Old 05-16-2010, 08:00 AM   #1
Carlos Garza
Carlos Garza's Avatar
Drives: 2010 Camaro SS RS
Exhaust for my setup
I just got my car from lethal performance in San Antonio and to say the least I'm very happy with the way my car performs. The guys at lethal performance installed a maggie with 1 7/8" ARH, high flow cats and we kept the stock axle back exhaust. My only problem is that I'm getting a lot of drone, I'm guessing is the stock exhaust. What exhaust do you guys recommend I get that will help me get rid of the dreadful drone without restricting airflow?
Thanks
Carlos
Maggie TVS 2300 SC with a 3.6" pulley.
ZR1 Twin Disc clutch.
Hurst Short Shifter.
1 7/8" ARH LT with highflow cats.
Drive Shaft safety loop
Roto-Fab CAI
160º Tstat.
Stage 2 Snow Meth kit safeinjection.
ADM Dual Pump kit
ADM boost and AFR guages
Catch Can.
586 RWHP/ 565 RWTQ
Installed at Lethal Performance San Antonio
www.youtube.com/cgarza12
Carlos Garza is offline   Reply With Quote
Old 05-16-2010, 08:11 AM   #2
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
The LS3 stock exhaust is a pretty much straight through setup. so if you think it has drone. more than likely adding a aftermarket exhaust will only make it worst.
trudawg660 is offline   Reply With Quote
Old 05-16-2010, 08:21 AM   #3
Carlos Garza
I only kept the stock exhaust form the rear axle to the exhaust tips...
Roto-Fab CAI
160º Tstat.
ADM Dual Pump kit
Catch Can.
586 RWHP/ 565 RWTQ
Old 05-16-2010, 08:25 AM   #4
trudawg660
the mufflers of the stock exhaust is a straight pipe, it shouldn't be hard to find one cut open on here
Old 05-16-2010, 08:26 AM   #5
trudawg660
http://www.camaro5.com/forums/showth...s3+muffler+cut
Old 05-16-2010, 08:41 AM   #6
Carlos Garza
thanks for the info...
so a straight pipe will minimize drone? I was thinking of maybe getting the corsa axle back exhaust... I get it a lot of it when ever I down shift before a red light, what I've been doing is getting on the clutch or putting the car in neutral, instead of down shifting, and the drone goes away...
Roto-Fab CAI
160º Tstat.
ADM Dual Pump kit
Catch Can.
586 RWHP/ 565 RWTQ
Old 05-16-2010, 09:02 PM   #7
Carlos Garza
I've been doing some research about the drone problem and I'm not sure my car has this problem. My car makes popping like sounds whenever I downshift and use the engine to slow down. I had the problem since I bought the car but the issue got worse when I installed the headers, high flow cats, maggie, among other things. So what I'm looking for is for an axle back exhaust that can tone this problem down.
thanks!!!
Roto-Fab CAI
160º Tstat.
ADM Dual Pump kit
Catch Can.
586 RWHP/ 565 RWTQ
Old 05-16-2010, 09:07 PM   #8
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
I think if it is factory axleback you're only going to make it worse also.. what midpipe do you have? is it the ARH X pipe? or is that stock as well?
The 2010 Sin is offline   Reply With Quote
Old 05-16-2010, 09:21 PM   #9
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
I had a similar setup .....
ARH 2" LTs, HF cats, x-pipe, and stock mufflers. I didn't have any drone at all. It was really quiet at idle and sounded great at WOT.
However one of the stock mufflers started to do this buzzing/rattling sound at ~1800 RPMs that drove me crazy (loose baffle I think). So yesterday, I removed the mufflers to see how it sounded without them (ARH stops at the axle). MY GOD is it loud.... extreme drone exept at idle. I can't hear the radio on 75% volume at 2000 RPMs.
I will be going to the muffler shop tomorrow to see if they can fix the stock mufflers. Otherwise, I will be getting magnaflow street series.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 05-16-2010, 09:22 PM   #10
Carlos Garza
I've got 1 7/8" AR LT headers with high flow cats and X pipe all the way back to the rear axle...
Roto-Fab CAI
160º Tstat.
ADM Dual Pump kit
Catch Can.
586 RWHP/ 565 RWTQ
Old 05-16-2010, 09:27 PM   #11
Carlos Garza
However one of the stock mufflers started to do this buzzing/rattling sound at ~1800 RPMs that drove me crazy (loose baffle I think). So yesterday, I removed the mufflers to see how it sounded without them (ARH stops at the axle). MY GOD is it loud.... extreme drone exept at idle!
I don't think I'm getting drone. My problems comes when I downshift and use the engien to slow the car down before I come up to a red light, the car makes popping sounds as if someone was fireing a gun. I use to have that problem since the car was new, but it was not as loud as it is now with the mods.
Roto-Fab CAI
160º Tstat.
ADM Dual Pump kit
Catch Can.
586 RWHP/ 565 RWTQ
Old 05-16-2010, 09:28 PM   #12
Bell040
Bell040's Avatar
thanks!!!
all of the V8 Camaros do this popping... you can hear it more when you change from the stock exhaust.
The PCM is pulling fuel during decel. You can tune it out if you want (I forget what it is called... decel delivery or something... check with the tuner gurus). My wideband guage shows an AFR so lean (over 22:1) that it reads an error during decel... right when the popping starts.
It saves gas. It saved you from paying the $1700 gas guzzler tax when you bought your car ... well that and skipshift.
Ordered: 10-13-08
Recieved: 6-12-09
Old 05-16-2010, 09:32 PM   #13
Carlos Garza
The PCM is pulling fuel during decel. you can tune it out if you want. My wideband guage shows an AFR so lean (over 22:1) that it reads an error during decel... right when the popping starts.
It saves gas. It saved you from paying yhe $1700 gas guzzler tax when you bought your car
That makes alot of cents... What I do is step on the clutch and the problem goes away... I'll tack to the guy that tune my car about this, thanks!!!
Roto-Fab CAI
160º Tstat.
ADM Dual Pump kit
Catch Can.
586 RWHP/ 565 RWTQ
Old 05-16-2010, 09:42 PM   #14
Bell040
Bell040's Avatar
yup... your gas milage will go down a little though
it is called DFCO
http://www.camaro5.com/forums/showth...t=tune+popping
Ordered: 10-13-08
Recieved: 6-12-09
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
New low profile electric exhaust cutouts for your Camaro @ PFYC.com Redshift V8 Bolt-Ons & Tunes 8 08-14-2014 05:19 PM
Corsa Exhaust System Christmas Special and free shipping GmPartsDirect.com V8 Bolt-Ons & Tunes 9 12-10-2009 07:55 AM
New Billy Boat 2010 Camaro Exhaust Ragin Racin Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 10-20-2009 07:09 PM
how loud would this exhaust setup be GQ4Life Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 10-17-2009 03:00 PM
