Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Suspension / Chassis / Brakes Suspension, chassis, and brake components
Old 05-27-2010, 06:28 PM   #1
AutoAgenda
AutoAgenda's Avatar
Drives: 69 Camaro, 02 Escalade, 67 Eleanor
Arrow BC Racing Coilovers 2010 Camaro Ultimate Performance | Ship Same Day| Best Price GTD!
Auto Agenda is proud to announce Full Set of 4 BC Racing Coilovers for the 2010 Camaro are in stock and shipping today! The BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All the systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system. This system comes direct from the manufacturer and is not re-branded which eliminates the mark-up enabling the low price of $999.99 for Complete System of Four w/ all essential hardware & Free Shipping!
Full Set of Four Coilovers with Essential Hardware Included
Compatible with both V6 and V8 models. Spring rates for the Coilovers are 8kg/mm and 10kg/mm metric, or 447.97 lbs/in and 559.97 lbs/in standard.
The BR series coilovers use a large 46mm diameter piston in a 53mm diameter damper body to maximize oil capacity. As the damper unit operates, the oil within heats up. The viscosity of oil changes as its temperature varies which can lead to changes in the damping characteristic of the unit. BC Racing only use a very high quality oil which their coilovers but go that extra mile to maximize performance and build their BR ranger with a large 53mm diameter damper body. This increases the capacity of the unit which increases the volume of oil contained which in turn reduces the peak temperature and so significantly improves damper performance.
BR coilovers feature 30 way damping adjustment that combines both rebound and compression in one adjuster for simplicity and ease of use. This adjustable facility allows you to fine tune the vehicle to meet the relevant conditions.
Damper units are black chromed steel to give superb durability even through the darkest of winters. The aluminum components (top mounts, locking collars etc) are anodized and the steel lower mounts go through an electrophoretic disposition process followed by powder coating. A random selection of steel components (brackets, dampers, screws etc) are put through a salt spray test once a month to check the quality of the protective processes and that anti corrosive properties are kept at the highest possible standard.
Camaro5 Member Installation Review Link
Planet LSX Review & Installation Instructions Link
Auto Agenda is proud to be a long standing BC Racing Authorized Dealer with the highest level of warehouse distribution. We have been stocking BC Racing kits for the Pontiac GTO and G8/GXP. Due to popular demand, we were the First BC Racing Dealer to offer “Front Only Kits” as many customers did not want to disturb their custom set-ups in the rear of their vehicle. If Camaro5 members are interested in BC Racing Front Only Kits please PM for details!
BC Racing has informed us their 2010 Camaro Coilovers are in stock and ready for shipment straight from the manufacturer. Meanwhile, we have inventory coming directly to our warehouse so we may offer “Same Day Shipping” in the near future.
Best Prices GUARANTEED!
-Auto Agenda Retains The Highest Level Of Distributorship Offering The BEST Prices!
General
● Mono-tube shock design
● 30 levels of damping force adjustment, adjust compression/rebound
● Pillowball mounts and adjustable camber plates included (where applicable)
● Adjustable rear camber plates available
● Separate full length height adjustable
● One year warranty
● Rebuildable
Technical
● Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
● Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
● Patented concave lower locking ring, to prevent unseating.
● Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation.
● T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
● Iron lower brackets on MacPherson struts to ensure rigidity.
● Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
● High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
● 2 step coating process utilizing nickel and chromium plating to prevent corrosion.
● Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
● An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
Order Here: http://autoagenda.com/2010-camaro-bc-racing-coilovers
AutoAgenda is online now   Reply With Quote
Old 06-02-2010, 01:19 PM   #2
AutoAgenda
AutoAgenda's Avatar
Thanks for the orders so far! All orders sent out with tracking information!
PM or Post w/ Any Questions!
Complete Set of Four Coilovers: http://autoagenda.com/2010-camaro-bc-racing-coilovers
Customer Photos:
Old 06-03-2010, 09:05 AM   #3
madmaxx18
madmaxx18's Avatar
Drives: 07_tundra/2010_IBM_2ss/rs/sc
I was wondering where is all your testing data to show us how well these perform. I would like skid pad numbers track numbers. Maybe some videos to tell us the customer why by your product over the competition. I just would like some sort of info other than the specs of the springs.
madmaxx18 is offline   Reply With Quote
Old 06-03-2010, 01:26 PM   #4
AutoAgenda
AutoAgenda's Avatar
We will certainly get some more tech data for everyone. In the meantime here is a video of a good drag run! His mods are Halltech CAI, Dynatech Headers, BC Racing Coilovers, Nitto NT05R Drags.
