sjm autoprod
Old 10-18-2008, 10:46 AM   #1
02bluess
Camaro Addict
02bluess's Avatar
Drives: 2014 Camaro ZL1 SIM A6
No Lift Shifting on Camaros??
Do we have official confirmation on the presence/absence of no lift shifting on 6M equipped Camaros?
I've seen confirmation on the presence of Launch Control, but haven't been able to find anything definitive on No Lift Shifting?
Paul...
02bluess is offline   Reply With Quote
Old 10-18-2008, 10:59 AM   #2
fredl11
Drives: 2000 TT SS Camaro
Question HUH??
Whats NLS???
OH wait!
Do you mean powershifting without using the clutch??
Proud Owner of:
TT 2000 SS Camaro: 486 RWHP 493 RWTQ SOLD :(
1997 Silver C5 Destroyed Replaced with 2002 Z06
Daytona Sunset Orange 06 C6 Waiting for C7
2005 Sunset Orange Colorado Replaced with 2010 GMC Sierra SLE
fredl11 is offline   Reply With Quote
Old 10-18-2008, 11:09 AM   #3
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
Originally Posted by fredl11 View Post
Whats NLS???
OH wait!
not quite... on the Cobalt SS, for example, you can keep the gas pedal floored and then just lift the clutch to shift gears... the engine hangs at redline, without bumping off of the rev limiter, and you shift as fast as you can into the next gear... hence the name "no lift shifting"
this question was asked in Indy and I believe the answer was "no, it will not have that option"
got tequila?
SilverTurtle is offline   Reply With Quote
Old 10-18-2008, 11:18 AM   #4
DET MUSL
Let's Go Wings!
DET MUSL's Avatar
Drives: 2005 Cobalt SS/SC
Really I think the only reason there's no lift shifting one the Cobalt was to maintain boost between shifts.
Current Ride
2005 Cobalt SS/SC
Mods:
GMPP Stage 2
K&N CAI
Vibrant Racing Muffler
Carbon Fiber Hood w/ SS style scoop
Black Wheels
Best 1/4 Mile Time
13.8 @ 101.4mph
DET MUSL is offline   Reply With Quote
Old 10-18-2008, 05:11 PM   #5
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
I'd rather not have it (or launch control) honestly. Kinda glad the Camaro doesn't have it.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 10-18-2008, 06:11 PM   #6
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
just because it has it doesnt mean you have to use it, unless you dont want to get smoked by a guy who can use them to be consistant
headpunter is offline   Reply With Quote
Old 10-18-2008, 08:06 PM   #7
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
Only comes into play in bracket racing. Not everyone is a bracket racer.
No lift shift with an LS3 and 20s means you'll still blow the tires off between gears. On a drag radial, that might be a different story. On a drag radial, I might want to ping the red for a split between gears to get into the right part of the torque curve in the next gear. I'd rather not have the car cutting into the throttle while I'm racing, thank you.
Launch Control is great on stock AWD cars. Those cars will hook consistantly every time. However, for everyone else, unless it's adjustable, it's useless. Launch rpm depends a lot on your tires, the track prep, and the conditions. GM's arbitrary rpm for "ideal launch" isn't really ideal at all.
Old 10-19-2008, 03:21 AM   #8
2KZ28_For_Now
SS Shotgun Ride?!??! :-)
2KZ28_For_Now's Avatar
Drives: 2000 Z28
well, launch control is also a great training aid for those trying to dial-in their 1/4 times. Once you hit time within 3/10ths to 5/10ths of each other, time to disengage the LC and try manual launches.
FUN!!!!
As far as NLS, I think anyone can bang the next gear without hitting the clutch if they sense the timing perfectly. The revs have to be just right. I've done it before, in a worn out 4-banger, and a 2-stroke motocross bike.
If there's a computer nannie that helps with this, that's cool. but apparently it wont be available on the Maro.
Sooooo. it will put me back to square one. Learn the manual with a car that has enough torque and HP to be forgiving of rookie mistakes.
I, for one, will be concentrating solely on rev-matching downshifts, and no-clutch upshifts. (road track driving style, not 1/4 mile).
I guess I picked one heck of a car to learn with.
Hopefully I wont chew any gear teeth in the process... or grenade any tranny's - or pop any rear diffs........
LT LS RS SS LS3 **LSA-Z28 (Skip the body kit)**
2KZ28_For_Now is offline   Reply With Quote
Old 10-19-2008, 04:57 AM   #9
Jamestwilliams
junior member
Drives: Grand Am
FUN!!!!
I've done clutchless shifting all the way up through the gears but I have never been able to go down with out the clutch, though I can heel toe and rev match (very effective for stopping in unfavourable conditions ie snow.)My old man could go up and down through all the gears without using the clutch, although when the trany had to be pulled from that car the gears were blue.
Jamestwilliams is offline   Reply With Quote
Old 10-19-2008, 11:43 AM   #10
02bluess
Camaro Addict
02bluess's Avatar
Really, you guys are powershifting without the clutch??
At the track, I've always powershifted by keeping my right foot planted on the gas and quickly hitting the clutch/shifting... Works great as long as you don't miss the 2-3 and bounce off the limiter.
My understanding of the NLS would be that you would do the above and it would hang at redline until you engage the next gear, rather than boucing off the limiter and ruining the run if you miss (along with kissing valves off the pistons, etc)....
Make no mistake... I'll still powershift at the track without NLS, but I thought it sounded like a pretty cool feature. Too bad we won't get it :(
Old 10-19-2008, 03:51 PM   #11
383ss
Drives: 1985 IROC, 2011 Camaro
you can NOT 'powershift' without the clutch. powershifting refers to shifting during WOT, while using the clutch.
you can run through the gears at low speed and low RPM without the clutch though.
383ss is offline   Reply With Quote
Old 10-19-2008, 04:02 PM   #12
headpunter
headpunter's Avatar
Drives: Man
lol wut?
Old 10-19-2008, 04:16 PM   #13
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
lol wut?
Yes. At certain rpms, you can shift gears without the clutch because the gears will be spinning at almost the same speed and the synchros will absorb the difference. It can be done, but it's harder on the trans than people think.
Old 10-19-2008, 04:46 PM   #14
headpunter
headpunter's Avatar
Drives: Man
i said lolwut because i knew you could do it
Real paint on real Camaros - Color options - 9 of 10 so far rolnslo Camaro Photos | Spyshots | Video | Media Gallery 96 02-27-2009 06:50 PM
Camaro's lineup? .Hack 5th Gen Camaro SS LS LT General Discussions 66 10-13-2008 08:06 AM
80,000-100,000 Camaros per year Txturbo Camaro Price | Ordering | Tracking | Dealers Discussions 28 08-17-2008 12:44 AM
LA Times: Design Changes Delay Camaro's Return to the Muscle-Car Race JustinZS 5th Gen Camaro SS LS LT General Discussions 36 04-01-2008 06:15 PM
