JDP Motorsports
Old 10-17-2008, 01:46 PM   #1
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Boost Gauge
OKAY...so we have the four gauges in the lower console...I figure Volt meter is the least useful...How could we replace that with a good boost gauge? Is there anyhing made to fit that weird shape? will it be replaceable?
I would love to see what you guys can come up with. I just think it would be extremely clean to put it there instead of getting too carried away with the A-pillar gauge pods!
Lets see it folks, what can we do with a boost gauge?
ZZcamaro is offline   Reply With Quote
Old 10-17-2008, 01:53 PM   #2
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I have a feeling the aftermark will come up with some sort of solution.
Crowley
Crowley is offline   Reply With Quote
Old 10-17-2008, 05:28 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
what good would a boost gauge be on a N/A motor?
I piss excellence
and fart awesomeness
Old 10-17-2008, 05:35 PM   #4
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Well .. it could read vacuum ..
I think he means if you go FI ..
Crowley
Old 10-17-2008, 07:07 PM   #5
haulass350
haulass350's Avatar
Drives: 97 silverado
Crowley
i was thinking the same thing although i would prefer a pillar mounted setup so all the criticall guages are at eye level, imho.
haulass350 is offline   Reply With Quote
Old 10-17-2008, 07:21 PM   #6
ZZcamaro
Well It is obviously on a blown motor. And I had pillar gauges in my T/A, but I would ike to keep it down in the center console. Those are the gauges i used to have on the pillar anyway. Just a thought, that is why I wanted to see what you guys all think could be done to get a guage in there, and keep a clean look. It isnt like you need to look at those numbers much while driving...I really only looked to check while dyno tuning...The rest (temps) you really only check sparingly.
Old 10-17-2008, 10:27 PM   #7
Radio Free Berlinetta
Drives: 1980 Camaro Berlinetta
Given that the car is equiped with a multi-fuction display between the guages, it would be nice for GM to release some kind of SDK to allow an owner to develope new uses for it, like a boost guage for example. This would solve two problems: no custom cutting or replacing of parts would be needed to mount new hardware, and it would keep these vitals in your line of sight.
Just an idea from and unrepentant geek.
Radio Free Berlinetta is offline   Reply With Quote
Old 10-17-2008, 11:10 PM   #8
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
what is the manual getting in place for the Tranny temp gauge?
franknbeans is offline   Reply With Quote
Old 10-18-2008, 02:23 AM   #9
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
From what I've seen, a trans temp gauge. Not that you'll need it.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 10-18-2008, 03:38 AM   #10
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Crowley
Old 10-18-2008, 08:34 AM   #11
Mr Twisty
Mr Twisty's Avatar
G-meter with recall would be a nice replacement gauge.
Wait and see what aftermarket comes up with, or design your own gauge pod to replace the factory setup.
-- Benjamin Franklin
Gauge cluster picture Txturbo Cosmetics and Lighting Modification Discussions 71 01-04-2009 01:14 PM
High Compression Ratio + Boost = Uh Oh AirGoya Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 50 09-21-2008 09:55 PM
Torque Gauge in the pod? Shifty 6 5th Gen Camaro SS LS LT General Discussions 39 09-04-2008 01:30 PM
more boost SSNIGHTMARE Off-topic Discussions 13 08-23-2008 03:25 AM
