| Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions. |
Thread Tools |
![]() ![]() ![]() ![]() Drives: 11 IOM 2SS/RS M6 w/Hurst Join Date: Nov 2009
Series/Parallel wiring
Ok I have a dumb question here:
How do you wire a sub in series/parallel? I have found the diagrams and for some reason it isnt clicking for me. Throw me a bone here. This is on a DVC woofer (dual voice coil). Cheers K |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: yummy Join Date: Sep 2009
Depends on what ohms you need to match up to. I take it you mean the sub has four terminals?
Yes the sub has four terminals to match each voice coil that it has. I need to present a 4 ohm load to the amp so in my case it would be series (2 x 2ohm DVC).
I assume the - of one coil is wired to the + of the other and then the remaining - and + are wired to the amp? Cheers K Last edited by Moriartii; 05-19-2010 at 02:52 PM. Reason: Changing ohm load |
#4 | |
edit: I read your post again, and It looks like you have 2ohm voice coils. Series will give you 4 not 1. |
#5 | |
Iatefiberglassinsulation
I'm Brick Tamland. People seem to like me because I am polite and I am rarely late. I like to eat ice cream and I really enjoy a nice pair of slacks. Years later, a doctor will tell me that I have an I.Q. of 48 and am what some people call mentally retarded.
2010 Chevrolet Camaro SS - Daily Driver 1996 GMC Sierra 2500 SLT - Tow Vehicle 1993 Volkswagen Fox - Race Car (yes seriously) "Like" my race team on Facebook: http://www.facebook.com/farfrumwinnin |
#6 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
series + \/\/\/\/ - + \/\/\/\/ - (the middle - and + is wired together) series adds resistances
parallel + \/\/\/\/ - + \/\/\/\/ - (the end +'s are wired together and then the end -'s are wired together) parallel divides the resistances |
#7 |
See my original post, I had the load wrong. Needs to be a 4 ohm load, not the original 1ohm like I had stated.
So it sounds like I should wire it like Darth Martel suggests? Cheers K |
#8 |
Yeah, just out of curiosity what amp and subs are you using?
#9 |
Using a SSA ICON 12" sub with a SA 125.2 amp in a Subthump trunk enclosure.
Cheers K |
#10 |
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
I would like to ask an add-on question for you guys.
When wiring up a sub, does the wattage the sub receives differ at all when put in series versus parallel? I totally understand resistance, but I must have skipped the class in Physics about wattage. I only ask because I was considering purchasing a new amp for a pair of subs in another vehicle, and I was trying to figure out what wattage of amp I needed to buy. I have two 4-Ohm dual-voice coil 12" Alpine Type-R subs. Which means, if I wire the voice coils in series but the subs in parallel, I get an equivalent load of 4-Ohms, or if I wire all four voice coils in parallel I would get an equivalent load of 1-Ohm. However, I am not sure what wattage I need to be able to push at the amp when the the subs say 500watts max per voice coil. Does that make sense?
#11 |
I think from what I have been reading you are ok to wire the subs voice coils in series but it is bad to wire the amps in series.
Cheers K |
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 1LT RS Rally Yellow Join Date: Oct 2009
With the subs you have, a monoblock amp, rated 1000wrms at 1 ohm would be perfect. The Memphis MC-1000d is a good example.
#13 |
speed freak
Drives: 2012 Cadillac Escalade,10 IOM 2ss Join Date: Jun 2009
What type of sub is it( dual 2 ohm voice coil)or (dual 4 ohm voice coil) ? You will need a dual 2 ohm to get reach a 4ohm load.
Current:2012 Cadilac Escalade.2011 CVO StreetGlide cammed,tuned&loud. 2010 IMO/IO,custom stripes,GFX,sunrf,solo exhaust,JBA shorties,rotofab,Jannetty tune,Pfadt,JLw6 Audison&Hertz,7/4/09 2GIFKIEJ6A9123779
Del 7/10/09 Former Camaros 72 LT1 Z28, 86 z28 |
#14 |
Warehouse 13 Survivor!!!!
Drives: '10 CGM 2SS/RS - 69' Camaro Join Date: Sep 2008
This is a nice visual example of the different wiring configurations that someone put together http://slumz.boxden.com/f22/subwoofe...agrams-833961/
#15 |
wiring in series will increase the speaker resistance that the amp 'sees', and parallel wiring +/+ -/- will decrease the resistance, causing the amp to try and create more power for that load. Whether or not the amp is stable under that 'load', and if the speaker can handle the amp power is the key.
DVC subs allow for different wiring flexibility, that's about it. |
#16 |
Maybe I'll ask my question in a different manner.
