| Suspension / Chassis / Brakes Suspension, chassis, and brake components |
| View our official forum sponsors list. |
Thread Tools |
![]() Drives: it like I stole it. Join Date: Feb 2010
Pfadt Race Engineering's newest distributor is...
![]() Apex Motorsports is proud to announce the addition of yet another great product line, Pfadt Race Engineering. The addition of Pfadt's incredible suspension components is the latest step as we strive to accomplish our mission of providing our customers with the best parts available while providing unmatched personal attention and customer service. The following products are now in stock and ready to ship with more being added daily. Pfadt Race Engineering Adjustable Sway Bar - Sport $490 ![]() Install Pfadt Sport Bars on your Camaro and you'll immediately feel more planted and in control! We've built our reputation on engineering well-balanced, performance minded suspension products and these sway bars hit the mark. Made in the USA of high strength steel, our bars provide the proper rate of stiffness and balance. Our sway bars will inspire confidence and keep you planted for the ultimate driving experience. Under-steer and the 2010 Camaro The Pfadt Camaro sway bars required major engineering changes from the factory bar package to eliminate the notorious under-steer. Basic vehicle dynamics say that to eliminate under-steer you must increase the roll stiffness in the rear of the car - our rear bar does exactly that. That's how we achieve such great balance. If a sway bar package offers huge increases in the stiffness of the front bar, your Camaro is going to suffer from increased under-steer compared to the OEM sway bars! The video below highlights some of the on-car testing that went into our sway bars. This video is a demo to show how much you can affect the balance of the car with swaybar changes. The day we shot this video, we tested a several packages which is a critical part of proving our engineering before building the product. Pfadt Race Engineering Drop Springs $330 ![]() Pfadt Race Engineering offers the ultimate solution for lowering your Camaro. Our drop springs are engineered to provide the lowered look you want and the ride quality you demand. With our engineering approach and race track testing, you can rest assured that your Pfadt Drop Springs are going to last. We use only the highest quality steel and the latest manufacturing technology. Pfadt Lowering Springs have been engineered to optimize the factory damping with a 1 to 1.25 drop and increased spring rate. Lower your Camaro more than 1.25 inches and you'll find that the factory dampers no longer work properly, resulting in a bouncy ride. Pfadt Drop Springs Feature: Engineered to optimize the factory shock absorber damping 1 to 1.25 inches of drop for the correct relation between looks and proper function Engineering design and race testing ensures the ultimate in quality and longevity Powder coated gloss silver for unbeatable looks and durability Made in the USA Pfadt Race Engineering Performance Rear Trailing Arms $235 ![]() The Pfadt 2010 Camaro Rear Trailing Arms were developed using the latest analysis software which enabled us to increase strength by 106% while simultaneously reducing mass by 17%. The decrease in trailing arm mass allows the suspension to react more quickly to the changing road surface keeping the tire in contact with the road to increase traction. Through further analysis and testing we were able to achieve a 32% reduction deflection which helps decrease wheel hop and increase traction even further. Included with this kit is our leading edge Trailing Arm Bushing Kit. Utilizing lightweight 6061-T6 aluminum sleeves that are hard anodized to create incredible surface hardness and microscopic pores to hold our special grease. These sleeves are then Teflon coated to further reduce friction. This is then coupled with our graphite impregnated polyurethane bushing which uses deep grease grooves to hold and continuously re-lubricate the surfaces for long and quiet operation. The result is an ultra lightweight, ultra-low friction joint that is 42% lighter than the OE bushing and more durable then ever before. This kit includes the bushing for both the trailing arm and also the upright for a complete performance trailing arm upgrade. The final arm is the result of four stages of precision manufacturing; CNC machining of the bushing housing, Laser cutting of the intricate panels, CNC bending and TIG welding to finish the assembly. All of this is accomplished right here in the USA. ![]() ![]() Pfadt Race Engineering Race Differential Bushings $115 ![]() Pfadt Differential Bushings hold the differential in place by replacing the soft factory rubber bushings. The kit will help protect the differential and is an absolute must for handling the added power of a super charger or high horsepower motor. Made in the USA our bushing and sleeve kit provides superior quality and durability. The sleeves are made from 6061 