" rear. bracket racer
1977 F-100 5.9L 12V Cummins conversion/NV5600
RedJewelSS is offline   Reply With Quote
Old 05-16-2010, 03:06 PM   #6
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
one link is a kit
the other link is just the headers
you want the kit (mainly the o2 extentions)
DO use the supplied o2 extentions
DO NOT use the supplied replacement exhaust manifold gasket. Just re-use your factory one. Just throw the new ones you got in a corner, or throw them out.
You DO NOT need locking header bolts. You can either re-use your factory ones. Or use the ones that come in the kit. I used the new ones because they were stainless steel and they looked better (I like shiney things).
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 05-16-2010, 03:12 PM   #7
JHL88
JHL88's Avatar
Drives: 02 z06
i dont know the quality of the kooks manifold gaskets, but i used jet hot's gaskets that came with my headers and no leakage. but i wouldn't bother replacing them if they don't need to. it wouldn't hurt buying the GM OEM gaskets either
1997 RS wrecked
1998 Z28 sold
10 SS sold
2002 torch redc5z06 - sold :(
'13 z71 4x4 - DD
www.fquick.com/JHL88
JHL88 is offline   Reply With Quote
Old 05-16-2010, 03:53 PM   #8
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
Originally Posted by danhr View Post
one link is a kit
This is all good advice from danhr. Reuse factory gaskets and bolts. A couple things to consider would be to be sure the header flanges are perfectly flat or you will have a leak. Also, if you are interested to coat the headers this is the time to do so before header installation.
The O2 extenders are necessary because the O2 bungs are located further away and factory wires will not reach. The extenders are plug and play. Good luck and you will feel the difference.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 05-16-2010, 04:02 PM   #9
danhr
BAMF SS
danhr's Avatar
You do not buy new GM oem gaskets. They are re-useable. I have reused 200k+ mile gaskets in other builds. The Kooks gasket is a carbon one, which will shrink during the first couple of heat cycles. You have to re-tighten them. If you don't catch them fast enough, it will blow the gasket, and you will have to start over with new ones. If a header bolt backs out with a GM gasket (generally doesn't happen because they are not carbon, so they do not shrink, you just tighten the hell out of them when you put them on), the gasket is still useable... just wipe off the carbon from the exhaust.
400 - 425 HP What's The Difference??? ParisTNDude 5th Gen Camaro SS LS LT General Discussions 20 04-16-2010 10:35 PM
CAI Sound Difference? kdbolt70 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 02-10-2010 09:25 PM
Sound difference with Cold Air Intake drtwo Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 01-03-2010 05:39 PM
What is the difference between between the 2ss, 1ss, and the Rs?? Houldv 5th Gen Camaro SS LS LT General Discussions 3 07-20-2009 11:34 PM
Whats the difference ? Terrellford12 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 07-20-2009 09:22 PM
