Old 05-19-2010, 05:38 PM   #1
need4spd
need4spd's Avatar
Drives: 2012 2SS Black on Black
using higher octane on v6
manual says 87 octane.. can we use higher octane on our v6 and not damage engine? or is there really a difference between using 87 and 93
need4spd is offline   Reply With Quote
Old 05-19-2010, 05:41 PM   #2
Frank in MD
Raining Blood
Frank in MD's Avatar
Drives: 2014 SS Performance Sedan
I don't think you'll damage the engine, but you might blacken the plugs, while spending more than you should.
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured
Frank in MD is offline   Reply With Quote
Old 05-19-2010, 05:43 PM   #3
Buhmblbe
Growing Up=Optional
Buhmblbe's Avatar
Drives: 2010 Camaro Transformers 2LT RS
I think the manual says something like 87 or higher. I have been putting 92/93 in since I got it and have not had a problem.
Go to this thread...Read post number 4...Should just about sum it up for you.
http://www.camaro5.com/forums/showth...t=v6+octane%27
"Sleep is an inconvenience to living...Get up and start living."
Buhmblbe is offline   Reply With Quote
Old 05-19-2010, 05:47 PM   #4
Berean
Drives: Truck
You can always go higher, but should never go lower.
Lower octane in cars not designed for it will cause engine knock due to fuel ignition outside of the combustion cycle.
You wouldn't think so, but lower octane fuel will ignite more easily, which is why it's not used in high compression engines.
Berean is offline   Reply With Quote
Old 05-19-2010, 05:58 PM   #5
squat
Drives: 2011 Dodge Charger
In newer cars the engine has sensors that detect knock and will retard the timing accordingly so the engine isn't damaged. So you probably could run lower grade in there, but I would avoid it.
2011 Dodge Charger
squat is offline   Reply With Quote
Old 05-19-2010, 06:00 PM   #6
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
My HHR SS requires (in the owners manual) 91 or higher octane. Now that's just a little 2.0L ecotec that's turbo charged.
If I had a 312hp V6 Camaro, I'd put 91 or higher in it. That's just my two cents. What are you saving by going with lower gas. $2.70 a fill up?
Old 05-19-2010, 07:12 PM   #7
zen
Drives: 2011 CTS CPE & 2010 2LT/RS CGM
If the ECM is set to maximize at 87 octane then you will actually loose power using a higher octane. Lower octane gasoline contains more BTU's of energy then higher octane.
zen is offline   Reply With Quote
Old 05-19-2010, 07:16 PM   #8
kevin1
Drives: 2010 Camaro LS
I've been using mid-grade or higher no problems here. And really the price for a fill up aint much more if ya think about
kevin1 is offline   Reply With Quote
Old 05-19-2010, 07:20 PM   #9
USAFJeeper
Bringing mullets back
USAFJeeper's Avatar
Drives: 2010 Rally Yellow 2LT/RS
Thats my thinking. At most 93 is 30 cents more than reg unleaded. So... 4-5 bucks mor eon a fillup max. If I can find 91, I use that, around here, with good gas stations, its 89 or 93...
I dont think it hurts the V6, would it affect gas mileage? Hell I dont know, the closest I am to a mechanic is when I am handing one money.
Stripes, InJen CAI, Flowmaster American Thunder exhaust system, Knight Rider scanner bar behind the grill (sue me!, I like it!)
Next - Tinting
USAFJeeper is offline   Reply With Quote
Old 05-19-2010, 08:42 PM   #10
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
lol. If you drive a V6 just fill with 87. No need to spend the extra money. Higher doesn't benefit you at all. Doesn't increase MPG, doesn't make it more powerful... I thought I should have used Premium on my V6 as well. But if the Manual says 87... just do as it says. =D
jagan323 is offline   Reply With Quote
Old 05-20-2010, 02:33 PM   #11
2010CamaroRS
Driver of the Blue Demon
2010CamaroRS's Avatar
Drives: '15 Jeep Grand Cherokee Limited
+1
New England Camaro 5
The Few, The Proud, The Hyper Blue Metallics
DT shorties.BBK Intake.FlowMaster AT.Eibach 1'' drop.Hurst Short Throw (44% reduction).Unrestricted Motorsports Gen 1 Style Rear Spoiler.Custom Aqua Blue Metallic Interior Panels.RS Embroidered Head Rests.Interior LED by Oracle.Illuminated Bowtie by Oracle.Footwell LED by Oracle.Grille LED by Oracle.Functional Headliner Console Toggle Switches for LED Lighting.Aqua Blue Engine Cover.RotoFab Radiator Cover.Aqua Blue Fuse Box Cover from RPI Designs.Much More
2010CamaroRS is offline   Reply With Quote
Old 05-20-2010, 02:35 PM   #12
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
As others have said, it's a waste of money to put higher octane fuel in the V6. It is designed to run on regular. You are throwing away money as you won't get any gains from higher octane fuel.
Old 05-20-2010, 04:20 PM   #13
rjcamaro
312 HP
rjcamaro's Avatar
Drives: 2LT/RS RJT
Gasoline Factors That Matter
The quality of gasoline and the additive package usually affect the rate of engine wear more than the octane rating. Basically what this means is that it matters more where you buy your gas than which grade you purchase.
Regular Unleaded Gasoline
The recommended gasoline for most cars is regular 87 octane. One common misconception is that higher octane gasoline contains more cleaning additives than lower octane gas. All octane grades of all brands of gasoline contain engine cleaning detergent additives to protect against engine deposit build-up. In fact, using a gasoline with too high of an octane rating may cause damage to the emissions system.
Mid-Grade Gasoline
The octane ratings 'regular', 'mid-grade', and 'premium' are not consistent. In the United States, for example, one state may require a minimum octane rating of 92 for premium gasoline, while another may allow an octane rating of 90 to be premium. Check the octane rating on the yellow sticker on the gas pump rather than relying on descriptive labels.
Premium Gasoline
Certain high performance engines benefit from use of high octane fuel. For other engines, using a fuel with a higher octane rating than the vehicle requires sends unburned fuel into the emissions system and catalytic converter. This puts unecessary stress on the emissions system. For some vehicles, a rotten egg smell coming from the tailpipe signals use of too-high octane gas.
rjcamaro is offline   Reply With Quote
Old 05-20-2010, 04:24 PM   #14
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
I've been using 91 since i bought it. actually, the dealer filled up the gas with 91 right before i picked her up.
Gasoline octane for V-6 RustyHookz Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 149 05-17-2011 09:00 AM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 11:58 PM
V6 M6 & A6 Differential and Transmission Fluids - Recommendations... V6 ONLY PLEASE! ninety6 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 2 04-14-2010 08:28 AM
Hmm...higher octane? Shadowsong Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 27 08-29-2008 07:29 AM
Octane Booster and synthetic oil big_bank5000 5th Gen Camaro SS LS LT General Discussions 25 05-14-2008 04:32 PM
