| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
Maggie experts...5 lbs boost on a 3.6 pulley?
I finished installing the maggie a few days ago. Got Ted to do the tune and put it on a local dyno. Ted put alot of time in on the tune for me
I'm only @ 5lbs boost with the 3.6 pulley. I know the heat in AZ is knocking it down some. DA was 4000ft today. But 5 lbs @ 90 degrees OAT? Hell it's not even close to warm here yet. I'll be creating vacuum when temps get to 118 with a DA of 5500 ![]() Car has 1 7\8 LT's w\cats, 2.5 cat back, ADM race intake and an MSD fuel booster. Added a set of NGK plugs. Tensioner pulleys are almost touching using the belt from maggie so I don't believe its belt slip On a Dynojet.. It ran 483/505 on the first tune but we had to pull timing, 87 degrees OAT It ran 478/477 on the second tune with a Perfect AFR of 11.4, 91 degrees OAT I was 402/393 before the maggie, on the same dyno, 86 degrees OAT So....Normal? Anyone else need a 3.4 just to get 7 lbs @ 4000 DA? Could I have missed\screwed up something on the install? Do I just need to go get laid and forget about it??? Help me out guys because if installing the blower, dropping the pulley size, installing a fuel booster and getting a tune netted me a whopping 76 hp\84 tq I may have to start drinking. Very Heavily
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS L99 Join Date: Nov 2009
I think most people lose about 1lb of boost from the headers and exhaust. What does the 3.6 suppose to make.
Okie doke
It's hard to tell and compare mods to mods, but with similar mods, and the 3.8 pulley, I was putting down 6 to 6.5 lbs of boost. I am not at 4000 ft though so I'm sorry I can't help with how much of a difference that would make. Did the shop that dyno'd it have any ideas? Also, can a dyno "correct" for elevation as well to simualte what you would get at a lower elevation?
Crowley
| Thread Tools | |
| DIY : Install underdrive pulley on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 33 | 04-19-2013 11:57 PM |
| maggie 3.4 | Petersimov | Forced Induction - V8 | 22 | 06-02-2010 11:22 PM |
| who has the 3.6 pulley on their maggie? | BlownSS | Forced Induction - V8 | 29 | 05-09-2010 12:42 AM |
| Quick question on tvs pulleys | boostedyards86 | Forced Induction - V8 | 19 | 04-29-2010 09:04 AM |
| maggie pulleys/boost | drkllr | Forced Induction - V8 | 16 | 03-24-2010 06:00 PM |
