Old 05-22-2010, 10:50 PM   #1
IamLliw
IamLliw's Avatar
Drives: 2010 2LT RS Camaro
what's better? turbocharger or supercharger?
i know this might have been asked before...but I really don't want to go searching for it cause I just woke up.
i was wondering what's better for a V6. a twin turbo like jay leno or a supercharger.
i am not too sure bout the differences between the two. could someone explain it to me?
thank you! =)
IamLliw is offline   Reply With Quote
Old 05-22-2010, 11:05 PM   #2
SA CHEVY
"HILLARY"
SA CHEVY's Avatar
Drives: "HILLARY" :D
Well at the So Cal meet they had in April they ran all the supercharged Camaro's and a turbocharged Camaro as well and the numbers showed that the turbo had better numbers simply because they are more efficient (as far as not loosing any power due to the extra belt etc) but these were V8's running them not the V6 however that shouldn't affect the results of how they would fare with each other again.
2010 Camaro SS2 L99 Aircharger, Straightpiped, DT long tubes, Dyno tune by Cal Speed
384 HP & 392 Ft/Lbs. 13.203 @ 107.13 mph at Camaro5FestII
SA CHEVY is offline   Reply With Quote
Old 05-22-2010, 11:17 PM   #3
khabboub
Tampa Gulf Coast Family
khabboub's Avatar
Drives: 2010 Black Camaro 2LT M6
this is the turbo vs super charger argument in a nut shell:
a turbo is better for high speed boost, the power from a super charger is available throughout the entire rpm range. if you want reliability then you should go with a super charger, if you want better gas milage you should go with a turbo.
in all reality if you dont care about spending more money on gas then a super charger is better because they last a lot longer, and are less prone to breaking down.
khabboub is offline   Reply With Quote
Old 05-22-2010, 11:28 PM   #4
Mr CLuTcH
Always On Kill!
Mr CLuTcH's Avatar
Drives: S.I.M. SS
thank you! =)
TURBO FTW.......
Fastlane Performance Turbo Package for the SS ran....10.86 @127 MPH during the LSX shootout. That's with 585rwhp, with a L99. All that for 9k FLAT. Can't be that.
S.I.M. SS(L99):
*American Racing Headers (LT)
*Magnaflow cat-back competition exhaust
*K&N typhoon CAI
*Aggressive cam.
*Tune
**Result**: 465rwhp/ 447rwtq. Satisfied.
Mr CLuTcH is offline   Reply With Quote
Old 05-23-2010, 12:32 AM   #5
Lucky SOB
Drives: 2010 Camaro 2SS/RS
Do some reading, don't make your decision off what a bunch of guys on the internet told you. Find out how a turbocharged or supercharged system works first.
Lucky SOB is offline   Reply With Quote
Old 05-24-2010, 01:49 AM   #6
8cd03gro
Drives: 2005 STi corn fed
If properly setup, a modern turbo system > blower. It's simply a more efficient design and with the right compressor sizing turbo lag is non-existent.
8cd03gro is offline   Reply With Quote
Old 05-24-2010, 04:24 AM   #7
esfkotaro
Drives: 2010 Camaro LS M6, Black with CGM
Better turbo technology has certainly REDUCED turbo lag significantly, but whenever you're using a turbo lag WILL be present. How much, depends on the setup of course, and can be greatly reduced...but the less lag, generally, the less power as well. Typically, people using power adders are doing it for exactly what the topic name implies...adding power. So a tiny turbo that has nearly unnoticeable amounts of lag most likely isn't going to make the power the owner wants.
I do agree that the turbo is a more efficient design, though.
In the end it all comes down to preference. In my experience, turbos can add mind blowing power. The problem lays in the initial lag, and then the sheer suddenness of the onset of the power (sudden large increase in power = more shock to driveline components). Though recent technological improvements have made this less of a factor, turbos also tend to be less reliable than their belt-driven counterparts. Turbos can also be more difficult to tune for, imo. Also, turbo's don't mix that fantastically with manual transmissions, since they pretty much lose all boost with every shift, having to spool again after gear engagement. If you're gonna go turbo, you'll wanna have either an auto-tranny, or a well programmed no-lift-shift feature and a lot of confidence in your shifts.
Superchargers, on the other hand, don't seem to make the same kind of efficient power that turbos can (since by their very design they're parasitic to the engines power, using a good portion of the engine's power output to compress the incoming air.) Personally, I find SC's easier both to maintain and to install. Being the kinda guy that feels awkward with an auto, the SC is a better fit for me and my M6 because it's not going to bleed off boost every time I back off the throttle to shift.
Like I said, it all comes down to preference, and it's probably obvious where my preference is. Something about the whine of a supercharger gets me all giddy
2010 Camaro LS M6, Black with CGM Stripes
MRTv2 :: Injen CAI
Factory Spoiler Added
Coming soon (end of summer, hopefully):
JBA Shorties :: Hurst or MTI Shifter (undecided)
New 20" Wheels (undecided) :: Fogs :: GFX :: CF Heat Extractor hood :: Painted-On CGM Stripes :: G-2 Painted Calipers :: Painted Bowties
esfkotaro is offline   Reply With Quote
Old 05-24-2010, 09:24 AM   #8
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Sequential twin turbo ftw!
Old 05-24-2010, 10:59 AM   #9
MontyCarlo
MontyCarlo's Avatar
Drives: 2010 2LT/RS auto IBM
I vote for whichever one actually comes into existence. These cars have been out for over a year now and we still don't have anything better than "nearly finished" prototypes.
FAQs:
1. No, I do not have any strong opinions about the Monte Carlo.
2. Yes, I know what my name looks like.
3. Yes, but the medication helps immensely.
2LT/RS IBM/gray #21,895 ordered April 21st, delivered July 3rd
MontyCarlo is offline   Reply With Quote
Old 06-08-2010, 10:57 PM   #10
verboten
Drives: Black
Turbo has better handling due to lower center of gravity.
verboten is offline   Reply With Quote
Old 06-08-2010, 11:04 PM   #11
Eleven Charley
Eleven Charley's Avatar
Drives: White 2010 Camaro 2ss
Eleven Charley is offline   Reply With Quote
Old 06-08-2010, 11:11 PM   #12
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
thank you! =)
Hey, when you wake up do the search. There are tons of thread on this topic.
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
Stock L99 A6 Supercharger options, opinions, & experiences 2010 Bumblebee Forced Induction - V8 106 07-14-2014 05:17 AM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 03:11 AM
Supercharging options available from BMC Performance! Curt@BMCPerformance Forced Induction 17 02-18-2010 08:17 PM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 10:05 PM
