sjm autoprod
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > International Regions > Middle East
Old 05-22-2010, 04:50 PM   #1
Camaro_AbuDhabi
It's Roar makes me giggle
Drives: Camaro SS2 / RS - 2010
Camaro - Abu Dhabi - 12AM - 33C⁰
السلام عليكم
Hello fellow camaro owners !
Got this Beast a little under two weeks ago. Gave my Mercedes CLS to my Parents ... can i say mercedes cls on these boards ? and decided to give german luxury a break and go for US muscle power ! went into the dealership on a Saturday, and by Wednesday night it was mine
Photo taken a few minutes ago outside my home in the city of Abu Dhabi.
Only problem in the almost two weeks i've had this beast of a car is the warning signal you get when one of the tire sensors goes off .... ive been to the dealers , all my tires are in top shape , but they did notify me that the job takes 10 minutes max to fix one of the sensors that was damaged probably during "heavy handling?!"
I have only 1200 kilometers on it so far and i didnt try and accelerate full force yet .... after the first inspection at 1500 i will go faaaaaaaaast
Camaro_AbuDhabi is offline   Reply With Quote
Old 05-22-2010, 05:06 PM   #2
CamaroFreako
KMK
CamaroFreako's Avatar
Drives: Slow V6 Camaro
gratz dude, hope u enjoy it.
CamaroFreako is offline   Reply With Quote
Old 05-22-2010, 05:13 PM   #3
Camaro_AbuDhabi
Thank you
Old 05-23-2010, 12:17 AM   #4
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Drives: Black 2SS/RS 14; Jeep 5.7 GC 15
Welcome to the club .
Man it was 43 degrees in Muscat last (NIGHT). Do you have black vent inserts in your Camaro as a standard accessory or did you order them?
I installed mine but for only 24hr, and they started coming out from the heat. Re-installed them again with gum and hope that they will hold longer in this hell
Im not Gray any more !!
Cyber Gray is offline   Reply With Quote
Old 05-23-2010, 01:29 AM   #5
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
congratz.. is it an auto or manual...
the sensors maybe that your just too used to mercedes.. these cars can slip out real easy with not so much accelration in a low gear and trigger the traction control
I used to have an '09 x5 4.8.. and when i moved to the camaro.. in the first month under 'normal acceleration' the traction control saved my car a few times...
AlSuwaidi is offline   Reply With Quote
Old 05-23-2010, 12:43 PM   #6
alssiri
alssiri's Avatar
Drives: 2012 ZL1 A6
Congrats on the beautifull ride
Ahmad
2012 ZL1 A6
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Corsa Sport Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, AGP Dual Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
2015 Rear Fascia Conversion, Z/28 Side Skirts, Flares, Spoiler & Diffuser , ACS Quarter Ports, ShowStopper's Side Marker's, LightWurkz Halo's.
Sosche With KenWood, SLP pod with PLX guage, DashLogic .
alssiri is offline   Reply With Quote
Old 05-23-2010, 11:47 PM   #7
Camaro_AbuDhabi
thanks everybody
@cyber gray .... they were installed at the dealership (liberty) in abu dhabi and i am facing no problems with it falling off i would go for UHO glue lol
@alsuwaidi , its an automatic and you might have a point there , ill raise my concerns once im at the dealers this weekend when i reach 1500 kilometers
Old 05-24-2010, 04:36 AM   #8
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Originally Posted by Camaro_AbuDhabi View Post
thanks everybody
Well we are facing a harsh summer weather this time, for almost 3 days now the temp. is around 43 at night and thats why I guess the vents couldnt hold on!
Man, I couldnt even touch them with my fingers because of the heat !!
Hopefully they will hold on with mounting.
I'm facing a similar problem with my Magna Flow exhaust tips, they release too much heat too.
Enjoy the ride.
Old 05-24-2010, 08:17 AM   #9
Q8Y
Q8Y's Avatar
Drives: '12 F150
Congratz on your car
If you still have a problem with your tire sensors try to recalibrate them that might solve the problem.
put the ignition on battery engine off press menu then scroll until you reach the tire page press set to relearn the horn gonna sound twice and tire learning active message gonna show start with left front tire driver side deflate the tire until you hear a horn then go to front right tire passenger side do the same then rear right and rear left, on the last tire the horn gonna sound twice switch the ignition off inflate the tires to the required pressure found on the door of the driver (mine 36 psi cold tires )switch the ignition on and see the pressure it may take a while before the pressure reappears.
hope that's help I used to have this problem in my silverado even after changing the sensor the message still appears but after doing this problem solved.
recieved 7-10-09 2010 camaro black 2ss/RS/6m
Q8Y is offline   Reply With Quote
Old 05-24-2010, 08:40 AM   #10
MinnesotaDream
MinnesotaDream's Avatar
Drives: 2010 RS Inferno Orange
How cool to see that car parked in Abu Dhabi!
Awesome in fact! Good luck an have big fun in it!!
MRT V2 - FOOSE Legends
MinnesotaDream is offline   Reply With Quote
Old 05-24-2010, 02:04 PM   #11
Camaro_AbuDhabi
thanks bro much appreciated ...... yeah im aware of this but the dealer did say i should not do it because it wont help , so lets see if he knew what he was talking about once i get there
@Dream thanks
Old 05-24-2010, 03:35 PM   #12
congrats
Old 05-25-2010, 03:46 PM   #13
BLACK
Drives: 2SS/RS BLACK
you'll have a lot of fun
Originally Posted by Paperer View Post
If my parents ever ask to drive my car, I throw them the keys.
But if my brother asks, I throw a banana at him.
BLACK is offline   Reply With Quote
Old 12-03-2010, 03:11 PM   #14
Muskles
Drives: Camaro 1LT
@ Camaro_AbuDhabi Congrats on bringing BumbleBee home!
I was wondering if you know if modification of the in built radio with a Rear View Camera screen fitting can be done somewhere reliable in the UAE (Im in Dubai) without affecting the dealer warranty.
Muskles is offline   Reply With Quote
Camaro - Abu Dhabi - 12AM - 33C⁰ Camaro_AbuDhabi Camaro Photos | Spyshots | Video | Media Gallery 7 05-22-2010 05:34 PM
Chevrolet Camaro Stars On Bin Hamoodah Automotive's Abu Dhabi Show Stand camaro5 5th Gen Camaro SS LS LT General Discussions 9 12-03-2008 09:33 PM
