Flowmaster Exhaust
Old 02-21-2012, 11:37 PM   #2115
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
I'd need a clutch too.
I just happen to have one of those, low mileage, one owner... 13,000 miles or thereabouts... and a complete precision engineered factory shifter with the housing and know... You will have to locate a clutch pedal though...
Old 02-21-2012, 11:51 PM   #2116
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
16" wheels over 14+" rotors & calipers? i thought it was a stretch to make 18"s work
I bought a set of V6 brakes for the rear. They'll also have to modify the LCA a bit too.
If I go Forgeline I want 305s in front as well. Mainly because Forgeline can do it.
If I go Vossen then I'll go staggered because they CAN'T do 305s in front.
Why put such heavy fat wheels up front?
Old 02-21-2012, 11:53 PM   #2117
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Is Pete offline?
Nope...Emma - RUN!
Old 02-22-2012, 12:06 AM   #2118
The Stig
knows 2 facts about ducks
The Stig's Avatar
Does Forgeline make 22s?
Did you learn nothing?
Click to view my build thread
Old 02-22-2012, 12:23 AM   #2119
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Miles and miles of
Originally Posted by BullF-16 View Post
All i can say is to Pedders and Forgeline. That is no easy task from a douche like me. I am pretty anal when it comes to certain things.....thanks again Pete and David at Forgeline
It started here: http://www.camaro5.com/forums/showthread.php?t=37333 and is not for the strip, but you already knew that
Old 02-22-2012, 02:31 AM   #2120
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Ah, if only.
Handling, stability, control, looks, etc............. Lot's of fun stuff I bought the car for.
Better question is why not? What do you think I lose by having them?
I gain in road MUCH more than I lose in strip.
My car is as powerful as it's going to get. So I'll set it up the best way I can for me. And part of that is to have as much fun with it as I can.
I'd put more power in it for mostly drag racing and set the wheels up strictly for that but having only run down the strip one time I have no business doing that. So I maximize my cars universal fun potential.
I still may get the Vossens though, but it would be more of a save money and still have a nice set-up thing. If Vossen did the same balanced set-up I'd do that.
How far back do I need to go to find these pictures, PQ?
I put them in the OP. LOL
Old 02-22-2012, 06:23 AM   #2121
garcmol
garcmol's Avatar
For the twisties!!!
Old 02-22-2012, 08:29 AM   #2122
Kyle.Gilmour
Charter Circle Member
Kyle.Gilmour's Avatar
Drives: 427 LSX- with TWINS
I have everything else you need Randy.....
Monster Stage 5 Single disk Clutch
(Monster parts are all brand new, never installed)
- Clutch pedal assembly
- Clutch master cylinder with lines
- Stock flywheel
- Driveshaft with rubber couplers
- Manual trans cooler lines and fittings
Old 02-22-2012, 08:37 AM   #2123
Darth_Emma
Darth_Emma's Avatar
Ah, if only.
I don't know enough about what is most beneficial as far as tire widths go up front for auto x or road racing. I guess I was asking to find out, not to criticize. I've heard that 20" wheels are a good choice for that (that's why I went for 20s for street driving). They're a good compromise between performance and looks too.
Is a 305 tire recommended for road racing? I would think it would cause the front tire to have less grip (fewer lbs. per square inch) digging into a curve. Although, it would have more contact patch. These things are always a compromise.
Personally, I like the look of a wide tire in the back and a 275 or 285 up front.
Does such a wide tire up front cause any issues during tight turns? I mean, is the wheel going to rub the wheel wells (especially on a lowered car)?
Good luck. I hope you are absolutely 100% happy with your choice of wheels and tires this time. Let's all put the Savini nightmares behind us.
Old 02-22-2012, 11:10 AM   #2124
Redemption
Just Because!
Redemption's Avatar
Drives: 2010 SIM 2SSRS
I recently put 305/30's pirelli neros on my forgelines, rear only. Moved the stock rear tires up front (for now).
First impressions.... Ehhh it doesn't look right at all (I'll post some pics in a bit). My car is about as low as yours and the fender gap is just too big for my tastes.
Tire performance: when it's cold, they suck. Might as well have bald tires. And that's with no Maggie. Warm outside, they hook pretty good, better than stockers. Rain, they are same as stockers.
Having the 275 up front seems to help in the corners. I havent been to a track yet, but my normal test corners I am able to take a little faster.
My 2 cents, if you want the look, go 315/35s.
Pics in a bit.
Jason
Sent from my payphone using carrier pigeons.
Redemption is offline   Reply With Quote
Old 02-22-2012, 11:27 AM   #2125
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
This thread is a good explanation of the why...
clearly it is for handling and not necessary for drag racing. but it makes a lot of sense to take advantage of a balanced and square setup.
Old 02-22-2012, 11:38 AM   #2126
Darth_Emma
Darth_Emma's Avatar
Thx.
Old 02-22-2012, 12:25 PM   #2127
PQ
Booooosted.
PQ's Avatar
- Stock flywheel
Even as I put my car closer to the road racing side of things I still will ultimately have a drag car at heart due to the auto tranny. I'd be on the fence about it even if I could do it for very low cost or even free. Much less to have to spend 5k to do it. (just a geusstimate, I really do have no idea but way too much for me. hahaha)
For the twisties!!!
I still may end up with the Vossens. I did a few photoshops with the Forgelines and Vossens. The Vossens would be a staggered set-up.
I'll shamelessly post them right here, right now.
Pics in a bit.
Jason
Ya, post pics.
As far as driving on them go, guys on the track are sure loving them.
I'd be pretty tight but still good with 305 35s in rear but not sure about 315. I'll have to check into it. But the perfect square would be disrupted.
Old 02-22-2012, 12:38 PM   #2128
garcmol
garcmol's Avatar
Thought you were trying to get away from square!
I don't like wheels (for me) with all those little nubs or screws around the lip. Too many crevices for road crap and brake dust to get in there and slowly start eating its way through things. Now those Forgelines are sweet and a clean face.
camaro of the week, the circle
