B&M Racing
Old 03-04-2012, 02:32 PM   #2535
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
Well, It seemed like a good idea.
There is NO 12 inch section of the Borla exhaust that isn't bent or have a turn in it so I can't put this 'Y' pipe in and fit the motors.
I might have to take it to a shop.
Welcome to the wonderful world of cutouts.
Old 03-04-2012, 02:34 PM   #2536
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Being so low to the ground is the problem.
I could do it in a couple hours if I didn't have to worry about that.
This style of cut-out might just be too big. Too bad too cause I like the design.
Old 03-04-2012, 02:36 PM   #2537
Darth_Emma
Darth_Emma's Avatar
That is EXACTLY what I went through. The auto tranny is bigger than the M6 tranny. Makes it much harder to tuck them up in there. That's why IPS had to recut mine and weld them back together into the right shape to fit in there. If it wasn't for ground clearance on a lowered car, it would have been easy.
Old 03-04-2012, 02:39 PM   #2538
PQ
Booooosted.
PQ's Avatar
There is one spot I could get them in at, right behind the would be cats just before the bend toward the center but it's tight enough that I can't know till I cut it. Even putting the assembly up to it it's very close. But I'd have to cut the ends off the cutouts and use the OEM coupling clamp. Which is OK but if it still didn't work then it would suck.
Best not to try it.
Grrrrrrrrrrrrrr.............
Old 03-04-2012, 02:49 PM   #2539
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Oh just run the pipes through the interior and back out. Fixes your ground clearance problems...
Old 03-04-2012, 02:49 PM   #2540
The Stig
knows 2 facts about ducks
The Stig's Avatar
Hmm - you can't just change out a section of the exhaust? Seems like the easiest way to me, but
Click to view my build thread
Old 03-04-2012, 02:53 PM   #2541
PQ
Booooosted.
PQ's Avatar
SST style. FAB FAB FAB. LOL
No need for OEM heater.
Change it out to what?
That's what the 'Y' pipe does essentialy in a 10 inch section but have to be able to be a part that will fit the motors too.
Old 03-04-2012, 02:55 PM   #2542
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
just bring it over to my place...lol
seriously tho... can you snap a pic of the area under your car? I'm trying to visualize it
Best not to try it.
you may have to shorten the cutout itself. shouldnt be an issue so long as you can get the clamp to still work.
I piss excellence
and fart awesomeness
Old 03-04-2012, 02:56 PM   #2543
The Stig
The Stig's Avatar
Ah OK. Nevermind then. I guess your stuck :(
Old 03-04-2012, 02:57 PM   #2544
CamaroSpike23
Truth Enforcer
and Randy... I'm going to be hitting the road in about an hour and a half... go charge your phone... I will be calling.
I piss excellence
Old 03-04-2012, 03:00 PM   #2545
PQ
Booooosted.
PQ's Avatar
Got it with me and earpiece on.
Old 03-04-2012, 03:02 PM   #2546
CamaroSpike23
Truth Enforcer
is it charged?
snap some pictures if you can with a ruler or something of well known size next to the exhaust for reference if you don't mind.
I piss excellence
Old 03-04-2012, 03:03 PM   #2547
CamaroSpike23
Truth Enforcer
I refuse to believe that. after all the other stuff Randy has done on his car... a little "placement" issue shouldn't be a problem.
I piss excellence
Old 03-04-2012, 03:04 PM   #2548
The Stig
The Stig's Avatar
Oh I know, I'm sure Randy can jerry-rig something up. That might just involve cutting/trimming the cut outs though.
camaro of the week, the circle