2010 Camaro SS Bolt Ons 12.587@111.32
Old 06-07-2010, 11:14 PM   #5
AutoAgenda
AutoAgenda's Avatar
Shipped! Tracking Information Updated!
PM for Price!
Old 06-09-2010, 06:18 AM   #6
AutoAgenda
AutoAgenda's Avatar
Offer Still Available! First Three Willing To Do A Write-up Will Receive These Coilovers At Cost!
Reveiw consists of before and after photos. Install photos if possible and one page on performance! PM to be the First!
Old 06-11-2010, 06:10 PM   #7
AutoAgenda
AutoAgenda's Avatar
Two Camaro5 members doing write-ups and we need one more!
PM if you would like to take advantage of this offer!
Old 06-13-2010, 08:28 AM   #8
madmaxx18
madmaxx18's Avatar
Since your asking us for reviews could you post up your performance capabilities of this kit. For example skidpad numbers or track performance that can be expected.
Old 06-15-2010, 02:37 PM   #9
gman1227
Drives: Pontiac G8
how much drop does these coilovers give? for the g8
gman1227 is offline   Reply With Quote
Old 06-17-2010, 05:22 PM   #10
AutoAgenda
AutoAgenda's Avatar
The G8 Kit will be out next month, and should have the same drop as the 2010 Camaro System which is a little over 2-1/2'' Each system also comes with some custom chamber adjustment.
Old 06-18-2010, 12:46 PM   #11
AutoAgenda
AutoAgenda's Avatar
IN STOCK AND SHIPPING TODAY! UNBEATABLE COILOVER PRICES!
Old 08-10-2010, 04:59 PM   #12
AutoAgenda
AutoAgenda's Avatar
The G8 GT/GXP BC Racing Coilovers were released this Friday (08/06/2010) in limited production numbers!
Under 15 available! Order now to apply Group Purchase Coupon: G8
Old 08-14-2010, 11:13 PM   #13
AutoAgenda
AutoAgenda's Avatar
We appreciate the orders! Great feedback so far, will be posting some customer reviews shortly!
Old 08-16-2010, 01:28 PM   #14
AutoAgenda
AutoAgenda's Avatar
Bump!
Old 08-18-2010, 11:20 AM   #15
Rockin the BlueSS
The New Guy
Rockin the BlueSS's Avatar
Drives: 2010 2SS/RS IBM M6
how much? for a kit (including the remote adjuster knobs and the camber adjusting plates)
pm me.
Thanks
Rockin the BlueSS is offline   Reply With Quote
Old 08-25-2010, 03:03 AM   #16
AutoAgenda
AutoAgenda's Avatar
PM Sent!
Old 08-26-2010, 05:09 PM   #17
AutoAgenda
AutoAgenda's Avatar
All Orders Shipped w/ Tracking Updated! Thank you!
Old 08-28-2010, 01:08 AM   #18
AutoAgenda
AutoAgenda's Avatar
Old 08-31-2010, 06:54 PM   #19
AutoAgenda
AutoAgenda's Avatar
All Order Sent w/ Updated Tracking Information!
Old 09-01-2010, 01:37 PM   #20
AutoAgenda
AutoAgenda's Avatar
PMs Sent!
Old 09-01-2010, 10:06 PM   #21
AutoAgenda
AutoAgenda's Avatar
PM for Best Prices!
Old 09-02-2010, 02:26 PM   #22
AutoAgenda
AutoAgenda's Avatar
Great Reviews! Keep them coming!
Old 09-09-2010, 05:33 PM   #23
AutoAgenda
AutoAgenda's Avatar
PM for Prices!
Old 09-12-2010, 01:00 AM   #24
AutoAgenda
AutoAgenda's Avatar
Orders Sent w/ Tracking! Thank you!
Old 09-13-2010, 10:41 AM   #25
Penaw001
Penaw001's Avatar
Drives: None
I would like to know price? PM please.
Penaw001 is offline   Reply With Quote
2010 Mongoose Performance Camaro Tran 5th Gen Camaro SS LS LT General Discussions 62 11-23-2012 12:20 AM
Remote Reservoir Seperate Bound and Rebound Adjustable 5th Gen Coilovers JusticePete Suspension / Brakes / Chassis 144 12-07-2011 03:50 PM
BC Racing Coilovers 2010 Camaro | $75.00 Gift Certificate w/ Purchase! AutoAgenda Suspension / Chassis / Brakes 5 06-21-2010 08:13 PM
Pedderizing the Nickey Camaro! Pedders coilovers / suspension fitted & tested. DallasMike Wheels and Tires Talk Sponsored by The Tire Rack 57 06-15-2009 04:36 PM
