Caryle Racing
Old 10-16-2010, 11:25 PM   #15
bossbunny
Mrs. Bunny to you
bossbunny's Avatar
Drives: The Sassiest V6 in the South!
Mine just started squeaking at 14500 miles. I plan on taking my to the dealer but if I need to replace my pads i'm going to be pissed. It is way to early and I do not want to fork out 800$.
bossbunny is offline   Reply With Quote
Old 10-16-2010, 11:38 PM   #16
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
I've had mine squeek a few times, but only when the car is cold and the brakes are being lightly applied. It's not consistant enough to reproduce it if I took it to the dealer.
Sterling is offline   Reply With Quote
Old 10-16-2010, 11:39 PM   #17
bossbunny
Mrs. Bunny to you
bossbunny's Avatar
Mine started tonight. Mostly when braking and when we were moving at very low speeds. Its got to be the pads. But its never done it before today.
Old 10-16-2010, 11:46 PM   #18
efpardo
Deep6
efpardo's Avatar
Drives: 2016 Camaro #182300 | 2SS | HBM
Send a message via Skype™ to efpardo
Mine started to squeak and I have 22k. I can't see paying 800 to replace pads. I just priced rear rotors and pads for my mothers Impala and the total was like 90 buck. The shop wants $289.00. DIY!; it's not that hard.
My Journals:
Erick's Mistress - Violet 2016 2SS
#182300 | 2SS | HBM |
Erick’s Mistress - 2010 2LT
#8212 | 2LT | RS | CGM | Litho #165 |
efpardo is offline   Reply With Quote
Old 10-16-2010, 11:48 PM   #19
bossbunny
Mrs. Bunny to you
bossbunny's Avatar
Well the gentlemen above said his dealer charged him $800. My dad changed my pads on my last car I'm sure we can do it on the camaro. But shouldn't a dealer just fix it little to no charge? Cause a car with 14k shouldn't have brake issues.
Old 10-16-2010, 11:58 PM   #20
efpardo
Deep6
efpardo's Avatar
If you are still under warranty, and I think you are, I would have the dealer take a look. Breaks should normally last at least 3 years. Rotors seem to be made thinner these days and so when they do wear, there may not be enough to turn = toss and replace. 30 to 75 for slotted and or drilled. Pads run between 30 and 50 a set, depending on brand. Labor is the killer.
My Journals:
Old 10-17-2010, 12:14 AM   #21
bossbunny
Mrs. Bunny to you
bossbunny's Avatar
I should still be under warrenty! Haha. Yeah, stupid labor. Well my dad has done the brakes on my car before but I hate asking him to do it. Hopefully the dealer covers it and I dont have to worry about it.
Old 10-17-2010, 08:21 AM   #22
philthy
philthy's Avatar
Drives: 1971 Monte Carlo/2010 Camaro 2LT
The dealer will cover it. There are redesigned pads that are covered under warranty. You guys should not have to pay a nickle out of pocket. Mine were covered without any problems and have not squeaked at all since.
If your dealer gives you a hard time keep pushing and go through the escalation procedure if they refuse. I did not have to resort to that since my dealer covered it without a battle. See my previous posts regarding squeaky brakes (on a LT, not a SS model.)
2LT Victory Red w/ Black leather interior, automatic trans, polished 19" wheels, R6P (Early Order)
Factory style spoiler, Magnaflow axleback exhaust with resonated x-pipe, Injen CAI, RX catchcan, ABL dash mod,
Drake billet shifter with leather boot, GM splash guards, Toyo Proxes4 tires for summer, Blizzak tires with Moda rims for winter driving
Pre-ordered November 17, 2008
Delivered May 14, 2009
philthy is offline   Reply With Quote
Old 10-17-2010, 09:55 AM   #23
bossbunny
Mrs. Bunny to you
bossbunny's Avatar
Awesome good to know. Feeling alot better about the situation.
Old 10-29-2010, 07:48 PM   #24
PhoenixRising
PhoenixRising's Avatar
Drives: 2010 Camaro VR LS
I've also noticed squeling on my LS that has just over 10,000 miles, It seems to be getting progressively worse...
Only squeals when brakes are lightly applied, hopefully I can get the redesigned pads and stop feeling embarrased driving in parking lots! :(
PhoenixRising is offline   Reply With Quote
Old 10-30-2010, 03:09 AM   #25
Vince69
Vince69's Avatar
Drives: 2011 Camaro 1LT (about to purchase)
Uhh have any of you tried to spray the rotors with some kind of brake spray? This is usually caused by the pads though. This is caused by vibration in the brake pads when light to moderate braking pressure is applied. The most common solution to this problem is to buy new brake pads.
They just don't make em like they use to.
Vince69 is offline   Reply With Quote
Old 10-30-2010, 03:37 AM   #26
Moonshade
Moonshade's Avatar
Drives: ABM LS
I'm at just under 15,000 and the only time I get any noise is under the usual circumstances.
Moonshade is offline   Reply With Quote
Old 10-30-2010, 03:37 PM   #27
Vince69
Vince69's Avatar
Yes, this is very common actually. This isn't really a big problem it's just annoying. There's this product called "anti brake squeal" you pretty apply this onto the surface of your pads.
Old 10-30-2010, 04:32 PM   #28
gill7784
Drives: 2010 Camaro 2LT/RS
Anti-squeal is applied to the areas where the caliper comes in contact with the pad. For clarification, this is on the BACK side of the pad, not the portion that contacts the rotor. Applying anti-squeal is best done when putting on new pads, so it is really not a time or cost effective cure to already squealing brakes.
The only good Mustang is one who was prior enlisted.
gill7784 is offline   Reply With Quote
how much did you pay for your v6??? StangKiller818 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 196 10-10-2011 06:31 AM
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 04:57 PM
Smallest V6 Brake Drag Wheel StrictlyPro Wheels and Tires Talk Sponsored by The Tire Rack 7 03-28-2010 09:15 PM
Ceramic Brake pads for V6? tradosaurus Suspension / Brakes / Chassis 1 12-15-2009 01:46 PM
Horrible Brake Squeal Paperer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 07-27-2009 01:35 PM
