Old 10-18-2008, 09:42 AM   #1
Fast1
Fast1's Avatar
Drives: 2010 Summit White SS
Can you S/C an active fuel mgt engine?
When I was considering a new Challenger, I noticed that with the 5.7 (active fuel mgt system) supercharging is out. Now, researching the L99 vs the LS3, I see the L99 has afms. Can this type of engine be s/c?
Fast1 is offline   Reply With Quote
Old 10-18-2008, 10:15 AM   #2
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
yes... since you're going to have to be in the computer system, anyway, to adjust your VE, fuel and spark tables, simply have the tuner turn that option off... this will, however, deactivate the AFM and you will be running on all 8 cylinders all of the time... but if you're adding a blower to a car, are you really worried about fuel economy?
got tequila?
SilverTurtle is offline   Reply With Quote
Old 10-18-2008, 10:50 AM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
turtle... you just told him yes.... then no.
he wants to know if you can still run a s/c without having to deactivate AFM.
im fairly certain you could, but it would take a donkey butload of tuning, and you'd probably need a BOV so you arent pumping 8 cyl worth of air into 4 cyl
I piss excellence
and fart awesomeness
Old 10-18-2008, 11:34 AM   #4
Mr Twisty
Mr Twisty's Avatar
What is BOV?
I'm assuming AFM still runs air thru de-activated cylinders, but without fuel/compression/plug fire,...Is this correct? Haven't read up on it since I'll be going with LS3
-- Benjamin Franklin
Old 10-18-2008, 11:58 AM   #5
Evotion
Warehouse 13 Survivor!!!!
Drives: '13 ZL1 - 69' Camaro
What is BOV?
BOV = Blow off valve.
Evotion is offline   Reply With Quote
Old 10-18-2008, 12:14 PM   #6
CamaroSpike23
Truth Enforcer
What is BOV?
Blow Off Valve
nope, the cylinders keep pumping, but the intake and exhaust valves are shut down along with the fuel to those cylinders.
keeping the air still in there allows for the compression to help push the pistons back down so it isnt just getting force from one side and free spinning on the other. it just doesnt fire the spark, it just keeps compressing and expanding the air thats in there already
I piss excellence
Old 10-18-2008, 12:59 PM   #7
Mr Twisty
Mr Twisty's Avatar
Blow Off Valve
Gotcha...What signals (conditions) does the computer use to activate AFM mode? Intake vacuum? speed vs. throttle position? etc.
Old 10-18-2008, 01:07 PM   #8
CamaroSpike23
Truth Enforcer
that and load on the motor. AFM is only activated during periods of low load on the motor, like cruising
I piss excellence
Old 10-18-2008, 03:14 PM   #9
Mr Twisty
Mr Twisty's Avatar
OK I'm with ya. I don't think a BOV would work, when AFM condition is met, 4 cylinders deactivate, blower goes from 3lb to 6, BOV opens, reduces pressure to an unpredictable pressure. Unless there was a way to control the valve to reduce pressure exactly 50% each time AFM kicks in...That make any sense?
Old 10-18-2008, 03:40 PM   #10
CamaroSpike23
Truth Enforcer
well, BOVs dont just dump all the pressure, if you set it to say 4lbs, and you surpass that, it will bleed off the pressure till it gets back down to 4lbs then it will close allowing you to stay at 4lbs... or whatever you decide to run.
I piss excellence
Old 10-18-2008, 04:05 PM   #11
Mr Twisty
Mr Twisty's Avatar
I understand. Problem is I'm seeing a fatal loop in the ecm...AFM kicks in, 4 active cylinders rise to 6 lb boost, exhaust gas goes lean, ecm compensates and richens fuel, car accelerates and kicks off AFM. Am I headed in the right direction?
One thing doesn't make sense here...If the valves are constantly closed during an AFM event, wouldn't that create much more energy loss than allowing valves to open and cycle air thru the cylinders? Closing the valves is like blowing up a balloon, cycling air thru the cylinders is like blowing thru a straw.
Does anyone have a good article on AFM operation?
Old 10-18-2008, 04:18 PM   #12
CamaroSpike23
Truth Enforcer
but when it goes past 4lbs of boost (since we are using that for our reference) the BOV will drop the boost back down to 4lbs. and if its tuned correctly the extra 2lbs wont do much even during the switchover.
but it will take some work and practice messing with the tune tables to get it working correctly.
I piss excellence
Old 10-18-2008, 04:51 PM   #13
Mr Twisty
Mr Twisty's Avatar
Thought thru the constantly closed valve situation, it makes sense that downstroke will regain energy lost in compression. I'll think on it later I gotta go to work, can't rub my belly and chew gum at the same time lol. Pass on any good afm articles if ya got em tho.
The more I consider it I'd love to have a blown L99 that would get 30 mpg!
Old 10-18-2008, 05:03 PM   #14
CamaroSpike23
Truth Enforcer
there's already a bunch of articles here. just do a search.
I piss excellence
New 4.5 L Duramax Diesel V8 for light duty pickups Scotsman General Automotive + Other Cars Discussion 8 12-01-2008 07:21 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 07:16 PM
Gas engines: Here to stay Mr. Wyndham General Automotive + Other Cars Discussion 0 05-05-2008 04:34 PM
