| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() Drives: 2010 camaro ss automatic Join Date: May 2010
anyone changed torque converter only?
I am curious to see how much of a difference just swapping out the torque converter would make. 1/4 mile, 0 to 60 and seat of the pants feel.
I would think that on these cars a converter would be a bigger difference than most other mods. What do you think? |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
The car was also tuned for the converter (which is recommended). It went from 13.13 to 12.79 in the 1/4 mile.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS , 1970 Z-28, 2002 Avalanche Join Date: Aug 2009
I have checked into this and was told that, yes, if you have good traction a loose convertor will show great improvements in the 1/4 mile at the loss of some "driveability" and there have been some issues with the lock-up in aftermarkets converters. I was told that the best thing to do to keep things in check with the trans was to have your existing converter removed and reworked for some extra stall and reinstalled. Just my 2 cents.
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ Livernois Motorsports 2C Cam kit Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust Roto-Fab CAI / Port Intake Precission 2400/2800 Converter/3.73 AAM gears Livernois Motorsports Tune Best time: 11.97 @ 117 MPH |
5150
Drives: 2010 Camaro 1SS/RS A6 Join Date: Feb 2009
Have a Phoenix 3200 I'm evaluating for streetabiliy and some 60' times.
*larry, we developed a nice converter with a flash stall of 3200rpm for the 6L80E. It retains the stock clutch and damper so it is compatible with the PWM lock-up strategy of this unit.It is a 258MM size and is nice and tight around town at normal driving. *no tune Around town w/paddle shifting it's great. D/S mode + AFM Just needs a little "heavy" foot from a stop Highway in D/S mode it's fine. Tried to get some 60' times, but do to wheel hop and stock tires breaking loose only gained a .10. (BMR trailing arms this week) Seat of the pants feel This was Gregs response concerning the GM High Tech Mag article That is very close to our converter with the exception that ours does not use a billet cover and clutch. We use a stock style damper and clutch to keep the lockup function just like the factory intended and it is also so much easier on the trans and converter since the damper cushions the clutch application. |
PWRtrip, what is the price? I have installed the BMR trailing arms and toe rods and my car pulls 1.8's 60 foot times with no tire spin on stock tires @ 374 RWHP. I am waiting on money so that I can do a cam swap but was limited to size due to the stall of the stock converter. Also, do they have any converters around the 2500 area? Thinks for the info and please PM me.
#6 |
5150
Dave..I believe $589. w/core exchange
Greg is the man to talk to. http://phoenixtrans.com/index.html *his customer service with the TBSS guys/gals is what swayed me to Phoenix. |
#7 | |
Hey, very interested in their converters. But they have a price of $973.35 for their 4L80E converter. Do they make less expensive converters for the 4L80E? Quote: This is our strongest Torque converter for the 4L80E transmission and is available in stall speeds up to 4500rpm and applications up to 900HP. This converter features a billet 1 piece front cover with pilots for GM V-8 engines as well as LS1 style engines. We use a special clutch design that not only has a greater clutch surface area than any other single piston 4L80E converter but will also work with GM ec3 programming. Other features include, full furnace brazing of all internal fins on both the cover and stator, heavy duty sprag and race, full Torrington bearings throughout, hardened hub, hardened turbine spline, anti ballooning plate, fully computer balanced. If you need a high stall converter for the 4L80E then this one can take the punishment! $973.35
#8 | |
5150
(I just got a hell of a deal with the offer to evaluate and would rather Greg confirm the pricing) ![]() Larry, we developed a nice converter with a flash stall of 3200rpm for the 6L80E but we don't have any cores left to build another one at this time. It retains the stock clutch and damper so it is compatible with the PWM lock-up strategy of this unit.It is a 258MM size and is nice and tight around town at normal driving. We sell these for $589. If you had the time I could use your converter for the build. It would take about two days. The only other option I have right now is a billet cover converter with a non damper style clutch. The downside to this is it is not nearly as street friendly and also costs about $897 Let me know if we can help, I appreciate your interest. Greg btw,noticed this converter was 11 lbs. less than stock when I shipped core back in same box. |
#9 | |
Did you get your car tuned for the converter (raise rev limiter, etc). Sorry, I just noticed you mentioned no tune. I've also been looking into Circle D and Protorque. They seem to have good reputations. I believe Pro Torque's converter is about $700.00. I know some guys with GTO's that really like the Protorque conveters.
![]() Last edited by SGOS252382; 05-23-2010 at 06:00 AM. |
#10 |
It's not just a hobby!
Drives: 2010 2SS/RS Join Date: Apr 2010
I ordered my Yank 3200 and it was $775 shiped to FL. Waiting for it to get here. The guys at the shop said i should get about 4 tenth off my 1/4.
#11 | |
Someone with more converter knowledge could chime in.
#12 |
![]() Drives: 6 camaros Join Date: Feb 2009
you can lock them up anytime really.. its in the tune... As for locking, I only lock mine in 5th and 6th anyway.. maybe 4th if cruising would be ok..
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427 2002 SSLE Convertible 1968 383 Camaro 1968 327 Camaro Convertible 1967 RS 327 1967 Pro-Tour LS3 in progress |
#13 |
![]() Drives: 2010 Camaro SS Join Date: May 2010
I would wait for the updated Protorque 2800
Joe Rivera from Protorque is doing a 12in version (2800 STALL) for me in 3 weeks, He is waiting for his newest stator to come in..It will work and function just like the stock verter but flash stall to 2800...Joe told me he can build me a Custom 10.5 using a billet housing but thinks the 12in (stock size) version will be a great option some of us.. You are correct some of the smaller units will not lock up in 3rd... Joe is a very smart guy, I would wait for his newest verter.. I will be testing it in about 3 to 4 weeks Tell him Joel From Injection Connection told you to call him
SOLD
2010 Camaro 1SS/A6 12.59@111.31 Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned |
#14 |
You can have it lock in any gear the tune will set everything up.
| Thread Tools | |
| Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. | radz28 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2465 | 05-10-2013 05:44 PM |
| Catalytic converter | jayC1974 | Tuning / Diagnostics -- engine and transmission | 11 | 04-24-2010 09:23 AM |
| GM Reveals 2011 Chevrolet Silverado HD | FenwickHockey65 | General Automotive + Other Cars Discussion | 55 | 03-04-2010 01:56 PM |
| Question about back pressure and torque | firengnred | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 02-18-2010 11:42 AM |
| 5th Gen Camaro LS3 info from Chevy Hi-Po...READ | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 295 | 03-07-2008 10:06 AM |
