SDTW Custom Wheels & Tires
Old 05-31-2010, 08:55 PM   #1
Supercharged SS
Drives: 2010 Camaro
Slick vs Drag Radial = no improvement
Just wanted to post this quick so you guys would no what the deal was. The car being used is an A6, still with the L99,(no ls3 conversion), TVS 2300, stock gears and converter. The car makes 550 rwhp/ 550 rwtq. With the 18" M & H drag radials the car cut 1.60 to 1.67 60's every time out. I changed over to 17" Bogarts with a 28"x10" Hoosier Slicks and the car still only cuts a 1.65 60'. 11 attempts with both set-ups. I think the problem is that I can't leave any harder than 1450 rpms otherwise the car pushes itself down the track. I mean literally. With the front tires completely locked, the car will push itself forward. It happened a lot at Jannetty's rental this past Friday. So I would say that unless you have a stall don't waste your money on a 17" set-up. Its just not worth it when for half the price you can do just as well, if not better. Best of luck fellas!
Old 05-31-2010, 08:58 PM   #2
cmiller8006
Drives: 2009 Cobalt SS/TC
Its because of the stock stall. But once stalled them bias ply sidewalls will take alot of the cars beating not transfering it to the drive line like radial tires will.
2009 Cobalt SS/TC: 10.89 at 133mph
cmiller8006 is offline   Reply With Quote
Old 05-31-2010, 09:12 PM   #3
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
did you gain any mph? the rolling weight should have helped. what's the best it ran? post the slip maybe?
94guy is offline   Reply With Quote
Old 05-31-2010, 09:20 PM   #4
Supercharged SS
Drives: 2010 Camaro
The car ran between 11.0 and 11.2 @ 122-124 mph. No improvement anywhere. That's why no slips, nothing gd to show. The temps were 35 degrees warmer than the last time so that didn't help. I know the converter is the culprit. It's holding the car back. Well it did until this week,
Old 05-31-2010, 09:42 PM   #5
jrpxxii
jrpxxii's Avatar
So you wanna sell your bogarts?
Old 05-31-2010, 09:46 PM   #6
Supercharged SS
Drives: 2010 Camaro
I can't. I'm just going to get a stall and put them to the test. You should just order a set. They make them pretty quick.
Old 05-31-2010, 09:53 PM   #7
Jchaluja
Jchaluja's Avatar
Drives: Twin Turbo Camaro
what type/size of stall are you planning to get?
Jchaluja is offline   Reply With Quote
Old 05-31-2010, 09:57 PM   #8
AmericanMuscle4.6GT
Drives: 2005 Mustang GT M5
yea your stock converter is what's killing you.......you need to be able to launch a lot harder to make use of that extra grip.
may i suggest..........3200 stall and a transbrake?
2005 Mustang GT
JLT2 CAI, Brenspeed 93 tune, Boomtube Axlebacks, Lowering Springs, Lakewood Panhard bar/brace.......296 RWHP/315 RWTQ
12.883@106.56
AmericanMuscle4.6GT is offline   Reply With Quote
Old 05-31-2010, 09:58 PM   #9
Supercharged SS
Drives: 2010 Camaro
Not sure yet. Prob at least a 3k or 3200. Not sure yet on a single or triple or the str. I plan on making some calls in the am.
Old 06-01-2010, 09:47 AM   #10
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Drive a 4000-4200, really before you go with a small 3k stall. They're plenty bearable and with a lockup clutch drive the same on the highway.
Add a trans cooler!
Ovenmitt is offline   Reply With Quote
Old 06-01-2010, 01:34 PM   #11
toehead93
Drives: 2014 2SS/1LE
Keep us informed with your finding on the torque converter options. I'm curios to see more pros and cons for the multi vs single disk setups. I also have found that alot of manufacturers don't give the STR in the specs. I only found this info for Yank and Vigilante.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 06-01-2010, 04:43 PM   #12
cmiller8006
At least a 3600.
Old 06-01-2010, 05:27 PM   #13
Supercharged SS
Drives: 2010 Camaro
3600 is way to high for my car. It would def blow the tires off. I don't think it would hook very well with anything above 3k. Jannetty suggested a 2200. I have a call into pro torque. Just waiting now but they claim to have a hot setup for the 2010 camaro.
Old 06-01-2010, 05:45 PM   #14
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Call Yank and Vigilante for some info. For one of the best knowledge bases call Neal Chance Torque Converters. A 2200 stall is very low.
This is my < .02 so take it as such:
1) Make sure the converter is still a lockup converter. That will make it 100% streetable.
2) You can never go "up" in stall speed, but you can go down. e.g. If you brake against a converter you effectively can pull it down some. We used to do this and preload the tires and drivetrain. A converter's stall speed is really based on "flashing the converter"
3) Treat your car as a total package. You will want to tune your cars launches with the SUSPENSION, not the engine or converter. There are cars that run in the 7's with IRS.
I am running a 3500/3600 stall with transbrake which is totally streetable. (and the SST has enough torque to kill a horse) You may not want to run that high, but for a whole generation the B&M Holeshot was a 2800-3200 stall converter and the Super Holeshot was a 3500 stall converter and they sold tens of thousands of these on street cars.
Once again, I want to emphasize this is humble opinion only, so call up some chassis/drivetrain pros and get their take.
LMR's Outlaw Drag Radial Car Initial Start Up Vid!! Late Model Racecraft Forced Induction - V8 17 10-19-2009 11:05 PM
Goodyear jumps into Drag Radials radz28 Dragstrip and Launch Techniques Discussion 4 09-30-2009 09:36 PM
Drag radial 69 Camaro 09 Wheels and Tires Talk Sponsored by The Tire Rack 1 05-26-2009 05:59 PM
