Old 06-01-2010, 02:57 PM   #1
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
Exclamation how to install MSD SHIFT LIGHT PART NO.8963
Installing the shift light was very easy the hardest thing about it was where do i run the wire through the firewall? Thats where i'll start theres a great thread on where to run wire through the firewall and not drill
http://www.camaro5.com/forums/showthread.php?t=83694 ( hope u dont mined the thread jack buhmblbe). After that locate the no#1 cylinder coil pack and isolate +volt wire in the coil (pink wire) and install gmr tach signal adaptor. to verify the wire simply turn key to run position and hook up a test light to it it should light up. The black wire goes to ground. the red wire goes to a switched 12 volt source (ignition fuse). then just decide where to mount the shift light. I mounted mine with double sided tape on the dash, i just didnt want to drill to the dash or a pillar cover. good luck!
moiy1983 is offline   Reply With Quote
Old 06-01-2010, 08:41 PM   #2
moiy1983
moiy1983's Avatar
Old 06-01-2010, 11:09 PM   #3
jbriggs
Drives: rjt 2ss rs
Thank you!! I will be ordering mine immediately, I'm sick of hitting the limiter...
jbriggs is offline   Reply With Quote
Old 06-02-2010, 04:26 PM   #4
loopback
SoCal C5 Family Member
loopback's Avatar
Drives: 2010 Black 1SS
sorry for the noob question but what does this shift light do?
loopback is offline   Reply With Quote
Old 06-02-2010, 04:40 PM   #5
2KWIK4U
2KWIK4U's Avatar
Drives: 1969 Camaro and 2014 Camaro vert
Light comes on at a set engine rpm to tell you at a glance when to shift for max power.
Danny
Danny
" I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I require the same from them" -John Wayne "The Shootist"
2KWIK4U is offline   Reply With Quote
Old 06-02-2010, 05:16 PM   #6
moiy1983
moiy1983's Avatar
Danny
Old 06-03-2010, 10:01 AM   #7
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
COOL!!!!! What are you guys setting your shifts at?
WICKEDSS is offline   Reply With Quote
Old 06-03-2010, 04:10 PM   #8
moiy1983
moiy1983's Avatar
every car is diffrent in my case im shifting at 6900 rpm thats when i peak.
Old 06-03-2010, 04:12 PM   #9
maybe a future mod
Old 06-03-2010, 05:09 PM   #10
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Well stock i dont really run my car to hard so have not really payed attention to when it would hit the limtr
Old 06-28-2010, 09:55 PM   #11
Merc
In The Circle
Merc's Avatar
THX Bud. Installing mine soon.
Old 09-16-2010, 08:56 AM   #12
Merc
In The Circle
Merc's Avatar
I found it easier to power shift light in fuse panel next to the driver door. Pico makes a piggy back fuse gadget.
Old 09-16-2010, 10:35 AM   #13
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
Pics please.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 12-30-2014, 02:41 PM   #14
10z4u2nv
Drives: 2010 2ss Rs
Ok So I just bought a autometer cobalt shiftlight and tach to fill my gauge pod and I have read a few different threads on the install so my question is do I really need to buy the 9117 Auto Meter tachometer adapter or can I just hook up to the number 1 coil pack harness and do away with the adapter all together? Thanks in advance
10z4u2nv is offline   Reply With Quote
Complete ******** install from a Novice Susantroy1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 07-31-2015 01:25 PM
GTECH Shift light ULTRAZLS1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 0 04-22-2010 08:36 PM
Backup Light part number? BlownSS Cosmetics and Lighting Modification Discussions 0 11-08-2009 07:02 PM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 01:49 PM