T6 aircraft aluminum and anodized orange. An important upgrade for dialing-out wheel hop, this kit is a great addition to any performance Camaro. The installation is involved, but the results are well worth the effort. This kit includes bushings designed for racing application. These bushings are designed to be as stiff as possible while still maintaining the ability to absorb damaging shock loading. Because of the extreme nature of this product it will transmit differential noise and is not recommended for the typical street car. Pfadt Race Engineering Street Differential Bushings $115 ![]() Pfadt Differential Bushings hold the differential in place by replacing the soft factory rubber bushings. The kit will help protect the differential and is an absolute must for handling the added power of a super charger or high horsepower motor. Made in the USA our bushing and sleeve kit provides superior quality and durability. The sleeves are made from 6061 T6 aircraft aluminum and anodized orange. An important upgrade for dialing-out wheel hop, this kit is a great addition to any performance Camaro. The installation is involved, but the results are well worth the effort. This kit includes bushings designed for performance street use. While these bushings are much stiffer then the factory bushings they still allow enough vibration absorption that differential noise is kept to a minimum. Pfadt Race Engineering Sway Bar End Links $225 ![]() Since 2005 Pfadt Racing has offered you ultimate in quality and performance with our engineered products. We engineered this system with the performance street driver and racer in mind and over the years we’ve established a reputation for performance, quality and customer service. The kit includes all four endlinks needed to mount your sway bars (2 front and 2 rear) Lighter and stronger than OEM units All four are adjustable These heavy duty endlinks Do Not require drilling out your sway bar mounting holes All hardware is included All components are very high grade materials, and high grade spherical units Made in the USA Designed and tested with the same engineering and race principles as our Corvette end links, these units offer increased strength and less weight than stock. Our end links are perfect for Camaros that will see some race duty, or have a performance goal. If you are running coil overs and have increased grip levels, our Pfadt End Links will handle the load. The turnbuckles are high strength 6061 T6 aluminum and are anodized gloss black for great looks and ultimate durability. The rod ends are teflon coated for smooth quiet operation and are studded for ease of installation, reduced part count which reduces weight. Innovating, engineering, and constantly moving forward, Pfadt will always blaze the path for new and improved suspension solutions.
![]() Drives: Wagon Queen Family Truckster Join Date: Oct 2009
I might also point out that if you are looking for the Pfadt package price deals, all you need do is add the combinations to your cart and you will automatically receive the package price discount. As always, click on the promotions link in my signature to see all the latest deals and discounts at apex-speed.com
The Pfadt packages include an automatic $20 discount on the Pfadt Sport Suspension Package: $800
![]() Or you can take it up a notch by adding the Pfadt Adjustable End Links with the Pfadt Sport Plus Suspension Package and get an additional $35 OFF! $990
So Cal Camaro5 Race Team
Drives: '10 SS/RS, '06 HHR, '70 El Camino Join Date: Sep 2009
can you PM price of both kits, thanks
TEAM L99 - So Cal Camaro5 Race Team #27
9/5/09 Purchased #36962 Black 1SS/RS L99 "E-TCKT" Base Dyno 328hp/341tq @BBK meet Mods to Date: Window Tint 5% & 15%, ACC P13W Lighting, Adaptive DRL Harness, Ghost Armor, Lloyds "SS" Mats, Dash Plaque, Flowmaster Outlaw Exhaust, Drake Front Bowtie Delete, Stealth 3457 Chrome/Mirror Signal Bulbs, Grant Revolutions Steering Wheel, PFADT Sport Springs, Sway Bars, End Links, Trailing Arms, 4 Wheel Alignment, Hurst Auto Shifter and Paddle Shifter, Satin Black Rear Tail Light Bezels |
PM sent and pricing added to post.
I have had several PMs asking if we have a particular item in stock. Eveything listed in this thread, including the packages, is currently in stock and ready to ship. Thanks.
#6 |
PMs replied to!
#7 |
![]() Drives: 2010 2SS/RS L99 Join Date: Nov 2009
Please PM a price for PFADT motor-mounts for an L99.
| Thread Tools | |
| Pfadt Race Engineering releases new Camaro V8 Engine Mounts | PfadtRacing | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 43 | 06-07-2011 12:09 PM |
| Camaro Pfadt Race Engineering Coil Overs | PfadtRacing | Wheels and Tires Talk Sponsored by The Tire Rack | 16 | 03-29-2011 09:10 PM |
| Pfadt Race Engineering releases new Camaro V8 Engine Mounts | PfadtRacing | Suspension / Brakes / Chassis | 6 | 01-15-2010 12:58 PM |
| BUDWEISER SHOOTOUT LINE UP | CamaroScotty | General Automotive + Other Cars Discussion | 22 | 02-07-2009 07:03 PM |
