Old 10-19-2008, 04:07 PM   #1
ttazzijr700
Drives: 2010 1SS/RS L99
Swapping summer for winter tires
Does anyone know if 18" wheels and rims would work on a camaro ss wich comes with 20". I was thinking about buying a cheap set of rims and winter tires to put on during the winter. and Does anyone knwo the cost of some cheap set of those tires and rims and the cost of taking 4 tires off and putting 4 different tires on? Thanx
ttazzijr700 is offline   Reply With Quote
Old 10-19-2008, 04:09 PM   #2
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
....as long as the OD of the tire is the same, it doesn't matter what dia. rim you use. Just make sure you use 15" rims with 15" tires, 16" with 16", etc. a.n.
patriotpa is offline   Reply With Quote
Old 10-19-2008, 04:11 PM   #3
ttazzijr700
For sure. Do u happen to knwo the prices i mentioned?
Old 10-19-2008, 04:16 PM   #4
patriotpa
Rims: Junkyard, maybe $15 each for steel. Snow tires should cost ~$65 for cheap ones.
Old 10-19-2008, 07:53 PM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
I'm not sure 18" will fit on a SS because of the Brimbo calipers. I read somewhere that someone had sat down and figured out that based on the rotor size, caliper dimensions, and required clearance for the calipers to work correctly, that it comes really close to 18" and that there is a very good possibility of rubbing. I would definitely wait until the car comes before making any decisions.
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 10:51 AM
are there any 20" all-weather tires out there? card21doc Wheels and Tires Talk Sponsored by The Tire Rack 11 01-15-2010 08:11 PM
First Decline in Summer Gas Consumption Since 1991 GTAHVIT General Automotive + Other Cars Discussion 10 04-22-2008 10:58 PM
new pictures on these See through tires . . . Camaro68 General Automotive + Other Cars Discussion 19 04-09-2008 02:33 PM
Possiblility of sightings this summer The_Stache 5th Gen Camaro SS LS LT General Discussions 15 07-17-2007 06:07 PM
