Old 03-31-2011, 01:18 PM   #1261
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Poor Randy...can anything ever be easy for you?
I feel like we should change your thread title to Days of PQ...so much drama!
Good luck getting everything together.
LOL
actually the confusion is from us wanting to skip the step of setting the ride height if we don't have to.
So he made the decision to install them the way they are since he really want' his car low.
if it's too low he'll remove em and set the ride height a little higher.
Old 03-31-2011, 01:45 PM   #1262
Buffnshine
So Cal Camaro5 Race Team
Buffnshine's Avatar
Drives: '10 SS/RS, '06 HHR, '70 El Camino
much better than a movie
Go Team L99
TEAM L99 - So Cal Camaro5 Race Team #27
9/5/09 Purchased #36962 Black 1SS/RS L99 "E-TCKT" Base Dyno 328hp/341tq @BBK meet
Mods to Date: Window Tint 5% & 15%, ACC P13W Lighting, Adaptive DRL Harness, Ghost Armor, Lloyds "SS" Mats, Dash Plaque, Flowmaster Outlaw Exhaust, Drake Front Bowtie Delete, Stealth 3457 Chrome/Mirror Signal Bulbs, Grant Revolutions Steering Wheel, PFADT Sport Springs, Sway Bars, End Links, Trailing Arms, 4 Wheel Alignment, Hurst Auto Shifter and Paddle Shifter, Satin Black Rear Tail Light Bezels
Buffnshine is offline   Reply With Quote
Old 03-31-2011, 03:26 PM   #1263
Redemption
Just Because!
Redemption's Avatar
Drives: 2010 SIM 2SSRS
Its easier to LOWER the car once they are on, VS trying to raise it.
Damn dont have any of my install specs when I did my XA's...All at home somewhere...But, looking at the picture above, there should be about the same about of space between the height adjustment ring and the lower lock ring for a 1-1.5 inch drop. Ball park...
I'll look for my specs when I get home.
Jason
Redemption is offline   Reply With Quote
Old 03-31-2011, 03:38 PM   #1264
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
All iPhone pics so I didn't take much to choose from. This is every pic I took. I decided not to really document it since GTAHVIT already did.
Old 03-31-2011, 03:40 PM   #1265
GTAHVIT
Blessed
GTAHVIT's Avatar
Nice! very very nice.
Damn that thing is slammed...
Old 03-31-2011, 03:41 PM   #1266
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
And I don't see any blood, so that's a plus!
Old 03-31-2011, 04:01 PM   #1267
PQ
Booooosted.
PQ's Avatar
Fraternizing with the enemy! Danger, Will Robinson!
Hey I didn't tell him how to fix it.... In fact I told him the tire and the fender are supposed to touch .... it helps prevent body roll...
Didn't work smarty.
Originally Posted by Dr Jkel View Post
Less air = Less bounce as well
So drain the air from tires.
Originally Posted by 600hp-lpe View Post
Maybe... but once you put the preload in, there will be room, as the bottom spring perch moves up.
He still hasn't set the ride height either, which may give more clearance between the rings.
My confusion was that the spring, even with the bottom perch rings all the way down against the ride height ring, gave the spring tension. Right now, as we speak, I hammered the lock washer to the bottom perch and left very little space. I basically had to end up with more that what would be 3 to 5mm worth of compression. So I could have some space at the bottom. It worked out.
What spurred the confusion was I was supposed to screw the retainer nut down finger tight and I was getting compression in the spring doing it finger tight. Wasn't sure at that point if I was supposed to bottom the nut out (which you do) or just finger it till you get spring compression.
Once I knew wht the deal was, I just took the chance on the ride height and measured both spring perch gaps for each side and made sure they were equal. Did the same for the rear.
Piece-a-cake..........
Old 03-31-2011, 06:25 PM   #1268
Mr Twisty
Mr Twisty's Avatar
Is it lower now than it was? Sure looks good!
-- Benjamin Franklin
Old 03-31-2011, 09:39 PM   #1269
PQ
Booooosted.
PQ's Avatar
I'm an idiot........... I didn't measure it before.
But, yes. It's lower in the front by about half inch and in the rear probably 3/4.
Old 03-31-2011, 10:00 PM   #1270
600hp-lpe
Drives: 2010
Are you keeping the 22's, or going with something a little more performance oriented, when your wallet recovers?
600hp-lpe is offline   Reply With Quote
Old 03-31-2011, 10:09 PM   #1271
PQ
Booooosted.
PQ's Avatar
I'll keep the anchors for now. May just buy some wheels for DRs on the back and keep them for track days.
Old 03-31-2011, 10:23 PM   #1272
PQ
Booooosted.
PQ's Avatar
Actually maybe only half inch back quarter inch front.
Here are some I took earlier today.
STIFF STIFF STIFF.............. I love the ride.
And here's one just for you Chris......... I did it......
How bout my collection I'm starting. LOL
The stock Sway bars, air box, window cleaner reserviore, headers, exhaust, mufflers, wheels, and a few other items are long gone already. Sheesh, won't be much left of my original car at this rate.
Old 03-31-2011, 10:26 PM   #1273
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I sold my intake manifold for a good buck. You might want to list that in the members classifieds section. Those Pfadt springs will get a you a couple hundred too.
Your car looks GREAT on the Pedders! Congrats!
Old 03-31-2011, 10:28 PM   #1274
BeckyD@JamesMartinChevy
BeckyD@JamesMartinChevy's Avatar
Beautiful!!!
Becky
Don't forget, I honor ALL DISCOUNTS THAT APPLY!
Available Inventory -James-Martin Chevrolet
BeckyD - I Deliver Nationwide!
..only 20 min from Detroit Metro Airport!
BeckyD@JamesMartinDetroit.com
ChevyFleet@aol.com
BeckyD@JamesMartinChevy is offline   Reply With Quote
camaro of the week, the circle
