tandtperformance.com
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 05-26-2010, 01:06 PM   #1
Santos
Santos
Santos's Avatar
Drives: 1SS Blk 6M
Wink no weeds as a temp fix?
so I really like loud cars which is why i really want to finish up my exhaust setup right now it is just hushpower axle backs, but plan on kooks 1 7/8 LT catted and H pipe but i am really impatient and want to just get the no weeds because its cheaper right now. So i need everyones input on what you would do.
380whp and growing
Santos is offline   Reply With Quote
Old 05-26-2010, 01:09 PM   #2
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT (2SS/RS)
I have noweeds and love them, I have corrupted my fellow camaro buddies and now they are getting them too...it really makes the car sound vicious....not that, that is a bad thing
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 128Mods: CAI CAI, Emblempros Dash Plaque, R/C Lic. Plate, Fbodfathers signature, AAC SMD SML, AAC P13 LED DRL, TF center console, Full dash ABL, Noweed Exhaust Diverters, Heritage Grille, Door Projectors, 20watt LED reverse lights with strobe features, S.S. black billet grille with air scoops, custom designed engine cover, custom designed "BLACKOUT" cross drilled / slotted rotors, Borla S-type exhaust, Elite Engineering oil catch can, Nitto Invo Tires WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 05-26-2010, 03:36 PM   #3
Santos
Santos
Santos's Avatar
Drives: 1SS Blk 6M
is there any hp advantage i will see
380whp and growing
Old 05-26-2010, 11:12 PM   #4
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
IIRC there was a 15hp gain with the open headers
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa, MSD Wires, MGW Shifter, Street slayer clutch, Tick braided clutch line & speed bleeder, DSS 1000hp ds & 1400hp axles, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Powerhaus Performance tuned.
BigMatt is offline   Reply With Quote
Old 05-27-2010, 10:24 AM   #5
Kendell347
Doc
Kendell347's Avatar
Watch the install video on noweed.net, at the end they show you the results of the dyno run. Or you can call and ask for Steve K., he's a great guy.
Old 05-27-2010, 02:47 PM   #6
Albion
Albion's Avatar
Drives: IOM 1ss
When the exhaust diverter is open i noticed the noise 'vibration' coming back through the car also 'Butt Dyno' tells me that it has lost torque low down,as opposed to the exhaust being closed.However,the superb sound emitted far outweighs its negative points.
Albion is offline   Reply With Quote
Old 05-27-2010, 10:17 PM   #7
pnyklr
Drives: A Gift From My Wife
We need someone to independently test it on a dyno. Closed pull, half open pull, and a fully open pull.
Any takers?
-Funk
pnyklr is online now   Reply With Quote
Oil Temp gauge - low oil temp! andyscozz Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 8 05-11-2010 09:20 AM
Lower temp thermostat? White_Knuckle_Tight 4th Generation Camaros 10 04-16-2010 07:30 AM
Normal coolant temp? SirZoltan 5th Gen Camaro SS LS LT General Discussions 4 03-07-2010 07:34 PM
What is the 4th gauge in a MN6 2SS? (not a tranny temp, like an auto) MajikMD Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 7 07-18-2009 07:55 AM
SECOND GEN WATER TEMP GAUGE INACCURATE 79ZRAG 1st & 2nd Generation Camaros 9 05-30-2009 05:13 PM
