Caryle Racing
Old 12-27-2011, 04:16 PM   #1835
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
....GM needs to stop making them better...
That can be OUR job.
Old 12-30-2011, 05:45 PM   #1836
PQ
Booooosted.
PQ's Avatar
Old 12-30-2011, 07:01 PM   #1837
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Is that your new exhaust?
Old 12-30-2011, 07:07 PM   #1838
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
what are you breaking now?
Old 12-30-2011, 07:13 PM   #1839
BeckyD@JamesMartinChevy
BeckyD@JamesMartinChevy's Avatar
...prob...
Not a good thing...
Don't forget, I honor ALL DISCOUNTS THAT APPLY!
Available Inventory -James-Martin Chevrolet
BeckyD - I Deliver Nationwide!
..only 20 min from Detroit Metro Airport!
BeckyD@JamesMartinDetroit.com
ChevyFleet@aol.com
BeckyD@JamesMartinChevy is offline   Reply With Quote
Old 12-30-2011, 08:44 PM   #1840
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2012 2SS/RS LS3
NightOwl RGB Halo Kit V2, Kooks 1-7/8 LT Headers, Cam Motion Cam, CAI Intake, Catless Midpipes, Borla ATAK Catback, 35% Tint, Vinyl Gill Blackouts, RX Catch Can, Devil Tail Side Stripes, Front Lip Blackout, Dual Color Bowties, Ghosted Sidemarkers,
Exhaust Video (Manifolds) Exhaust Video (Headers) White Lightning
A.C.E.5.
xxx RWHP/xxx RWTQ
CamaroKid300 is offline   Reply With Quote
Old 12-30-2011, 11:34 PM   #1841
PQ
Booooosted.
PQ's Avatar
I put those on there to show Chris when IM wouldn't transfer it.
That's my kitchen drain and I had to completely gut the inside of the cupboards.
Old 12-30-2011, 11:39 PM   #1842
camaro2lt
camaro2lt's Avatar
question for ya pq.......how did you install your shift knob i have the same one i can not figure out to install it
camaro2lt is online now   Reply With Quote
Old 12-30-2011, 11:49 PM   #1843
PQ
Booooosted.
PQ's Avatar
Small allen head screw in front to pull the first one off. Same type allen screw to put it on. Just make sure that the spring inside doesn't snag on the pointed part of the stick.
DO NOT tighten the upper screw. it needs to just be snug but not tight, or you won't be able to shift it.
Old 12-30-2011, 11:51 PM   #1844
camaro2lt
camaro2lt's Avatar
what spring do you use does defenderworx give you one? if soo i did not get one and is the upper screw already in the shifter?
Old 12-30-2011, 11:56 PM   #1845
PQ
Booooosted.
PQ's Avatar
The upper and lower allen screws should both be in the shifter already.
The spring is already in the shifter. You probably won't have a problem with the spring but if you find that you can't get the key out of the ignition then the spring is hung on the inside. Easy fix. But you should be fine.
The whole thing should only take a couple minutes.
Old 12-31-2011, 12:00 AM   #1846
camaro2lt
camaro2lt's Avatar
taking a pic of it now i do not think its in there
Old 12-31-2011, 12:04 AM   #1847
camaro2lt
camaro2lt's Avatar
pics
pics
Old 12-31-2011, 12:11 AM   #1848
PQ
Booooosted.
PQ's Avatar
The upper one is in there?
IIRC I might have used the lower one that came out of the stock one.
camaro of the week, the circle
