SDTW Custom Wheels & Tires
Old 06-03-2010, 01:08 PM   #1
Swytch
Swytch's Avatar
Drives: 10 2SS/RS Black, 99 Daktota
Rear End Noise when enabling/disabling TC/Stabilitrack
Hi All, I am a fairly new owner, only got 450mi on the odo. I was in the driveway the other day messing with the radio presets and car settings. When i was done with the radio i hit the traction control button and disabled TC, then hit it again and disabled stabilitrack. Then i turned all back on, then held it for the 7 secs to get launch control on. I never moved the car during this, and i did not use any of the modes (i.e. i never tried launch control, was just messing with the buttons) When i re-enabled them all there were a few small clicks from the rear end. (keep in mind the car never moved...) After turning everything back on, i pulled it forward about 10 feet into my parking spot, when i first started to go there was a loud C-L-U-N-K from the rear and then it went forward (almost like the parking brake was on) after that no noises, drove it in to work this AM and did not notice anything.
Is it normal to get noises like this when messing with the TC/Stabilitrack? or should i head to the dealer and get it looked at?
Kooks Signature Series Headers 1-3/4 stepped to 1 7/8, Kooks 3" High Flow Cats, Vararam OTR Cold Air Intake, JRE Performance Tune, RX Catch Can, RX Oil Breather, LSR Tri-Ax short throw shifter, AAC Red/White Halos and Fog Rings, AAC Knight Rider Scanner Bar
Swytch is offline   Reply With Quote
Rear end gets loose in 3rd gear??? SSMagna Suspension / Brakes / Chassis 15 08-01-2010 10:03 AM
Richmond Rear End Gears - 3.73 & 4.10 Sean@Phastek Transmission / Driveline 0 06-02-2010 11:47 AM
rear end failure? xshortd Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 04-08-2010 07:59 PM
Steering response.... CGM2SSRS Wheels and Tires Talk Sponsored by The Tire Rack 130 10-21-2009 06:04 PM
Rear end whine while under load shiftz33 5th Gen Camaro SS LS LT General Discussions 4 08-12-2009 05:15 PM
