Emblempros
Old 05-19-2010, 03:21 AM   #1
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Amp Recommendations?
I'm looking to power one ten inch sub. The models I'm looking at are the IDQ10V3.D4, ID10D4 V3, or the JBL Powerseries P1024.
The current amp I am looking at, recommended by 2010Sin is the JBL GTO7001, which the lowest I can find is around $216.
My question is, are there amps that are just as good for less money that would work for any of those subs? I don't want to get a crappy sound just to save money, but I'm wondering if there are better deals.
I'm looking at the grand total for the sub, amp, ******** enclosures and budgeting $100 for Steve's harness (hopefully won't be that much, just a guess) and it's kinda steep for me, between 750-850 depending on the sub.
Also, for anyone who is experienced with ID subs, how much difference will I notice between the ID10 and the IDQ10? What are the advantages? Is the IDQ worth the extra $80 or would the ID10 do the job? I guess I just don't know enough about these things to know how much I need to spend to get a good sound.
Thanks a lot guys, I really appreciate all your help.
Old 05-19-2010, 11:01 AM   #2
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
$216 for that amp is a good deal IMO. Base your amp selection on rms power handling of the sub that u buy. That amp is rated at 700wrms@2ohms, which is plenty of power for a 400wrms subwoofer.
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 05-19-2010, 11:16 AM   #3
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Check out Sound Solutions Audio I think you will be happy and have money left in your pocket.
I could be wrong but I would go the other direction, get an amp that is lower than the rms of the woofer. This way you dont run the risk of overdriving your woofer. Example I have a 1000rms woofer being driven by a 400-500rms amp.
Cheers
K
Moriartii is offline   Reply With Quote
Old 05-19-2010, 11:56 AM   #4
LS3SSRS
LS3SSRS's Avatar
Yea, ideally u want the amp to match the rms rating of your woofer. I just see having a more powerful amp being benefical in case u wanted to upgrade the sub down the road.
Old 05-19-2010, 12:02 PM   #5
Racer-X
Rhymin and Stealin
Racer-X's Avatar
Drives: The Search is on ABM V6.....
Send a message via MSN to Racer-X
if you buyh a pre built enclosure you will have to use the ID10 not the IDQ... the IDQ is actually an 11" sub. will not fit standard configation prefabs. the IDQ's performance is probably twice that fo the ID10. very transient and acurate. does not have a stamped metal basket to resonate. is "field serviceable" meaning if for any reason the cone/voice coil assembly should go bad it can be replaced with out have to send the sub in. the ID series are good subs, the IDQ is worht every bit of the 80 bucks and more. but again will not fit a traditiolal prefab mounting diameter.
I think for what it sounds like you are trying to accomplish the ID10 will work quite well for you.
Side note... more power from the amp means you will use less of the gain to level match in turn will give you more "headroom" which will equate to better sound quality. (amps does not have to work as hard.)
Bryan
I Make Cars Sound Good.
Enchantment Editions
Arc Audio Competition Team
Image Dynamics Elite Sound Performance Team
Team Stinger
Racer-X is offline   Reply With Quote
Old 05-19-2010, 12:13 PM   #6
Moriartii
Moriartii's Avatar
So is it a big deal to go the route I did? A 400-500 rms amp pushing a 1000 rms woofer?
Cheers
K
Old 05-19-2010, 12:31 PM   #7
Steve@Subthump
Drives: 2011 2SS IOM Vert
Geez, no the harness won't be anything near that high.
Steve@Subthump is offline   Reply With Quote
Old 05-19-2010, 12:37 PM   #8
Steve@Subthump
We can fit an 11" sub in our large driver's side stealth. Give us the hole dimension and we'll do it. I've never considered any of our boxes pre-fab because they can be tweaked and customized upon request. A JL stealthbox is a pre-fab. Each one is identical to the next and they won't modify the design on an individual basis like we can.
Old 05-19-2010, 12:43 PM   #9
Racer-X
Rhymin and Stealin
Racer-X's Avatar
Steve that is excellent to know. Thanks. I will get you some spec for the IDQ10.v3 to have for future reference.
Bryan
Team Stinger
Old 05-19-2010, 02:25 PM   #10
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
Cant wait to see what you decide to do! :-)
The 2010 Sin is offline   Reply With Quote
Old 05-19-2010, 04:53 PM   #11
CamaroDreams07
Drives: Slow V6
Sounds like I really owe it to myself to spend the money. Which means waiting a little longer :(. Steve, is there an additional charge to get it made to fit the bigger sub? Oh and good to know on the price, I'd just rather budget too much than not enough, you know?
Old 05-19-2010, 04:56 PM   #12
shevyman
Drives: 2010 Camaro SS IOM
Cheers
K
running a low amp to your subs is actually bad for them. you would actually want an amp with more power.
shevyman is offline   Reply With Quote
Old 05-19-2010, 04:56 PM   #13
CamaroDreams07
Drives: Slow V6
Cheers
K
Every amp on their site is more than the one I'm looking at- they start at $240...
Old 05-19-2010, 05:01 PM   #14
shevyman
in some ways i think the systems other people mention ask for to much.
i have learned to work with arc,focal, and hertz. all work great in large or small enclosures. also give great sound. never have been so impressed with a single sub that is being pushed with 300watts. sounds better then my fosgate with the 800watts i was running it with. also you want a great amp i would go audison. MAN can you tell the difference in clarity.
Amp install- how to (w/pics) ASTEDA Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 02-27-2017 02:27 PM
Amp install - how to (w/pics) ASTEDA Camaro DIY & HOW-TO instructions & discussions 28 01-27-2013 04:07 PM
Stereo GUIDE ALL READ WildBeast15 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 29 09-11-2010 02:14 AM
Adding an Amp to the BA system... ZZcamaro Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 07-09-2009 12:52 PM