If you have an amp that's rated for 1000watts at any resistance load (4-Ohm, 2-Ohm, or 1-Ohm), how many watts would each voice coil of a subwoofer see if it was wired in series or parallel? Does each voice coil see 500 watts regardless of the configuration (series or parallel), or does the configuration determine the wattage that each voice coil sees? |
#17 | |
So to take the different available scenarios using the most common speaker configurations (4 ohm and 2 ohm SVC and DVC): 200x2 at 4 ohm You need 2 SVC speakers rated at 4 ohms each hooked directly and separately to each channel. OR you can have 4 2 ohm speakers and wire two of them in series to each channel. You would go + on the channel to + of speaker 1, - to + from speaker 1 to 2, then - to - on the channel. OR you can do the same with 2 DVC speakers with 2 ohm voice coils. 300x2 at 2 ohm You would need 2 DVC speakers with each voice coil rated at 4 ohms, you would then hook the positive side of the first channel to the positive of the 1st voice coil, then to the positive of the second voice coil, do the same with the negative, then go to the next speaker and channel and repeat. OR you can do this with 4 4 ohm SVC speakers by connecting them in the same manner, just treat the second speaker like a second voice coil. OR if you have 2 ohm SVC speakers you can directly wire the positive and negative of each channel to each speaker. 600x1 at 2 ohm You can do 1 DVC speaker with 4 ohm voice coils wired in parallel and bridging the channels, to do this you use the positive from channel 1 and negative from channel 2 (read the amp's manual to make sue this is the case some have specific setups to bridge them). OR 2 SVC speakers with 4 ohm coils wired the same way OR 1 2 ohm SVC speakers wired directly. The possibilities become even more if you throw in 8 ohm and 1 ohm (does anyone even make a 1 ohm sub??). So in the end theres no exact formula for wattage, you have to look at what the amp is rated at based upon recommended load ratings, better quality amps will be able to hold better RMS wattage at lower resistances.
#18 |
[QUOTE=CamaroSkooter;1881465]Maybe I'll ask my question in a different manner.
this = the configuration determine the wattage that each voice coil sees |
#19 | |
Well... Several amp companies have regulated power supplies, which means they produce the same power regardless of impedance presented by the subs. JL and PG are two off the top of my head. So one cna wire anywhere from 1 ohm to 8ohm, and the amp will provide the same power. Only regulated power supply amps can do this, and the down side is that you can't cheap by wiring below rated resistance and getting more power, if you can supply the voltage. And yes, if oone wires a sub in parallel or series, and it's a dual coil, quad coil, whatever, the power is split evenly amongst those coils.
#20 |
Rogue, I appreciate the "lesson" but I wasn't asking about impedence. And there are amplifiers that are "rated" for the same wattage regardless of load. Check out Alpine's PDX series amplifiers. Not only do you get the same wattage at the different impedence levels, you can also stack them to save space
![]() My question was, if you have a set load, do the voice coils each get an equal split of the amplifier wattage regardless of them being in series or in parallel? I believe mrray13 answered that for me though. Which boils down to, my subwoofers are both dual voice coil subs (four voice coils total). Each voice coil is rated at 500watts max (probably 250watts RMS, they're a much older version, I need to find the paperwork) which means I need an amplifier that can supply 1000watts RMS at whatever impedence I decide to wire them at. |
#21 | |
Yep, you got it!!
#22 | ||
You need to check the amp specs. Yes this can be done in a way (admittedly I've been out of the game for a while so I didn't even realize these amps were out there), but The Alpine example used puts the same output out at only 2 and 4 ohms, the JL example depending on the amp AND the channel configuration may only go down to 1.5 ohms not bridged or 3 ohms bridged and only as high as 8 if its bridged. Its not as simple as you make it sound, they will not always put out the same power, so as I said at the end of my description, you need to read the amp specs and match your speakers and wiring to it because the amp you want to use may not match what you have. For example Look at the JL HD 900/5 for the front or rear channels it puts out 100wx2 at 4 ohms but only 75wx2 at any lower impedance. But yes skooter maybe I read your question wrong but no matter how you have it wired they will split the power evenly between coils or subs or whatever. Your last statement is exactly right, you need to find an amp that can provide whatever power you need at whatever impedance the coils are rated for and you wire them at. The amp may be able to handle multiple load ranges but it can't defy the laws of Physics.
#23 |
JL Audio 1000/1v2 Monoblock...
1000 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V) is one example of a regulated power supply amplifier. PG has made one, as had a few other companies. They aren't as plentiful as non-regulated power supply amps, but the can be found. Also, I did overgeneralize a bit above, but my point remains the same, lol. Also, Rouge Leader is correct. You should always check specs before buying.
#24 |
Like I said above, I remember all the stuff in physics about impedence, just forgot all the stuff about wattage
(or I neglected to pay attention )
#25 |
http://www.the12volt.com/caraudio/wo...s.asp?Q=2&I=22 I always jsut use this
| Thread Tools | |
| BCM wiring | HaZe_X | 5th Gen Camaro SS LS LT General Discussions | 4 | 11-03-2012 05:57 PM |
| Garmin nuvi > mounting & wiring for the Camaro | 67 GTO | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 25 | 11-05-2011 12:52 PM |
| Conept Wiring vs. Production Wiring | Silverghost | Camaro Photos | Spyshots | Video | Media Gallery | 2 | 01-19-2010 05:43 PM |
| Anyone have picts/info on the factory infotainment system wiring harness & plugs? | Matt'sSS | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 3 | 10-01-2009 12:48 AM |
