| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
DO you guys think if i got the dealer to install the hot cam the car would still be the same? If they pulled the motor out then they could probably put it back to normal but if they decided to leave the motor in and just tear off the front end would they be able to assemble it back to factory condition? Would the gaps still look perfect?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: fanboys and ass kissers crazy. Join Date: May 2008
If the dealer knows what they are doing then yes. But after owning a 4th gen, I would drop the cradle. Much easier IMO.
"BBOMG - More than just a car show.... It's an experience!" |
![]() Drives: 1985 IROC, 2011 Camaro Join Date: Oct 2008
cam swaps are EASY. I don't see any issues. I could swap mine in less than 2 hours on my 4th gen with the motor in the car.
and yes, it should still be in 'factory' condition with everything looking normal |
![]() Drives: 2010 2SS/RS & 04 silvy Join Date: Mar 2008
^^^ im with him, swapped mine in my 4th gen in about 3 hours. It was fun too.
How did you get the lifters out of the way without removing the heads?
#6 | |
![]() Drives: Z28 Join Date: Jul 2008
With pen/stick. Magnets in place of the rods
#7 |
![]() ![]() Drives: Everywhere Join Date: Jun 2008
LS engines have keeper boxes in the valley, just give the cam a full rotation and they stay in the up position.
#8 |
![]() Drives: 2003 Mustang Gt Conv. Join Date: Oct 2008
so what exactly is a hot cam? also i have never had a new cam installed in a car. what benifits does a new cam offer?
#9 | |
#10 |
![]() Drives: 1998 convertible Camaro RS Join Date: Dec 2007
Not to mention the extra 50 horses GM is claiming it will give the LS3 engine!
#11 |
Yes, that's my real name.
Drives: 2005 LS2 600hp GTO Join Date: Jul 2008
but will it smog?
see the maggie will 50 state smog.
Magnuson 112HH supercharger at 7.5 psi (Virtual 9.0 liter) 600hp 1 of 2 torrid/red int /A4/05 555r 275/40/R17's Nitto Extreme Drags 1.7 60 ft Car runs high 11's No other mods. I got the first 112HH Magnuson blower ported for a GTO. Now it appears it was also one of the last....
![]() http://www.ribbonprinting.com http://www.personalizedawarenessribbons.com |
#12 |
According to GMPP smog will not be able to detect a significant enough difference. Not only that, neither will almost everyone who gets one installed. The idle and sound will be about the same. Unless you're a GM engineer who helped develop the engine, you should have no idea until you're pasted to the seat as you accelerate.
#13 |
so there is a GM hot cam for the LS3??
#14 | |
Yes, it's the same one for the LS1, LS2, LS6, etc. |
#15 |
so the best route to change the cam would be to pull off the front end?
#16 |
yup
#17 |
#18 | ||||||
The Jalopy Jedi
Drives: anything I can get my hands on Join Date: Sep 2006
if it were me, id just pull the lifters. Quote:
http://www.ls1howto.com/index.php?article=23 cam swap on an LS1 4th gen
#19 |
Helping Build America
Drives: 2010 2SS/RS,LS3 2006 Colorado Join Date: Aug 2008
If it's GMPP, is it covered on warranty if the dealer installs it? Any effect to engine warranty?
No need to change lifters, rod, etc. Just tune afterwards? Does it effect MPG?
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
#20 | |||||
The Jalopy Jedi
and a hot cam should work with the stock valvespring max lift. now if you go with a bigger cam, you will need to make sure your valvesprings are up to the job.
#21 |
#22 |
![]() Drives: 2010 CMG 2SS Join Date: Oct 2008
How hard do you think it'll be to get the dealership to give it the ls376/480 flash when they're done? I'm assuming the new cam needs a different tune, and the official program should not violate any warranty you're trying to keep by having the dealership swap them.
![]() Cyber gray! |
#23 | |
come to poppa
Drives: 67RS,09 Harley FLHX Join Date: Jun 2008
Cancelled the 2010 SS/RS (for now) and bought this instead (2009 Harley FLHX) |
#24 |
![]() Drives: 2010 Camaro 69 Nova Join Date: Oct 2008
IT's on the GM Performance Parts website. Here is a link.
https://store.gmperformanceparts.com...chText=Hot+Cam Last one on the page. You will also need a 3 bolt 4X Cam gear. The LS3 cam gear is now a single bolt design. A LS2 non GTO gear would work. The chain and tensioner are good to go. This modification would not be covered under warranty. Also GM does not have a calibration that would work in the Camaro. As you know GM Performance Parts has a controller that is available for their crate LS376/480. That controller is not compatable with the Camaro. I am sure that most tuners would be able to tune that cam change. Robin
Holley Performance Products
#25 | |
I know it will fit and function, it just takes a different grind. |
| Thread Tools | |
| Hot Cam! | smike07 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 155 | 01-14-2010 06:30 AM |
| Hot Rods & Hot dogs | Iroczlover | USA - Northwest / Pacific Northwest | 0 | 08-18-2008 05:15 PM |
| Can a Superchagered Z28 have a lumpey CAM, and sound like a NA heads and cammed LS3 | D-Unit | Forced Induction - V8 | 12 | 07-29-2008 03:34 PM |
| New Cam | GCguy2169 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 07-22-2008 05:36 AM |
