ADM PERFORMANCE
Old 10-22-2008, 02:52 PM   #1
bret03
bret03's Avatar
Drives: 30th anniversary Z28, Jeep XJ
HELP... 97 Z won't start.
My 97 Z28 with a 6 speed wont start. All the electronics come on and seem normal but the car wont start. No clicking, no nothing. The car has had this problem for a couple years on and off but by the time I can get someone to look at it the car is always working again. I believe the problem is with the wiring/sensor that read the electronic chip in the key. I tried the other set of keys, so the key isn't the problem. I've heard the security light should come on if thats the problem but it doesn't. My other thought is that it could be a problem with the sensor that makes sure the clutch is pushed in.
Any help would be greatly appreciated!
bret03 is offline   Reply With Quote
Old 10-22-2008, 03:06 PM   #2
GamerGuyZ28
5TH GEN BURNOUTS!
GamerGuyZ28's Avatar
Drives: 95 Z28, and a 2000 Z28
I had the same problem in my '95 Z28, and it turned out to be a bad ignition switch, but be careful when checking/changing it because it got some blade-like edges on it and it will tear you fingers up bad.
Life begins at 100 MPH
GamerGuyZ28 is offline   Reply With Quote
Old 10-22-2008, 05:54 PM   #3
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
Ok, first things first.
1-get the battery tested, this is free and you never want to dump money on expensive or exotic parts when the easy stuff is a possability.
2-next test the clutch pedal position switch. it is right behind the pedal and if you unplug it and bridge the terminals in the pigtail with a paper clip you can fool it into thinking the pedal is depressed(just make sure your in nuetral before turning the key)
3-still no luck, how does chip in your key look? are the contacts ground flat with the black plastic? the "chip" is just a resistor and with no contact to the terminals in the lock cylinder the car doesn't know the key is there. a new key should run you $25 at your local dealer(try your spare key too, it may be in better condition)
4-without a volt meter the next step is either to remove your starter and have it tested or take a shot in the dark and try changing the ignition switch at the base of the column
I can tell you how to bypass the security chip if you want to know but you will need a volt meter and a soldering iron.
I hope this helps
Robert91RS is offline   Reply With Quote
Push Start button? CG'sSS Camaro DIY & HOW-TO instructions & discussions 158 06-06-2012 08:27 PM
No Push Start?!?! Why Not cabaret2 5th Gen Camaro SS LS LT General Discussions 82 02-01-2012 04:21 PM
Link to Video of interior with start up???? Cmyskill Camaro Photos | Spyshots | Video | Media Gallery 6 10-23-2008 06:37 AM
What a Great Day - Camaro orders start, DOW up 936, GM up 33% heinzd01 5th Gen Camaro SS LS LT General Discussions 17 10-14-2008 10:12 AM
Dealers Will Start Taking Orders In Oct. ckellyme3 Camaro Price | Ordering | Tracking | Dealers Discussions 1 09-04-2008 09:03 PM
